How do you empty the toner waste bin on samsung CLX-3170 series
SOURCE: MESSAGE REPLACE/ INSTALL TONER WASTE TANK EVEN THOGHT I HAVE REPLACE IT ON A SAMSUNG CLX-3160 FN
When this happened, I took the tank out and shook it out into a garbage can (do this outside and be very careful not to breathe the dust). I then took a shop vac and held the hose at the opening while blowing compressed air into the tank. Wiggle the air nozzle around and you'll get out 99% of the toner. Pay extra attention to the sensor optics (plastic bulges on the sides of the tank).These need to be clean since the printer knows when the tank is full because the toner blocks light shining from one side of the tank to the other
Reinstall the tank and be sure it is fully inserted. If they printer is still on, turn it OFF. Close the front door of the machine and turn it back on.
Continue printing.
Posted on Jun 15, 2009
  • 670 Answers
SOURCE: CLX 3160 waste toner tank error message
Empting the waste toner tank does not always fix this problem. Samsung shines a light through the tank with a photo receptor on the other side. If it the photo receptor does not see enough light, it will trigger the replace waste tank message.
You can fix this by trying to clean the clear window portion of the tank with a q-tip. This is difficult to do since there are parts of this window which is hard to clean with a q-tip.
Or you could wash it out with soapy water until the window is clear of toner. Allow the tank to dry and reinstall.
Posted on Jan 19, 2010
rtrahan
  • 741 Answers
SOURCE: Samsung CLX 3170 scanner locked
Many scanners contain a scanning head lock to keep the scanning head from moving during shipping. This may still be still be in the lock position. All scanners are different but check the documentation on how to remove the head lock.
Posted on Dec 25, 2008
SOURCE: replace waste toner container message
I have a CLX-2160N and have just emptied my own waste toner container. (Disclaimer: not sure how toxic or environmentally friendly this is).
Emptied carefully and thoroughly (fine dust). Immersed in bowl of warm soapy water, and vigorous shaking to get nice and clean.
Shook all water out well, and dried off as much as possible. Reinstalled. Turned printer back on. Hey presto - seems happy.
Posted on Apr 17, 2009
Get rid of the error message "toner empty stop" after replacing the cartridge with a new Samsung cartridge?
After replacement with OEM cartridge it will never show Toner empty
however refil cartrdige will show the same , You need to replace the chip to remove the empty indication
Oct 01, 2014 | Samsung Office Equipment & Supplies
Replace the wast toner for the samsung clx3175
My Samsung CLX-3175 printer will not print - the message is replace/install toner waste bin. I have emptied the waste bin of all the ink and still the message will not go. I have a stack of work to do and am stuck as to what to do next! Help please
Apr 01, 2014 | Samsung CLX-3175FN Color Laser All-in-One...
Samsung 3170 reset imaging unit
The drum fills up with waste toner and you can empty it but its messy and you need to clean everything carefully after taking it apart. Take out the imaging unit, unloosen the screws on both sides, unmount the retainer springs and push the center pin out of the drum. Take out the drum and unscrew the two screws that were hidden behind the drum. Now take away all parts so that you can empty the waste drum container. Clean everything especially the light emitting panel, drum and white plastic cover needs to be clean. Hope this helps.
Feb 15, 2012 | Samsung CLX-3170FN All-In-One Laser...
The wast toner bin on the clx.3175 needs to be replace how do i remove the bin out the printer
Open door where toner cartridges are. On left side of cartridges below the Colour Letters is a small black handle. Just pull the handle and the bin comes out. You can't simply empty the bin and re-use, you need to order a new one from Samsung. Only costs $25 and just push in. Very easy, just need to wait for part to be ordered in and then collect it, which took me a week.
May 16, 2011 | Samsung CLX-3175FN Color Laser All-in-One...
My Samsung CLX-3175 printer will not print - the message is replace/install toner waste bin. I have emptied the waste bin of all the ink and replaced it and still the message will not go. I have a stack...
open the cover and now remove the waist toner container (you say it is empty) check the conection to the drum unit sometimes if the waist toner is verry full there is a pille of toner closing this connection, now clean it and all the sorounding from the toner and mount the waist container back in his possition, close the front cover and try, it should work now.
Apr 27, 2011 | Samsung CLX-3175FN Color Laser All-in-One...
I have emptied the toner waste bin and the message still jkeeps coming up>
The Toner waste bin should be made transparent enogh to pass the light to detect the sensors.
Even after cleaning the waste toner waste bin if thie MFP shows the error you may clear the memory by calling samsung service center, or an alternate the service center may help you for further assistance
Oct 12, 2010 | Samsung CLX-3175FW Multifunction Laser...
How to solve the problom of 'install/replace toner waste bin'?
Laser printers "print" by throwing toner onto a electrostatically-charged drum. The ink that sticks is then heated, and melts into the paper. The ink that does not stick falls into the "waste-bin".
Eventually, that waste-bin gets full, and needs to be removed, and emptied.
Aug 24, 2010 | Samsung CLX-3175FN Color Laser All-in-One...
Are the toner waste bins on this printer 1 time use?
can be reused first carefully empty it. and may wash and dry with normal water. While you empty cover your nose suitably the toner is a harmful.
Mar 31, 2010 | Samsung CLX-3175FN Color Laser All-in-One...
Samsung clx-2160 says waste tank is full. What must I do and where is the waste tank?
If you open the front of the printer then you will find a waste tank in the left side - its gray. Take it out and empty it, and put the tank back in place.
This works for Samsung CLX-2160
Jan 31, 2010 | Samsung CLX-2160N All-In-One Printer
1,112 people viewed this question
k24674
