Question about Compaq Presario Notebook
#100008 Replace hard Disk 1 - Compaq Presario Notebook
  • 165 Answers
Give it to a authorised service centre
Posted on Oct 06, 2010
Setup disk
Hi
You need to:
1. Create recovery disk (link)
2. Replace the hard drive
3. Restore using the disk created (link)
Regards.
Oct 20, 2013 | Gateway NV57H94u Core i5-2450M Dual-Core...
Erase hard drive hp1055
In service test menu scroll to "3.Hard disc drive", & press enter, if test drive passed don't replace the hard disc or modification or changes. If test failed then check as shown below:
1 Switch the printer OFF. Remove the EIO Card (if installed) and re-install the Hard Disk Drive making sure it installed correctly by pushing it firmly inwards and checking that the two installation screws are completely tightened. Switch the printer ON again and repeat the Hard Disk Drive Test. If the Hard Disk Drive Test fails again then replace the Hard Disk Drive.
2 If the Hard Disk Drive Test passed after removing the EIO Card,then switch the Printer OFF and reinstall the EIO Card, making sure that the two installation screws are completely tightened.
Switch the Printer ON again and repeat the Hard Disk Drive Test. If the Hard Disk Drive Test fails, then the EIO Card could be faulty.Replace the EIO Card.
3 If the Hard Disk Drive Test continues to fail after replacing the EIO card or the Hard Disk Drive, then replace the Electronics Module..
I am having little knowledge, if I am wrong Pl don't comment, pl forgive me.
May 20, 2013 | HP DesignJet 1055cm InkJet Printer
How to upgrade ST380011A 80GB seagate hard disk to 500GB
First you check your Hard Disk connectivity type SATA or IDE. Then purchase same type of connectivity Hard Disk as your wish. Seagate Desktop internal Hard Disk Available in market (160 GB, 250 GB, 320 GB, 500 GB, 750 GB, 1 TB, 1.5 TB, 2 TB, 3 TB).
Nov 20, 2012 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Bios cannot detect hard drive suddenly. I was running the PC well. Trying to start the PC again, cannot go into windows. Check on the bios, no hard drive detect.
Follow the steps given below.
1) First, check your hard disk cable, I recommend you to replace the Hard Disk Cable.
2) If the BIOS doesn't detect your Hard Disk after replacing Hard Disk cable try upgrading your BIOS from the Dell website.
Jul 06, 2011 | Dell Studio Xps 9100 Desktop Computer
During a hard disk test, it stopped and said to replace hard disk 1
Which tools are you using? Does it give any other information such as bad sector on hard disk? You can also check the log to see whether some details are there. If bad sector, you may need to replace the disk or fix the sector by flagging it. But it is safer to replace it because it might be the reader so it will keep breaking the surface of the hard disk.
Apr 23, 2011 | Computers & Internet
My hp laptop says replac hard disk 1 and will not
There seem to be a problem with your hard disc, that is why it is saying replace hard disk 1.
It either is because the connection of the hard disk is loose or the hard sick is faulty.
All you have to do is to unscrew the compartments below, You will have direct access to the Hard disk. Take note of the cable to see if it is loose, if it is, just adjust it.
And if it is not loose, disconnect it from the board and reinstall it back.
Then turn it on again. If it does the same, then the hard disk is faulty and needs replacement.
Replace the hard disk and it will be in good condition again.
Take care
Jun 23, 2010 | HP Pavilion dv4000 Notebook
Howvto replace hard T-1616
1ºst is the Hard Drive making funny noise?, like Scrathing? Has the Bios dont Detect? It´s very hot in Hard Disk? If not. you have a serious Virus Problem, instaled in the Bios Hard Disk. Just Low Level Disk format, and use the Hard Disk Utils for HardDisk Company. 90% of Hard Disk Problems is Virus Problems
Nov 21, 2009 | Gateway Computers & Internet
Getting error code 04C300 00310000
Hi;
if you HP 1050C Plus display System Error 04CXX Try the following Steps to resolved an error:
1.)Press ENTER and switch the printer OFF. Remove the Hard Disk Drive (if installed) and make sure that the EIO card is installed
ON again. If this error code continues to appear then replace the EIO card.
2.)If this Error Code disappeared after removing the Hard Disk Drive, then switch the Printer OFF and reinstall the Hard Disk Drive, making sure that the two installation screws are completely tightened. Switch the Printer ON again. If this Error Code reappears, then the Hard Disk Drive could be faulty.
Replace the Hard Disk Drive.
3.)If this system error continues to appear after replacing the EIO card or the Hard Disk Drive, then replace the Electronics Module...
May 26, 2009 | HP DesignJet 1050c InkJet Printer
I have asus m2n-e board, i used 80 gb hard drive in sata 1 socket, used 4 hard disk of 250GB in from 2-5 ports and used 320 gb hard disk in port 6, configured 4 250gb hard disks in raid 5 using the mother...
USE DIFFERENT PORT FOR PROBLEM OCCURED HARD DRIVE AND CHECK SAME PROBLEM CONING TO THAT PORT ALSO .THEN THE PROBLEM IS WITH YOUR HARD DRIVE .REPLACE IT.
Dec 31, 2008 | ASUS M2N-E Motherboard
Compaq Presario Notebook Logo
454 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
