Question about Panasonic Palmcorder PV-DV102 Mini DV Digital Camcorder
No power with remote
When i leave the camera on for a while it turns off automaticaly after not being used for a short time then when i try to record again with the remote i can't get it to turn on and record with the remote please help me.
  • 3 Answers
Try changing the autotimer in the Menu Screen.
Posted on Aug 22, 2008
Dyk4500 how to fACTORY RESET
The PW or code to enter with the remote is 12888. You MUST have a remote, or the unit is worthless. The remote may not look exactly like how it appears in any manuals. My remote is the original and it was a stark difference in appearance, although having all the correct and needed buttons.
Code may not initially work, depending on how any configurations may have previously been setup. Try the following steps to reset configuration.
  • Remove the 3 screws to open the unit up.
  • Remove the CMOS button battery.
  • Short the battery contacts for 30 seconds. (I also tested shorting the contacts while powering the unit on to see if that had an effect. It will not damage the unit, and it also reset the DVR, but I recommend only doing the power on method as a last resort.)
  • Insert CMOS battery.
  • Power unit on and wait for display to show firmare version and all HDD info. after about 30 seconds the cameras and locations should appear. If they do not, Press 'MENU' 2x times, and wait for the cameras and names to appear.
  • Press 'MENU' on remote. When menu appears, press 'DOWN' 2x times to get to setup utility and press 'ENTER'
  • You should see an "Admin" and "guest" accounts. "admin" should be already highlighted, but if it is not, use the directional buttons to highlight the "Admin" account and press 'ENTER'.
  • Enter the code 12888 and press 'ENTER'.
  • You should now have the Utility Menu to reset the unit, add new accounts. adjust network info, etc.
Oct 17, 2015 | GE Adt Calibur By Kalatel Dvmre-16cd Dvr...
Canon powershot elph 320 hs
Hi Doug,
You are right in identifying the cause of the pre-mature shut-down of the camera during video recording. Battery saving features (auto-shut down) detect the camera as idle while you are recording. you could do two things to avoid this;
1. A short term practice is to manipulate the camera to stay on by using the zoom button, taking a snap-shot or anything like that from time-to-time, before the 2 minutes is up. This will keep the camera awake long enough for you to record a good length of video.
2. The second and permanent option is to program the camera - just as you mentioned. You can do that by opening the menu and under camera setting , scroll down till you find the auto-power save. Change the time to your preference
Please note: You have to switch off your camera as soon as practicable while the auto-switch-off time is set at a bigger value to conserve the battery. otherwise the battery will be drained quicker than you imagine.
I hope this helps.
Sep 01, 2014 | Canon Cameras
How to keep Dish Remote from truning of Dish reciever when turning off TV
r_pettit,
I can definitely assist you with this. What button do you press when you turn off the TV? Have you tried pressing 'SAT' then the big red 'Power' button on the remote?
Tommy Faust
DISH Social Media Representative
Jul 05, 2013 | DISH Network ViP722 DTV Receiver /...
I'm unable to record with my AG-DVC7. When I turn on the camera , the LCD screen comes on and says "tape not inserted". But immediately I open the tape compartment, power will turn off from...
  • Like all the old video recorders there are mechanical parts inside what need cleaning in high priority the parts that mechanical activate switches for the intake in the little microcontactsswitches and the most important of all are mechanical mode-select-switches where timing is an hot issue
  • The entire process is timed often gears are used, but sometimes also strings that can slip by age and or dirt, cleaning and contact cleaner and look for bad soldering.
  • Also check that the lens motor for the aperture setting is working properly, because everything concerns mechanical settings when that failure then stops the device.
    Also the zoom lens motor that are the first mechanical parts after the tape was lace in. all must exactly done in a special short timing.
PANASONIC AG DVC7 SCH Service Manual free download schematics eeprom...
Apr 23, 2017 | Panasonic AG-DVC7 MiniDV Proline Camcorder
I can't find my manual. I need to hook it up so that I can record tv shows I like to watch when I am not home. But I didn't do it right and I am having trouble with the remote also.
You can download a manual from http://www.funai-corp.com/support/manuals.aspx . Click on Customer Support and then Owner's Manual. Remote problems - first try new batteries then try a universal or other replacement remote, http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=EWD2203+&uuid=12828737757670 .
For problems with timed recording, make sure the clock is correctly set. If power goes out for more than 30 seconds, the clock will be incorrect and the timer information will be off. Insert a blank tape (or one you want to record over). Then press Menu and then go to Timer Programming. (Use the up/down arrows and then hit the right arrow button.) Set the frequency of recording followed by the day and start time of the programmed recording. Then set the end time of the recording. Next set the channel number. (with some set top boxes and TV connections, choose 3 or 4 depending on the way the setting of the RF output. Then set the channel on the set top box and leave the box on.) Then set the recording speed. Press T-set to lock in the program. If you want to watch a tape before the program starts, press T-set (turning off the timer light). Remember to press T-set afterwards to resume programmed recording. You can't record to DVDs.
I hope this helps.
Aug 27, 2010 | Emerson EWD2203 DVD Player/VCR
When recording from vhs tape, and the signal is poor at times, the machine automaticaly stops recording temporarily and resumes when the signal is more stable. how can this feature be disabled?
If you are recording VHS tapes that contain macrovision, and most commercial tapes do, you can't record them with this DVR because it is compliant with the law that says you can't do it. So don't try. Download nearly every movie/tv show from the internet instead.
If you are recording from VHS tapes that you have created yourself from TV sources, or from camera, you must stabilize the picture. There are several devices like that. Do a google search on "vhs stabilizer".
Apr 21, 2009 | Protron PD-DVR100 DVD Recorder
LG LCD TV remote power button turns off LG DVD Recorder as well
Hi VMUZZI,
IT Seems that teh SIMPLINK Featire of your TV/DVR is ON. Try to OFF the feature.
Mar 09, 2009 | LG DR787T DVD Recorder
Stopped working last night
simple, returned the product.lesten to be learned, dont purchase any product concerned with sagem or hitachi.happy new year to all. bplak63 stockport.
Dec 25, 2008 | Televison & Video
Dta Dispaly
Acording to the manual to display date and time press DATA CODE ON THE REMOTE CONTROL during playback. Useless if you dont have a remote like me. IT deos say the date and time are recorded automaticaly onto the tape.no idear how to view it. Hope i have helped Eric
May 22, 2007 | Sony Handycam DCR-TRV145 Digital Camcorder
Panasonic Palmcorder PV-DV102 Mini DV Digital Camcorder Logo
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
