Question about Seagate Barracuda 7200.10 500 GB SATA Hard Drive
Hard disk error then i format it erasing all files i want to recover the files now is it possible?
    Brigadier General:
  • 10,406 Answers
It depends on how long the FORMAT took -- if it just was a few seconds, then what happened was a 'empty' table-of-contents was written, to make the drive appear to be 'empty', and nothing was written on the other 99% of your disk-drive. Thus, some "file recovery" software can be used to read that 99% and "stitch" together each block of data, to reconstruct the old table-of-contents.
Or, if the FORMAT took several minutes, then every block of data on the disk-drive was overwritten by a block of 'zero' bytes, making your data _almost_ unavailable. In that case, you need to find a 'friendly' federal agent (maybe Department of Homeland Security) to use 'advanced' techniques to read the 'residual' magnetism that is 'under' the block of 'zero' bytes, to recover the data.
Posted on Oct 06, 2010
Hard drive does not recognize a file system
Buy a software called EASUS DATA RECOVERY WIZARD, install it on a working computer. Connect your hard drive as a slave and open the program. Use the Complete Recovery Method to recover all your files. It is usually pointless to try and recover system files. Unless you want to recover your documents and files that were there in the hard drive.
Apr 03, 2012 | Iomega Computers & Internet
How to recover tally data from the twice formatted NTFS hard disk partition ? my operating system is window xp service pack 3
Hi, Mac data loss is actually a hard task for many Mac users 'cause most of them think the Mac OS is a complicated computer operating system (At least I think it is complicated). Here are some tips you need to know after data loss happened.
1. If you meet the file loss situation, keep calm and stop using your computer to do any read or write operation until you find the way to recover the lost files because any wrong operation.
2. If you've lost a file, time is of the essence. As new files saved to Mac hard drive or storage devices, the original files gets overwritten. So do not use the drive or disk which your deleted files are stored before at all, until you have completed the scanning and recovery process.
3. The system crashed or the files loss situation happens occasionally, so remember build a backup for the files periodically is strongly needed.
4. If you meet the file loss situation again, stop using the Mac or storage device right now, use another computer to process the files recovery.
5. Remember this, no matter at the normal time or after files recovery, build a backup for the files periodically is the best method to protect your files from data loss situation.
Maybe you can try uFlysoft Data Recovery for Mac, it can recover empty trash on Mac only in three steps: Step 1. Launch the software to scan the device where your files deleted
Step 2: Preview the scan result files and make mark if it is the one you find
Step 3: Recover files
Mac Data Recovery Recover Lost Data with Ease
Feb 06, 2011 | Computers & Internet
My sandisk cruzer says it is not formatted. it contains all my documents but I cant open anything if i format it i will lose all my data help!!!
Possible Reasons:
1. Your USB flash is too old and can be corrupted with time went on. As you know no hardware can be life-long ever.
2. There are bad sectors in the specific area of the disk that is required for a file system, e.g. for a boot sector or the FAT table sector. Since such a drive is obviously not possible to use, Windows refuses to format it.
3. Sometimes, you cannot format the drive to the FAT file system if it has been formatted to a file system which is not recognized by Windows. Such a drive should be reformatted to NTFS first, and then to the FAT file system.
Solution:
Step 1: Try the problem USB on another computer (better be most common Windows OS). See if the device can be accessed normally. This way can clear the buffers and eliminate incompatibility. Sometimes it will let the error disappear and make the drive work normally again.
Step 2: If the first method still won't help. Try recovering the data with some data recovery programs first of all. If you are running Windows, you can use Data Recovery for Windows. For Mac OS X users, turn to Data Recovery for Mac
Step 3: After the files are recovered, then follow those steps to try format the error USB drive (connect the disk to your PC first). My computer -> Properties -> Manage -> Computer Management -> Storage -> Disk Management -> select the problem drive and then format it from here.
Step 4: It's not over. After formatting, try use the data recovery software recommended in #2 to re-scan the drive to see if you can harvest more data. Good luck!
Feb 26, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
How to recover data from a faulty hard drive
As long as the drive is spinning you should be able to recover files with any decent file recovery program. I've just spent half a day recovering about a 1000 photographs that had been deleted and apart from all the unwanted stuff that also gets recovered, it all went well.
If the drive is not spinning or is making clicking noises then your options are much reduced. You will most likely have to use the services of a professional data recovery company - and they don't come cheap.
Dec 03, 2009 | Computers & Internet
When i try to access my Trekstor Datastation maxi mu 400Gb, I had error that the drive is not formatted. And if I try to fix or retrieve the files with PCI file recovery or other software like it, i got a...
it is difficult to recover it from that partition..use this software
"Recover My Files" if it is recover then ok otherwise use "Virtual Lab"
if it is not again recoverable then noway to recover. after all efforts one thing u can do is to quick format it and then try recover my files to recover from fast formated drive....but chances r very less something like wallpapers and songs can be recover.
Good Luck.
Hope the files will recover
Nov 24, 2009 | Trekstor Computers & Internet
Undelete/unformat a Mac formatted external hard drive.
The theory to unformat a Mac hard disk is, when you format a Mac HFS+/HFSX Volume or format a external hard disk, the data are not really wiped. Format process just marked your Mac hard disk as available to reuse, no matter it is quick format or complete format. So if you put if you fill in a mount of new data to your hard drive, then the formatted data are overwritten, your will permanently lose your formatted data.
Follow this guide to unformat your mac hard drive or formatted external hard drive on mac.
Jul 26, 2008 | Computers & Internet
Open Questions:
bricked hard drive? Would folling this lead to a full hard drive format or just unbricking a drive like people sat it does?? Also any other ways that might help would be great to know, heres what i'm talking about! "Fixing The Drive NOTE: Commands for you to type are in red boldface. Pay attention to upper & lower case - it is important. Turn on power to the RS232-to-TTL adapter and the hard drive. After a few seconds, Press CTRL+z. You should then see a prompt like this: F3 T> If not, swap TX & RX wires. Access Level 2 (type /2): F3 T>/2 (enter) F3 2> Then spin down the (disconnected) motor: F3 2>Z (enter) Spin Down Complete Elapsed Time 0.147 msecs F3 2> Very carefully, remove the cardstock that you placed between the PCB and the drive head contacts. Carefully replace and tighten the 3 loose screws. I suggest using a small piece of masking tape to help you hold the screws while you put them back in place. Then start the motor: F3 2>U (enter) Spin Up Complete Elapsed Time 7.093 secs F3 2> Next go to Level 1 (type /1): F3 2>/1 (enter) And do a S.M.A.R.T. erase (create S.M.A.R.T. sector): F3 1>N1 (enter) Cycle power to the drive, then do partition regeneration: F3 T>m0,2,2,0,0,0,0,22 (enter) After 15-30 seconds, you should see something like: Max Wr Retries = 00, Max Rd Retries = 00, Max ECC T-Level = 14, Max Certify Rewrite Retries = 00C8 User Partition Format 10% complete, Zone 00, Pass 00, LBA 00004339, ErrCode 00000080, Elapsed Time 0 mins 05 secs User Partition Format Successful - Elapsed Time 0 mins 05 secs Do not turn off drive until you see this message. Once seen, drive can be turned off. Power down everything, place drive back into your computer, and confirm that it's working." Thanks.
Apr 12, 2010 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Seagate Barracuda 7200.10 500 GB SATA Hard Drive Logo
83 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
