Question about LG Washing Machines
DE comes on in the middle of the cycle and the machine just stops working
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. DE is a door open error, you'll have to check the door if it's properly closed. Also check loose electrical connections at the door switch and PWB assembly. If everything appears to be fine then it is the door switch assembly that should be replaced. Please rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Oct 06, 2010
Ge washing machine/stopped in the middle of the drain cycle
sounds like your pump has got jammed with a coin or usually hair grip.
Sep 18, 2016 | GE Washing Machines
Sw56app with DE message
On your Samsung washer, the "dE" error code typically occurs just after the rinse cycle. This will leave your machine filled with water as it does not drain because the washer thinks that the lid is open. Reset the cycle to properly drain the water then stop it before it fills up again.
Check to make sure nothing is preventing the lid switch from letting the cycle continue. Debris, such as lint or paper, could have fallen into the switch hole. Rust or an object could also block the hinges on the back of the lid. Clear anything off of the washer that may interfere with the lid switch then try to run the cycle again.
Dec 04, 2012 | Washing Machines
I have a bosch washing machine make is a exxcel 1200 express and it stops working in the middle of a cycle and the words f04 come up wot does that mean please
there may be a stuck in cycle of rotating knob kindly rotate the knob more than three times your problem will be sloved otherwise replce the mechanism
Dec 23, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Wash Cycle doesn't start
Unplug the machine for about fifteen minutes. When your fuse blown it caught in the middle of the cycle. By unpluging it will reset the machine.
Dec 07, 2009 | Washing Machines
DE code on WM0642HW TROMM washing machine We've been getting this error code on our washing machine for some time. The code is coming up quite frequently now. It stops the cycle so the load is not...
HI, this is a Door Open Error.
Possible Causes are..-
* Door not all the way closed
* Loose electrical connections at door switch and pwb assembly(Control Board)
* Door switch assembly is out of order(Miss aligned)
* Gasket on door may be creased in
Most common issue here will be a defective door lock switch. check all causes before replacing the switch.
Jul 11, 2009 | LG Washing Machines
Machine just died in middle of cycle. will not
first of all take the waste pipe out from the back of the washer which goes to the outside drainage,make sure you have a bucket to catch all the water that comes out,the lower the pipe the faster it will come out,then you will be able to open the door,and the problem that you have with it stopping in middle of cycle is that the bushes are worn on the motor,these are easy to replace and cost about £10.00
Jun 07, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Washer stopped
Bear in mind I'M a novice.. but I'm going to try replacing the CONTROL PANEL ASM WJSE4150B1WW (for GE Model: WH42X10303 found one for $45 at partadvantage.com ... I don't have the water temp problem but the other two yes...
Dec 04, 2007 | GE WBSE3120B Top Load Washer
Maytag stops at any cycle after warm
sounds like a motor problem. the motor might have reached then end of its life and is overheating causing the thermal overload protector to shut down the motor.
Sep 09, 2007 | Washing Machines
Washing Machines Logo
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
