Question about Canon (6981A002AA) for imagerunner 2200, 2800, 3300 Print Server
Error code E00003-0000
What is the fix for error code E00003-0000 on a cannon IR 2200
The film (plastic) film is probably torn from a piece of paper that got jammed between the upper and lower section causing an overtemp lockout condition.
1. Remove left paper door.
2. Remove conector rear plastic(black) and fuser shields(2) screws holding fuser cover shield and unplug (3)connectors,2on the rear and a small one on the front lower right of fuser unit
3. Remove (2) assemlbly mounting screws one at rear and one
on the front sides.
4. remove unit and purchase new complete unit from cannon
5.Installed new fuser by reversing above steps.
Posted on May 30, 2008
Solution to erro e000007 on ir 2420 copier
What is remedy error code E000007-0000 for canon ... - Fixya
www.fixya.com/.../t14373194-remedy_error_code_e000007_0000_can...
Oct 12, 2007 - ... is remedy error code E000007-0000 for canon imageRUNNER2422/2420 ... Copier canon ir 5065 prolems with eror code e 000808-0002.
Imagerunner 2200 error E000007-0000 - CopyTechNet.com
www.copytechnet.com > ... > Copier Technical Discussion > Canon
Mar 15, 2007 - 4 posts - ‎4 authors canon ir 2200. hi, this machine do not have fixing roller. machine have fixing film assembly. this code is for damaged fixing film, on the end you ... Error Code Canon 3025 E000007-0000
Jan 30, 2013
Error Code The dreaded e000007-0001 error code!
Sep 5, 2011
Error Code Color ImageRUNNER 4060i has code ...
Jun 30, 2011
More results from www.copytechnet.com
Nov 05, 2015 | Office Equipment & Supplies
Is cannon ir 2200 the shows me error E000051-0000. How can restore it
clearing error code E000051-0000 in canon IR2200
Try to reset the printer follow this stepTo reset the error
1. Additional functions (push)
2. Function (choice)
3. Error (choice)
4. Error code choice (wait)
5. Reset (push)
6. Right power supply off
7. Right power supply on
Oct 24, 2015 | Cannon Office Equipment & Supplies
Error code e000602
Mounting fault of the HDD.Viring faulty.The main controller PCB faulty.Wiring between connector J1025 of the main controller PCB and the connectorJ 2005 of HDD,or try reinstall the system software,or try to replace HDD and download the system software,or replace the main controller PCB...
Sep 25, 2014 | Canon gpr-6 ir 2200/2800 drum...
How do i clear error e000007-0000 on a canon ir 2200 photocopier
Fixing film assembly may need to be replaced if error cannot be cleared. Fixing error codes should be reset by a professional only. Fuser assembly must be examined before resetting the E000, E001, E003 and E007 codes. Enter the service mode this way: Press "Additional Function" key, Press "2" and "8" simultaneously, press "Additional Function" key again. Go to COPIER----FUNCTIONS-----CLEAR----ERR. Here your tech can reset the error codes. Then turn machine off & on again.
Sep 04, 2014 | Canon Cannon Ir 2022 Photocopier
How to go service mode Cannon ir 400 ?
Here is the error code page http://www.scribd.com/doc/56428927/iR-400-Code-List
And here is the service manual
http://www.scribd.com/doc/135167936/canon-Ir-400-Service-Manual
Looking at what the error is, getting into the service mode will not allow you to fix it; you have some parts to replace first.
Jul 20, 2014 | Cannon Office Equipment & Supplies
Ir3300 e805 error sollution
if cannon ir 2200-3300 shows error E00805-0000 THEN fixing fan is not workig fan is jam oiling d fan then fan is not work change fixing fan.
Jul 15, 2014 | Canon imageRUNNER 3300 All-In-One Laser...
Cannon IR2318 E000019-0002
Please give me advice how to repair E000019-0002 error in IR 2318L. After printing about 20 pages I got that error code. Please reply me.
Mar 22, 2013 | Canon (6981A002AA) for imagerunner 2200,...
My cannon ir 3300 machine show me Error code E 000530-0000 from last 2 days please give me solution for emergency
My cannon ir 2200 machine show me Error code E 000530-0000 from last 2 days please give me solution for emergency
Sep 09, 2010 | Office Equipment & Supplies
Code error of Cannon IR3300 E000006-0000
getfile.asp?rid=1258 November 7, 2002 getfile.asp?rid=3215 Product : IR 2200 / 2800 / 3300 Title : E007 code for the IR 2200 / 2800 / 3300 Problem :
E007 code is occurring for the IR 2200 / 2800 / 3300
Solution :
In Service mode / Copier / Function / Part Check, energize M4 (the Fixing Drive motor). If the Fixing Drive motor does not come on, replace M4 (part number FH6-1848-000). Canon USA, Inc. Systems & Technical Support Division
you access service mode by pressing ADDITIONAL FUNCTIONS-2-8-ADDITIONAL FUNCTIONS
Apr 29, 2009 | Office Equipment & Supplies
Cannon IR 2200
OK i am having the same problem but here is the solution that I have found online that I am going to try in the next 5 minutes:
waste toner container is placed left-rear side of the machine. Take out one screw,small cover will come out then pull out plastic container. Empty the container and clean the head really well as this can cause problems with the fuser.
good luck!
Aug 26, 2008 | Canon imageRUNNER 2200
Computers & Internet Logo
2,878 people viewed this question
Top Canon Computers & Internet Experts
Computer Links
Tony
old marine
old marine
Are you a Canon Computer and Internet Expert? Answer questions, earn points and help others
