Question about HP ProBook 4310s Notebook
My laptop powers up but the screen is blank. I attached it to an external monitor and it proved that the laptop is functioning with an external screen. Is there a solution to this problem? TB
  • 2,567 Answers
1. Test using an external monitor. If it works, then either the screen bulb or the inverter board might be defective.
2. Test the inverter. Easiest way to do it if you have a good screen with a good bulb. Connect the good screen to the inverter board & test it. If it lights up, then the inverter board is good. If it did not, then the inverter board is bad & needs to be replaced.
3. If the inverter board is good, then we are left with the possibility that the screen bulb is bad. To fix this, we will need to replace the LCD screen.
Posted on Oct 09, 2010
When trying to turn on the screen is blank
Shine a flashlight on the dark screen to see if you barelysee the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can beany kind of monitor even the old big fat crt monitors as long as it has a vgacable to connect to your computer's vga port. If so that proves yourvideo card is ok. The video will show on most systems when you rebootwithout you having to do anything. Some systems will require you to hit the FN(Function key) + F1 thru F12. Hold down the FN key then hit the correctkey for displaying on the monitor (F1 thru F12). The correct key willnormally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,then your screen is bad. If you see no icons by shinning the flash lightand nothing shows on the external monitor, then most likely your video card isbad.
May 24, 2012 | Compaq Presario CQ56110US Laptop
Monitor automatically clicks into power saving mode
Laptops often have a function key which switches from laptop only, external monitor only, laptop & external. One of the top number keys, along with the function (fn for short) must be pressed simultaneously to step through these.
Where these keys are at, may differ from laptop to laptop.
Nov 28, 2007 | LG L1915S 19" LCD Monitor
Blank screen
Did the laptop boot up all the way except the screen is blank? Do you hear fans running and the hard drive spinning, lights on? If you think it booted except the screen is blank try the steps below.
Shine a flashlight on the dark screen to see if you barely see the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If so that proves your video card is ok. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works, then your screen is bad. If you see no icons by shinning the flash light and nothing shows on the external monitor, then most likely your video card is bad.
May 23, 2012 | Computers & Internet
How to enable secondary display adapter fujitsu laptop
You can switch to anexternal monitor or data projector by two methods.1. Connect the externalmonitor to the laptop's video port, power up the external monitor first and thelaptop. The video information will automatically switch to the externalmonitor.2. If you power up thelaptop first then you can switch the video output to the external monitor bypressing the Fn key and one of the Function keys, depending upon your make andmodel laptop. You can also toggle between the external monitor or both LCDscreen plus the external monitor or back to LCD screen only by pressing the Fnkey plus one of the function key. Here is a list of keycombinations for some of the laptops :-IBM ThinkPad = Fn + F7HP and Compaq = Fn + F4Toshiba = Fn + F5Dell = Fn + F8
May 18, 2012 | Fujitsu LifeBook Computers & Internet
Aspire 5110
So does it sound like your laptop is running and booted up all the way except the screen is blank? if so try the steps below:
Apr 08, 2012 | Computers & Internet
Screen is blank (no video), even when connected to to an external monitor. I presume at this point that it's a problem with the on-board graphics processor. Notebook appears to power-up normally. Notebook...
will video work when first booting?? try to start in safe mode then if you have restore disk or applications disk remove the display video in hardware manager, sometimes the drivers get corrupted, thei may re-install video drivers. al so you might go into bios and check for setup defaults hope this works. have had similar situations on diffirerent systems. some laptops have a Fn key Function key so when you have external monitor up to system it switched=s from laptop monitor to external little picture on keys usually on or near function keys.
Dec 29, 2009 | Toshiba Satellite M35X-S311 Notebook
Blank LCD laptop does turn on
I beleave you may need to press the function key as well as the F-4 key to bring up an external monitor.
Try holding down the Function key and tapping the F-4 key while watching the screen on the external monitor.
Is your unit within warranty, HP offer an extended 1 year on top of your normal 1 year warranty for video and motherboard issues.
Hope this has helped.
Sep 27, 2009 | HP Compaq Presario CQ50-210US Notebook
Screen goes blank
My best guess is that it's the screen or the screen sensor try playing with the angle of the screen. If it displays at a particular angle its the sensor if not its the screen, or motherboard. Either way if you pay Dell to fix it, it's like buying a new laptop.
May 14, 2008 | Dell Inspiron 6000 Notebook
Blank screen
1 Blank - absolutly or 2 stuff on the screen but dim and unlit? 1. - tube or inverter gone - workshop job 2 Ditto
May 30, 2007 | Compaq Armada M700 Notebook
HP ProBook 4310s Notebook Logo
562 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
