Question about Seagate FreeAgent Pro 1TB External USB 2.0/eSATA Hard Drive
My hard disk drive does not respond or show up in My computer when plugged in.Its a seagate 1 tb with those lights in front which usually light up when connected but even that doesnt happen when i plug it into my laptop now.
  • 4,281 Answers
First make sure usb cable connected to harddrive is working fine. try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. Try your harddrive in different computer if it is not recognized on another computer too then your harddrive has internal issue.
Let me know if you need further assistance. Thanks for using FixYa
Posted on Oct 06, 2010
1 TB My Book Live Western Digital, light starts up blue then after trying to discover goes red, tried new eternet cable and still going red. Reset my router and have tried plugging hard drive right into...
I have SeaGate FreeAgent GoFlex 500GB external hard disk and it shows only 230GB. I formatted it many a time but still shows 230 Gb only..Please help me to fix the problem....
Sep 11, 2013 | Western Digital WD My Book Live 1 TB...
I just bought a Dell Back-up plus 1 TB hard disk . when i plug in the USB cable it does not show up on My computer but it shows on "Device manager" and "computer management" .. so i cannot use it as a...
The only thing that I can think of is that you need to go into computer management and click on the "disk management" sub-heading under storage. From there all of the hard drives in the computer should show up. Find the new hard drive in the list and right click on the part where is say Disk 1 or Disk 2 or which ever disk is the correct one (it should be around 930gb or so). Then select initialize disk, and follow the wizard through the choices to setup the disk as a basic hard drive. After the disk is initialized you need to format it and then you should be access the drive in my computer.
Austin
www.we-supply.com
Aug 08, 2013 | Computers & Internet
Seagate 1tb hard disk not recognized
This is a hardware problem but since you can't access to the removable you have to order a new one making sure the warranty of your product is still valid
Aug 05, 2017 | Seagate FreeAgent Pro 1TB External USB...
How to upgrade ST380011A 80GB seagate hard disk to 500GB
First you check your Hard Disk connectivity type SATA or IDE. Then purchase same type of connectivity Hard Disk as your wish. Seagate Desktop internal Hard Disk Available in market (160 GB, 250 GB, 320 GB, 500 GB, 750 GB, 1 TB, 1.5 TB, 2 TB, 3 TB).
Nov 20, 2012 | Seagate Barracuda 7200.7 ST380011A 80 GB...
When i installed my Seagate 1 TB USB 20 Hard Drive to my computer it worked. But when i plug it in to my other computer nothing shows or comes up. Why is that?
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
Aug 28, 2011 | Seagate (ST310005EXA101RK) 1 TB USB 20...
My seagate HDD 1 tb, does not show any drive in my computer
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seated
if this fails to fix the problem
hope this helps
Aug 20, 2011 | Seagate (ST310005EXA101RK) 1 TB USB 20...
Have a 1.5. TB "Sea gate Free Agent - Desk". Used
if your computer came with a motherboard disk the drivers could be on it
hope this helps
Jun 28, 2011 | Seagate FreeAgent Pro 1TB External USB...
Wont reconize
Probably not the right answer for your problem. Mine is an external 1 TB Simple Drive. Mine wouldn't respond at all. I unplugged the power cable from the back of the hard drive and replugged it in and instantly it worked (with the computer and hard drive plugged in). I had tried rebooting the computer, plugging/unplugging over and over into the computer and that didn't work.
Jun 17, 2010 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Lights on nobody home
Well if it is less than 2 or 3 years old you could contact them to attempt a sawp out of the drive. Over that - replace the unit. IF you do - you might want to consider a duel disk enclosure so if a drive dies, your data does not. you can build one yourself (1 TB duel drives, Raid 1) for a total of 252 bucks, with good drives (Seagate - Barracuda) Yes I swear by the Seagate Drive. For off teh shelf they have worked very well in every application I have deployed them.
I've been burned by too many single drive failures - even when I have the data backed up it is still a royal pain.
Jan 25, 2010 | LaCie Big Disk Extreme with Triple...
Seagate FreeAgent Pro 1TB External USB 2.0/eSATA Hard Drive Logo
435 people viewed this question
Top Seagate Computers & Internet Experts
Computer Links
Steve
terminalcon
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
