Question about Sony Ericsson W700i Cellular Phone
While down loading net setting authentication failed appears ?
While downloadig GPRS settings from vodafone live on my phone sony ericson w700i,it shows authentication failed,connection discarded
Posted on Dec 31, 2010
Tip
I cannot access my Verizon mail _ Verizon.net server responded: Authentication...
Hi.
The following tip applies to users that want to access Verizon mail using an e-mail managing software as for example Outlook, Outlook Express, Eudora and similar.
The checkup procedure and server settings can also be used to setup your verizon email on a mobile or on a PDA.
If the Verizon server responded: Authentication failed, that means that either your ID, or your password had not been recognized.
Ensure that Caps Lock is not on.
ID and password are case sensitive, ensure that you use capitals only if needed.
Ensure that you entered the right user ID and password for your mail.
The ID must be your Verizon email address, or the first part of the Verizon email address (before @ sign). Password must be your Verizon email password.
If for example the address is MyMail@verizon.net , then try first putting id MyMail@verizon.net , if that does not work, try again with MyMail as ID.
The format that is supposed to work on Verizon is MyMail@verizon.net.
Ensure that the server settings you are using are correct:
1. Incoming mail server (POP3) - incoming.verizon.net.
2. Outgoing mail server (SMTP) - outgoing.verizon.net.
Ensure that you have not set the Log on using Secure Password Authentication (SPA)
Ensure that ports are POP3 PORT: 110. SMTP PORT: 25
Turn off any active firewall or security software. Also ensure that your router is not blocking port 110 (for POP server) or port 25 (for SMTP).
If all that does not work, then there may be an issue that depends on Verizon server. Also try calling Verizon online to find out if there is any additional issue that can affect your account.
Regards.
on Mar 12, 2010 | Microsoft Office Outlook 2007 for PC
Google will not help me reset my password on my Gmail account because my answers were apparently wrong how can I access this without their help
Not sure if there is anything else you can do if you are not able to follow the security authentication process.
The process is well defined in their website. In your case it appears you were unable to authenticate with either an alternate email address or the mobile phone and hence the need to have verification questions.
If you failed on all of these then unfortunately you may have to create a new account and make sure you note down all the details when you are setting up. These days it is important for service providers like google to ensure their systems are not being violated by unauthorised users. Account recovery options
Aug 15, 2014 | Computers & Internet
Need apn settings for at&t straight talk Samsung galaxy discover.model sgh730g at&t4.0.1.1 when first got phone it showed. 4g.phone it blacked out called straight talk they had me changed the apn settings...
Straight Talk AT&T APN Name ATT 4G LTE APN tfdata Proxy proxy.mobile.att.net Port Username Password Server MMSC http://mmsc.mobile.att.net MMS Proxy proxy.mobile.att.net MMS Port MCC MNC Authentication Type PAP APN Type default,mms,supl,hipri APN Protocol IPv4
Sep 11, 2017 | Cell Phones
"Packet Data Authentication Failed" what is
The error msg "packet data authentication failed" is displayed when connecting to internet via cell phone, even after having the original configuration settings provided by the supplier set to default. The problem can be solved by the following method or else contact the service provider. >Delete the old settings and then by switch off the phone. >Remove the sim card and reinsert it, after some time >gett the new settings and set it to default. Hope this helps. I had the same prblem. Even after calling cc, nothing helped. I tried all things but failed. Then unfortunately, i entered the url of the sp in the access point setting manually and wow it worked. I did this by using uninor.
Jun 17, 2011 | Nokia 2626 Mobile Phone
The message could not be sent because the server rejected the sender's e-mail address. The sender's e-mail address was 'fkb@ameritech.net'. Subject '', Account: 'pop.attyahoo.com', Server:...
One problem is that the incoming (POP) mail server shown in the error message appears to be incorrect. The server address should be "pop.att.yahoo.com" (with a period between "att" and "yahoo"). The incorrect mail server address may interfere with authentication of the sender's email address, which is needed before the outgoing message is sent.
The "530 authentication" message indicates your outgoing (SMTP) server likely requires "server authentication". Also, the "Port 25" message indicates your email program is currently trying to send via Port 25, with no SSL; but Ameritech/Yahoo accounts appears to use Port 465 with SSL enabled.
See more on sever settings for "ameritech.net" users:
http://www.dslreports.com/faq/5535
https://motorola-global-portal.custhelp.com/app/answers/detail/a_id/61941/~/i886---at%26t,-bellsouth,-sbcglobal,-ameritech-email-settings
I would suggest you check the settings for your Ameritech email account in your email program. You may need to correct several settings. The steps to access account settings are somewhat different for various email programs (Outlook, Windows Live Mail, Thunderbird, etc.). You should be able to find guidance in the "help" section of your email program.
Feb 05, 2011 | Outdoor Concepts OCI AD20 27 Stainless...
What is the wifi password and how to solve this problem authentication failed when i use wifi in corby wifi
WiFi password is not set by your phone. It's dependent on the device called router that allows you to connect your phone to the internet cloud.If it's on a public network or WiFi hot-spot usually it doesn't have a password, but if it does, you may need to ask a personnel from the establishment where you are currently staying. Same goes if you're connecting to a university or a coffee shop, better ask the password from the personnel available.
Moving forward, the "authentication failed " usually appears when you're not able to provide the correct passkey, or network password
Jan 11, 2011 | Samsung S3650 Corby / S3650 Genio Touch...
LDAP issues with Konica C451
5 Network settings
5-52 bizhub C650/C550/C451 (FE3)
Setting up LDAP
Register LDAP servers and specify authentication settings. Settings can be specified for the following.
Setup LDAP screen 1/6
Setup LDAP screen 2/6
Setup LDAP screen 3/6
Setup LDAP screen 4/6
Parameter Description
LDAP Server Name Type in the name of the LDAP server to be registered.
Use the keyboard that appeared in the touch panel to type in the server name (32
characters or less).
Max. Search Results Specify the maximum number of destinations to be displayed after a search. To
change the setting, press the [C] (clear) key, and then use the keypad to type in
the desired setting. (Range: 5 to 1000)
Timeout Specify the maximum wait time for a search operation. To change the setting,
press the [C] (clear) key, and then use the keypad to type in the desired setting.
(Range: 5 to 300 seconds)
Initial Setting for Search Details Specify the initial search conditions for "Name", "E-Mail", "Fax Number", "Last
Name", "First Name", "City", "Company Name" and "Department" in an advanced
search.
Server Address Specify the address of the LDAP server. Use the keyboard that appears in the
touch panel to type in the address (255 characters or less).
Search Base Specify the search starting point in a hierarchical structure arranged on the LDAP
server. Searches are performed by also including the sub-directories lower than
the starting point that was specified.
Use the keyboard that appears in the touch panel to type in the address (up to 255
characters).
SSL Setting Select whether or not SSL (data encryption) is used when connecting to an LDAP
server.
When SSL is used, communication information is encrypted.
Port Number Specify the port number for the LDAP server. To change the setting, press the [C]
(clear) key, and then use the keypad to type in the desired port number. (Range: 1
to 65535)
Port Number (SSL) Specify the port number when SSL is used. To change the setting, press the [C]
to 65535)
Authentication Type Select the authentication method used for logging on to the LDAP server.
Anonymous: This authentication method does not require a user name and password.
If "Anonymous" is selected, dynamic authentication is disabled.
Simple: This simple authentication method requires a user name and password.
Be careful since the passwords can be leaked over the network.
Digest-MD5: This authentication method can be used on a typical LDAP server. If
authentication fails using Digest- MD5, the authentication is performed by automatically
switching to CRAM-MD5.
GSS-SPNEGO: This authentication method can be used with Active Directory in
Windows (Kerberos authentication).
NTLM v1 and NTLM v2: These standard user authentication methods can be used
with Windows NT.
They can be used for logging on when sharing files and printers.
bizhub C650/C550/C451 (FE3) 5-53
Aug 14, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Skype on LGkf310
make sure the date/time on you phone are set correctly. I had the same problem with mine and works now
Oct 11, 2008 | LG KF310 Cellular Phone
Sony Ericsson W700i Cellular Phone Logo
300 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
