Question about Samsung SC-D353 Mini DV Digital Camcorder
Tape keeps ejecting
Every time I put a tape in, the display says "no tape" and ejects it. I need the machine to work tonight. I've been able to temporarily fix the problem by cleaning out the inside with compressed air.
PLEASE help me. My daughter's concert is tonight, and her future stepfather is out of town,
-elizabeth ebushey@gmail.como
  • ladyqueen77 Jun 15, 2008
    yup I'm having the same problem also.... when I put a new tape in it's telling me NO TAPE and it wont record, rewine or fast forward .
    can someone please help me
    Thanks.
  • Walt_Felix Apr 21, 2009
    I have the same problem. I've discovered if I take the tape out, set it on a table print side down so you can see the underside of the reels. It'll kind of look like a little smiley face. There is a little white square on the center of the tape, towards the far edge where the label attaches. That is the lock for the reels. Using the tip of a pen, push the lock away from you to unlock the reels. Then, while holding the lock, take a pencil with an eraser with you other hand and gently insert the eraser in the right reel and give it a turn or two counter clockwise to forward the tape slightly. Put the tape back in the camcorder and try it again. Seems to me the rewind function rolls the tape back to far and the camera is not able to index it correctly.
    Habit-Forming:
  • 27 Answers
Has anyone find a solution? if so please post it,thanks.
Posted on Jun 15, 2008
Cannot play a VHS tape. Push in and pops out.
The belt on the loader motor is slipping. This causes the tape to not completely position itself to allow the tape to load around the drum. The machine senses this and ejects the tape.
Feb 20, 2014 | Samsung DVD-VR375 DVD Recorder/VCR
I have a brand new tape adapter (for my iPod) that was working for weeks, but after I ejected it, it just keeps ejecting itself right when I try to put it back in. It will play just a tiny bit of the...
You might try flipping the adapter over the other way. If that doesn't work, you might want to try putting a cleaning tape in and clean the cassette heads. The tape player will sometimes eject a tape if it cannot read it very well. It assumes that the tape is damaged. Dirt on your heads can cause it to eject your adapter because it is having trouble reading the signal from the adapter.
Aug 22, 2011 | 1996 Chrysler Concorde
Sony DCR-HC28E Camcorder tape won't eject
I\'ve got a Sony DCR-HC28E Camcorder power switch off position but it's turn on automatic when I put power AC adaptor in DC inlet and battery not charg
Dec 29, 2009 | Sony DCR-HC28E Camcorder
I have a Sylvania 6240VE vcr. When I try to rewind a recorded tape, the vcr ejects the video. I was wanting to purchase a dvd/vcr combo, but the reviews for these items are awful. I tried a Magnavox combo....
When you put the player into rewind, is it at the beginning of the tape that it ejects? If so, it may be because you have the machine in timer mode. If you have a pre-recorded tape in a VCR, it will automatically eject the tape because you`ve not to record on a pre-recorded tape. I hope this help, Ian
Jul 23, 2009 | Sylvania 6240VE VHS/S-VHS playback VCR
SONY VCR: Keeps ejecting video tape
When putting in a video the VCR has a tendency eject the tape and then shuts off. Then there are times it works fine. What seems to be the problem?
Apr 07, 2009 | Panasonic DOLBY DIG. 850w HOME THEATER...
Will not display picture or eject tape.
most of no signal means dsr 11 or similar machines have dirty heads. When they get dirt sometimes, you can´t play a cassette and the machine turns off (with the cassette in).
I´ve tried several times to reload the cassette and I manage to make it work again.
with the cassette in and the machine off press at the same time power and fast forward.
When in fast forward press play and your head should be starting to be clean (takes 4 o 5 minutes
to get a clean picture). Normally the machine gives a code error like if it was a loading problem but
not nearly related
Mar 13, 2009 | Panasonic Televison & Video
Tape keeps getting ejected
This unit requires the rubber parts to be replaced. The loading sequence is not completing properly. The VCR will eject the tape when the sequence fails as a safety measure to prevent damage to either the VCR or the tape.
Parts cost for this should not be more than $10.
Dan
Feb 03, 2009 | RCA VR639HF VHS VCR
VCR tape loads and runs about 5-10 sec; then ejects
you need to clean the vcr with a cleaner that you can buy at a store. If that doesnt work then you need to take the 4 or 5 skrews out that hold the top on and look at the motor and gears move while you put a tape in and you should spot the problem pretty quick. It'll be with the round metal wheel that turns the tape.
Jan 02, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
VCR keeps ejecting the tape
It needs Belts/Idler/Pinch roller.. If you UNPLUG IT, remove the cover you can wind the tape back manually....When you can get a DVD player.
Sep 28, 2008 | Sony SLV-N750 VHS/S-VHS playback VCR
Samsung SC-D353 Mini DV Digital Camcorder Logo
278 people viewed this question
Top Samsung Video Cameras Experts
Tony
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
