Question about Micro Innovations PD950P Mouse
My mouse is not connected with my pc - Micro Innovations PD950P Mouse
  • 3 Answers
Have you installed the driver that came with your mouse?
Posted on Oct 06, 2010
Nextech mouse through usb continues to install successfully, then freezes while trying to move about my laptop! No, it is not that the Lptp is working in the background, leaving the mouse to freeze th
Step 1:
For a standard trackball mouse, unplug the mouse, turn it over and then twist the retaining ring counter-clockwise to remove it. Remove the trackball inside the mouse. Clean the trackball with warm water and dry carefully. Clean the rollers inside the mouse with a cotton swab dipped in rubbing alcohol. Replace the trackball, then secure it with the retaining ring. Clean the outside of the mouse with rubbing alcohol and a cotton ball. For an optical or wireless mouse, clean the bottom of the mouse and the surface it sits on with a damp cloth. Solve Hardware Problems Make sure the mouse is connected properly. The connector will either be USB or PS/2. A PS/2 connector is color-coded green and can only be inserted in one direction. Check for any bent or broken pins or damage, then carefully plug it in, making sure the connection is secure. Reboot the computer. Connect the mouse to another computer, then reboot the PC. If the mouse works after testing it on another computer, the problem is most likely with your PC or operating system. Also, try a different mouse on your computer. If there is no PC freeze, your mouse is probably malfunctioning. Switch to a different USB port. Sometimes mouse freeze will occur if the mouse is connected to a USB hub. Connect the mouse directly to one of the USB ports on your PC. Try different ports until you find one that works. Replace the batteries. If you have a wireless mouse, replace the batteries with fresh ones. Also, try using a different kind of mouse pad. Sometimes surface imperfections can interfere with the operation of a wireless or optical mouse. Install more RAM or memory. If your PC doesn't have enough memory, PC mouse freeze may occur when you are running resource intensive programs. Installing more RAM will help your PC run more efficiently. Solve Software Problems Check for device conflicts. When you install another device on your computer, it can sometimes conflict with a PC mouse. Remove any new hardware and drivers you may have installed, then reboot the computer. Reinstall PC mouse drivers. In Windows, open "Control Panel" then "System." Select the "Device Manager" tab, then scroll to and select your mouse. Uninstall any drivers that are listed. Unplug the mouse and reboot the PC. Plug the mouse back in, reboot the system, then allow Windows to reinstall the drivers if prompted. Remove viruses. PC mouse freeze and other serious problems can be caused by viruses lurking on your system.Set the program to run a complete scan every 24 hours. Also make sure the virus definitions are updated regularly. Turn off video acceleration. Sometimes video acceleration can cause PC mouse freeze. Go to "Control Panel," then click "Display," and then "Change Display Settings." Click the "Advanced Settings" button, then the "performance" tab. Set the acceleration slider to "None," then reboot. Repeat the process moving the slider up one notch until you have the maximum amount of acceleration with no mouse freeze
Feb 18, 2013 | Computers & Internet
Cursor freezing
Remove viruses.
hope this helps
Oct 09, 2012 | Sony Vaio VGN NS20E Laptop Car- Air DC...
My mouse does not work,tried plugging in other mouse and no go. any ideas?
Maybe the port your connecting to is not working properly.Try connecting it to other ports.If you are using PS2 mouse try using USB mouse and connect it to your PC.
May 30, 2011 | Dell OptiPlex SX280 PC Desktop
Mouse not responding
Clean the PC Mouse
1. Unplug the mouse, turn it over, then twist the retaining ring counter clockwise to remove it. Remove the trackball inside the mouse.
2.Clean the trackball with warm water and dry carefully. Clean the rollers inside the mouse with a cotton swab dipped in alcohol. Replace the trackball then secure it with the retaining ring.
3.Clean the outside of the mouse with rubbing alcohol and a cotton ball. Use a small amount on one area at a time. For an optical mouse, clean the bottom of the mouse and the surface it sits on with a damp cloth.
Fix PC Mouse Problems
1.Plug the mouse back in. The connector will either be USB or PS/2. A PS/2 connector is color-coded green and can only be inserted in one direction. Check for any bent or broken pins, then carefully plug it in making sure the connection is secure. Reboot the computer, and then test the mouse.
2.Connect the mouse to another computer. After the mouse is connected to a different computer, reboot the system, and then test the mouse. If your mouse works on another computer, the problem is most likely with your PC or operating system
3.Check for device conflicts. When you install another device on your computer it can sometimes cause conflicts with a PC mouse. Remove any new hardware and drivers you may have installed then reboot the computer.
4.Reinstall PC mouse drivers. In Windows, open "Control Panel" then "System." Select the "Device Driver" tab then scroll to and select your mouse. Uninstall any drivers that are listed. Unplug the mouse then reboot the PC. Reboot the system again, plug the mouse back in, then allow Windows to reinstall the drivers if prompted.
Please rate me if this solution works for you
Thanks......Have a great time.
Aug 19, 2010 | Computers & Internet
The mouse that i am trying to get to work on my acer desktop is a USB port mouse and it will not work. I notice that their is a green circular connection with a mouse icon above it. Do i have to have a...
The green circular connection IS for a standard PS/2 mouse. Your USB mouse should work, however. Make sure it is connected BEFORE you power up and let the PC boot up completely. If the mouse will then not move, either the mouse is faulty or the USB port is disabled. Good Luck, Ian.
Aug 13, 2010 | Acer Aspire m5640 PC Desktop
PC does not respond to mouse or keyboard
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it to Reset/Connect the mouse to the receiver and work properly.
If not, try pressing the receiver button and then press the mouse. This should be done whenever you change batteries or glitch.
Hope this helps you. Bud
Jan 05, 2009 | Computers & Internet
I have an Advent ADE-WLOI1 wireless mouse. Recently moved house and packed up my pc and mouse - now mouse won't work. Tried reset button - no go. My pc is virus infected and am trying to clean it - without...
This seems to be a generic mouse, usb / ps2 connectivity. User needs to press the connect / reset button on the receaver and on mouse. generally.. no drivers or cd required.
mouse has battery.
-check battery
-reconnect (receaver and mouse, if receaver doesn't have button, make sure its connected to pc and power is on, then reset.
try ps2 instead of usb or another usb port, might require adapter. (if im not mistaken it comes with the mouse)
-try another pc
= possibly faulty mouse if still not working? It should work with windows drivers, so no cd required.
Sep 23, 2008 | Computers & Internet
I have a logitech wireless mouse, i don't have the manuel or anything that came with it and i'm trying to connect it to my home desktop computer.. the piece that connects to the computer works the lights...
Click on the connect button on the remote (part connected to the PC) and click on the connect button on the mouse. Move the mouse around after you press that button. It should connect.
Also make sure your batteries are fresh.
Once working, I've found that Microsoft's Intelli mouse driver does a better job then Logitech drivers.
Jul 25, 2008 | Computers & Internet
Micro Innovations PD950P Mouse Logo
80 people viewed this question
Top Micro Innovations Computers & Internet Experts
micky dee
Are you a Micro Innovations Computer and Internet Expert? Answer questions, earn points and help others
