Question about HP Pavilion Replacement 200w Micro ATX PS3 Power Supply with Video Connector (PSHPPAVILIONVIDEO) Power Supply
I think it blew out ,how can i know for sure and if so how do i fix it
  • HP Master
  • 32,281 Answers
If the power supply has a burnt electrical smell, then it has failed.
I do not recommend you to repair this power supply, mains voltage equipment are dangerous if you do not have the electronic knowledge to repair this type of equipment.
I suggest you purchase a new switch mode power supply, with a capacity of the same wattage as the existing power supply or higher (higher wattage would be better especially if you are operating near the maximum limit of the old power supply).
Posted on Oct 06, 2010
Think fuse blew in trunk release don't know were this fuse is?
Try checking the fuzes under you hood look for the trunk relay if its not under the hood most likely it will be inside off your car
Aug 02, 2014 | 2006 Infiniti M35
Blew a fuse nedd to know where
fuse link should be in the battery cable it's self
Dec 14, 2013 | Kymco 2010 MXU 375 IRS 4x4
Right dipped headlight comes on and light is out
Had same problem.fixed mine by replacing what i think is the control modual located on the bottom of the headlight . Its about 3"by7" and looks like a hard driven or mini computer.u will also need a mini star pattern screw driver about six screws.to make sure thats the problem and to know if it malfunction n the reason, take the one out of ur good headlight n swap en n if ur bad one starts wrkn again.thats the problem.good luck n hope this helps
Nov 16, 2012 | 2002 Audi A4
Fuse keeps blowing in hotpoint microwave
The magnetron is the other issue, high voltage diode will sometimes crack causing a high level short, the capacitor developes a dead short across the 2 points, the power transformer almost never fails, "very rare"
Apr 08, 2012 | Hotpoint RVM1635 Microwave Oven
Check lint light on replaced thermal fuse 2x blew again??
it would be nice to know if it's gas or electric, I think it may be an airflow sensor switch,clean or replace switch
Feb 01, 2010 | Dryers
I BLEW MY AUDIOBAHN AW1208T SUBWOOFER AND WANT TO KNOW IF IT CAN GET FIXED I THE THINK ITS JUST DUAL VOICE NOT SURE THOUGH
is the rubber surround blown out.. look at voice coil itself .. it could be repaired but maybe not worth it. can u actuate the speaker down and up.. if you can then the voice coil is fused.. and if u can and u hear or feel resistance then there is work to be done to the voice coil and spider. Could be costly.. if its just the rubber.. use silicone to re-seal it.. ol skool trick..
Sep 14, 2009 | AudioBahn AW1208X Car Subwoofer
How to find a short in my wiring harness for a 1989 honda prelude? The fuse blew and now my tach,gas gauge,clock and blinkers don't work I put a higher amp fuse in and it lasted about 5 days and blew...
at least you know were to start,key on the fuse that blew.and everything controlled by it.i'm assuming that every time you replace the fuse now,it blows .think back before the short,was there any electricial problems,or devices that didnt work.,wires are melted together,or motors are shorted out.putting a bigger fuse in probably burnt a wire open(meaning got too hot and broke)whatever blew the fuse to start with,is most likley where the meltdown is ,start unplugging the things on that fuse,one at a time,remove tail lightbulbs,inspect thre sockets,look up under the dash at the wiring ,your clock,tach.and gas gauge ,are there,observation is almost 90%of trouble shooting anything .fixing it is easy pop the hood spend some time just looking at every thing follow wires make sure they arent melted together ,and are plugged in,just unplugging something and plugging it back in will show problems,things will fall apart.clips will break and hopefully you will see something obvious,shorts are never fun,do you have any electrical background?and know how to use a multimeter .if you do reply ,
Sep 14, 2009 | 1989 Honda Prelude
Front wheel problems...
remove wheel loosen nuts from one side be sure to catch any parts that fall out check for damage or rust fill bearing cups with grease put bearings back in tighten til snug make sure wheel still rolls put back on bike tighten retaining nuts
Apr 09, 2009 | Cycling
Possibly blew engine on 1997/96 Jeep Cherokee
Why do you think you have blown the engine, what are the symptoms? What happened?
Mar 25, 2009 | 1996 Jeep Cherokee Country
What can I do?
Sorry, the PS3 does not have a circuit breaker. Most likely when the power came back on the surge blew the power supply. You can get it serviced by Sony or replace the power supply your self.
Sep 30, 2008 | Sony Playstation 3 (PS3) Console
HP Pavilion Replacement 200w Micro ATX PS3 Power Supply with Video Connector (PSHPPAVILIONVIDEO) Power Supply Logo
183 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
