Question about Stanton C.304
Hi, i have just bought a pair of stanton c304 cd player second hand. One of the players has a problem with the cue button. It is not very responsive. Some times it works and other times it doesnt, if i continually press it, it will eventually work but it is not ideal as you need it to be accurate. Can i get this fixed? How much should it cost? and where can i get it donw? They only cost £200 so dont want to spend much. Could i do it myself?
    Top Expert:
  • Stanton Master
  • 77,499 Answers
The contact pad under the button is defective, in order to get it to work you need to replace the entire assembly.
Posted on Jun 25, 2017
3 Suggested Answers
SOURCE: Stanton C304 Single Top... Problem
i had the same problem on the c303. ended up sending it to FL for fixing. when i got it back it worked fine for a few days then other issues such as not reading disc. unfortunately i could only recommend another manufacturer since this one seems unreliable.
Posted on Oct 13, 2008
petraman7
  • 1175 Answers
SOURCE: my stanton c304 (the cd tray) dont open
HI...
There's usually a motor-driven belt that runs the drawer.
Look for that. Change it if you can.
studiosoundelectronics.com has the belt.
Dust the unit out with some compressed CO2 (dust-off)
Rate my help if you could
Thanks
Posted on Mar 25, 2009
Stanton c304 cd to mp3
Sorry you cant convert it to MP3 the deck only supports CD audio
Feb 04, 2013 | Stanton C.304
One of the CD players will not recognize disk.......will not cue up.....reading is "no disk"
There may be dust inside the unit on the laser. Try shoting some compressed air in the CD drive area to clean out. Also, ensure that the CD surface is clean, and try a different factory made audio CD. Sometimes CD players have problems reading "burned" CD's.
Jun 28, 2010 | Stanton C-503 Dual CD Player CD Player
MY CDJ 1000 KEEPS CUEING ITSELF
Seems that the switch under the Cue button is dirty, or broken.
Regards,
Gerard
Jan 10, 2010 | Pioneer CDJ-1000 CD Player
My stanton c304 (the cd tray) dont open
HI...
Thanks
Mar 25, 2009 | Stanton C.313 CD Player
I have a stanton-vestax cd-11 dual cd player, and was wondering how to get a cd to play on it. I put one in, turned the player on, pushed all the buttons and nothing happened. how does it work?
I have had one of these for many years: Switch it on, you must make sure the two transit screws at the back of each deck are fully unscrewed and loose, let the machine displays settle down, then insert a CD, then press the 'reset' button. There is a built-in delay of about 11 seconds before the deck begins to read. After this the machine should then display the first track number, and pressing the big red button will start play.
Pressing the 'reset' button again stops playback and the CD spins down, but if you leave the CD in there it will eventually re-index and cue up again. This feature is to enable fast, one-button CD changing and it works very well in practice, as the 11 second delay is enough time to take one CD out and get another in there before it tries to read it again.
To stop playback just press the 'reset' button (this is the most used button!) and take out the CD. After the delay, the machine will try to read a CD as normal, but display 'no CD' on the display. There is no stop button, as this unit was designed for continuous use in a club or disco.
Hope this helps. :)
Oct 18, 2008 | Audio Players & Recorders
Aug 22, 2008 | Stanton C304 Single Top Loading CD Player...
C-314 stanton cd player, reads no disc, but disc is in cd player
as with my other posting - all i could do was mail it to be fixed. then it stopped working again so perhaps its time to go elsewhere.
Jul 28, 2008 | Stanton C304 Single Top Loading CD Player...
Stanton c303 cd turntables
the c303 has the same screen and inturnal curcit board as the 304 ans 314. the other two items you are seeing are for the other units. it was a way for stanton to save money by useing the same parts in other table top cd models.
Mar 30, 2008 | Stanton C-303 Single Top Loading CD Player...
Cdj-500ll cue button repair
the faulty button will not stop it from playing well... replacing them is not hard so long as you have some experience with a soldering iron.
Clean the laser lens with a cotton bud wet with windex... then use a dry one to be sure no residue is left. If it still mistracks... new optics required!. You willl need a pioneer service agent to do this for you. A little complex for the first timer :)
Jan 08, 2008 | Pioneer CDJ-500II CD Player
Stanton C.304 buttons
Contact an authorized service center for repairs.
Oct 09, 2007 | Stanton C.304
Stanton C.304 Logo
43 people viewed this question
Top Stanton Audio Players & Recorders Experts
 Grubhead
Grubhead
da surgen
Are you a Stanton Audio Player and Recorder Expert? Answer questions, earn points and help others
