Question about Indesit Washing Machines
I have the indesit moon washer. The red door lock light is flashing when i start the cycle which is stopping the washer from going. The door is locked properly and there is nothing caught in it.
Just sorted this problem out, wife said just b4 leaving for work,oh love the door on the washing machine wont open and theres a red light on,,OMG i thought, as she said she would find the instructions when she gets home, so i got the corless drill out and a big hammer,( not needed,) lol just turned the power off and after 2 mins the door unlocked and was able to get all the clean wifes undearware out, cheers all and hope this helps
Posted on Jan 22, 2013
SOURCE: Indesit W 125 X Washer Handle Broke Off and Door Will Not Open
use something lopng and thing, a thin screwdriver operhaps. Pull the metal bar ( part of the spring) to the left. When this is fully to the left push the white plastic part in and jiggle about util the door comes off. Might be easier with sumone to help you pull the dor out as you uch in
Posted on Mar 29, 2008
  • 1462 Answers
SOURCE: Fixing broken door lock of Indesit W123X washing Machine
no easy way to open
disconnect from mains
take top off. feel down the front to where the door lock is and see if you can feel the door peg sticking thro the door interlock. force this with your fingers and with luck the door will open
if can't do this way, break handle off and lever peg with a small screwdriver
you can buy a handle kit complete. fitting this is not difficult - split the door and all will be revealed advise you make a carefull note of where springs go etc before you start stripping it down or take a few fotos if you have a digicam
Posted on Jul 10, 2008
  • 1294 Answers
SOURCE: washing machine door locked indesit WD12X
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 5 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped
Posted on Apr 02, 2009
beltronic205
  • 1474 Answers
SOURCE: The door locked light keeps flashing on my
Sounds like needs new door interlock swith Cost around 15 pounds.....Simple to fit
Posted on Sep 28, 2009
cpldw48
  • 163 Answers
SOURCE: Kenmore He 2 Plus washer door is locked and unable to open
unplug the washer an the door will open
Posted on Apr 25, 2010
Indesit IWD7145K Washing Machine Error code F06 flashing on digital display + all program indicator lights. What does this mean. There is no such error code in the troubleshooting section of the manua
F06 - Door lock fault
Issue: Washing machine door cannot be opened or closed/when the door is closed the machine the programme will not start.
Advice: If your washing machine door will not close, please check for any obstructions in the door lock.
OR,
Switch off the device. Disconnect power. Wait about 3 minutes.
Open the door, then close. Reconnect device to the network.
Start device.
Cause: Door lock fails to close / open door lock triac open / closed,
frequency signal fault
Dado
Feb 12, 2015 | Indesit Washing Machines
I have a indesit iwb71250 that the red door lock light is on constantly but we can open the door and shut although the machine will run it wont fill with water... any ideas
May be the switch is loose try fixing it with ascrew driver or the rubber hose is not fixed properly and the machine pump is taking air or the pump failure
Oct 19, 2014 | Indesit IWB71250 White 60 cm Washer Front...
Indesit Washing machine WIL88 red light flashing
Seems that the main board or the processor is hanging up and does not take up the full process control. You need to remove the panel and check for moisture on the board, check for loose connectors. If this seems fine the fault seems related to the board and can be confirmed with a board swap before one can be ordered. Check the door switch and wiring to the main board.
Jun 03, 2013 | Washing Machines
Indesit WIA121 Flashing Door Lock, Prewash and Spin Lights - Machine not draining
hi something similar has started happening to our washer, after the initial wash starts the machine doesn't do anything for a while then the red door light flashes on and off very quickly as does the 1st and 3rd green wash cycle light?
Jul 04, 2012 | Washing Machines
My Indesit Moon 1400 has stopped working. Shortly after the cycle starts the blue LED lights at start and 40 deg flash rapidly. Washing inside machine is soaking wet but has neither washed nor spinned. ANy...
Tom, I'm having exactly the same problem, Have you managed to solve it? The Service center will no even tell me what's wrong with (they're quite keen to get me to arrange a visit from their engineer for £110 though). Thanks
Jan 30, 2010 | Indesit W 123 Front Load Washer
Indesit washing machine not spinning - fault code timer and dor lock light flashing
my indesit washer/dryer wd12x programme dial goes all the way when it reaches spinning
May 30, 2009 | Indesit W 123 Front Load Washer
Indesit W1A 111 front load W/M
hiya
no need to worry they do this.
hope this helps
please dont forget to rate the helpfulness. thanks kj
Jul 20, 2008 | Indesit W 123 Front Load Washer
INDESIT 1000 DOES NOT START
Had a similar problem ,flashing red led means door not locked, I removed door from machine removed front from door and found hinge pin for lock had come adrift, religned pin and chapped back into position .THen replaced door and door to machine .dor shut and lock worked perfectly, hope this helps
If this doesn't work you may have to replace the EMW. Should cost you around 60$
May 23, 2008 | Indesit W 123 Front Load Washer
Washing Machines Logo
507 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
