Question about Minolta magicolor 2300W Laser Printer
Paper jam My 4-year-old Magicolor 2350 has a problem with paper jamming. Every time I send a document to it, it always returns a paper jam message, but only for the first page. When I remove the jammed paper, it always has a single crease down the middle. Thereafter, all the subsequent pages print fine. I spoke to Konica Minolta, who told me it was a sticky transport solenoid. Is it worth fixing, or should I buy a new printer?
    Champion:
  • 214 Answers
Open doors and find these solenoids, clean them and make sure they are moving fine, its not so hard. just step by step move with paper and find out where the solenoids are. solenoids aren't expensive so if its a solenoid problem you should fix it
Posted on Jun 19, 2008
Media jam fuser
replace the fuser unit. and replace the transfer roller and belt,
Jan 30, 2014 | Konica Minolta Magicolor 2530 DL Laser...
Paper Jam in Duplex mode when printing more than 1 sheet
check between the rollers there will be small bits of paper jammed in that is the reason.
Sep 09, 2008 | Minolta magicolor 2350 Laser Printer
Work Center Pro 575 always gets paper jams
If a document jam occurs during a transmission, the message "DOCUMENT JAM" is displayed. If this occurs, follow the procedure below. It is recommended that a duplicate from a copier, of the jammed document be used to reduce the chance of a jam when resending the document.
See Chapter 3, "Loading Documents" for document specifications and recommendations which may help avoid paper jams.
Note: The power can be left ON when clearing a paper jam.
Typical Causes of Document Jams
Recommended Procedure
The document is fed at an angle.
Adjust the Document Guides to the edges of the
document.
The document paper is too thin or too thick.
Make a duplicate using a copier and use the copy
as the sending document.
Document has tape or pieces of paper taped to it.
Remove the tape or make a duplicate using a copier and use the copy as the sending document.
The Control Panel Cover is not fully closed.
Close the Control Panel Cover fully.
The document is stapled. Remove the staple(s), or make a duplicate using a copier and use the copy as the sending document.
Basic Troubleshooting
1. Remove all documents from the Document Support.
2. Open the Control Panel Cover.
3. Remove the document jam. Remove any pieces of paper, paper clips, or staples that may have caused the jam.
4. Close the Control Panel Cover.
5. Verify the display has returned to the Standby Mode.
Jul 13, 2010 | Xerox WorkCentre Pro 575 Plain Paper Laser...
Paper jam occuring in my minolta qms2350 printer. What can I do? Di I need to and how do I change the rollers? Thanks
I am forwarding a list of manual that will help you with the paper jam issue and also would help you with any future issues related to your printer.
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Sep 10, 2009 | Minolta magicolor 2350 Laser Printer
Paper jam message on Magicolor 2300W
How do you clean the rubber rollers, hope you didnt use solvent....
Use dry cloth with dishwashing fluid only to wipe the rollers.  You will notice the increase in grip immediately.
Dec 17, 2008 | Konica Minolta magicolor 2300DL Laser...
Minolta 2350 DL laser printer stuck paper in rear user roller
sry, dont understand, where is the paper jam, in the end at the fuser ? or some where else?
Feb 05, 2008 | Konica Minolta magicolor 2430 DL Laser...
Out of Paper. Load Paper Error
Check
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00265823&cc=nz&lc=en&dlc=en&product=422000&dlc=en&lang=en
HP PSC 1600 and 2350 Series - Paper Jam or Paper Feed Problems"
When the all-in-one detects a paper jam, the following message appears: Paper jam: Press OK to continue . The computer might display the following message: There is a paper jam (or misfeed). Clear the jam and press the Enter, Resume or OK button on the HP PSC. This document will assist in correcting paper-feed problems such as paper jamming, print slanting, and multiple pages feeding into the all-in-one. s.gif Clearing paper jams
Jul 28, 2006 | HP PSC 2355 All-In-One InkJet Printer
Minolta magicolor 2300W Laser Printer Logo
552 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
