Question about Western Digital 500GB My Book World Edition 500 GB Hard Drive
How do I change my WD5000G032-001 external hard drive's IP address?
    Brigadier General:
  • 10,406 Answers
Very few external disk-drives _have_ an IP-address (the Apple Time-Machine is the exception). For those drives that do,
they obtain their IP-address automatically, by sending a 'request' out through their network-connection. A DHCP ('Dynamic Host Configuration Protocol') server on the network sends an IP-address to it. Most 'home' routers (wired or wireless) include the DHCP-server functionality.
So, the only way to change the IP-address is to configure the DHCP-server to always assign the desired IP-address whenever that specific device sends a 'request' for an IP-address.
Posted on Oct 06, 2010
What is the IP address for my Firestick?
The IP address of an item, unless you specifically assign it one, is done automatically by the router when it connects to the network. This address can be different each time the device connects depending upon what other devices are already connected.
Jan 02, 2016 | Computers & Internet
Lost login info, what should we do?
You are talking about accessing a Hard Drive via IP Network Address. Very difficult to troubleshoot via this method as the Network protocol interfears. Try plugging the drive in via USB or FireWire etc.
On A hardwired port it is easier to access the drive & copy it's contents to a backup device before formatting & testing the drive and adjusting the IP address to you preferred settings.
The drive can also (probably) be taken out of it's case box and plugged into another case with a USB port on the back or directly into it's ATA or SATA port on the actual drive. This is the preferred way to back up as it's much faster than Network or USB access for large file transfers. You can buy external empty cases. eg. See OWC. Other World Computing website.
Oct 17, 2014 | Toshiba Canvio Computers & Internet
Can someone show me how to change my Dell lattitude e5520 ip address?
Your IP address is assigned by your network system.
If you have a conflict with your IP, you can try a ipconfig /release or ipconfig /renew.
At the command prompt type
ipconfig /? for all available switches.
If you are using a cable modem, you would want to reset to factory first.
May 03, 2014 | Office Equipment & Supplies
How do i change my ip adress on netbook
First you can find your internal ip address of your netbook by using these following steps
Goto START> RUN> Type CMD> Command prompt open here Type " ipconfig/all "
You can change your internal ip address
Again go to command prompt
  1. Type "ipconfig /release" (without the quotes, on the command line by itself).
  2. Type "ipconfig /renew" (without the quotes, on the command line by itself).
If you want to know your external ip address Just visit the site Ip-Details.com
your external ip address assign by your internet service provider. if you want to change this do the following procedure
  1. Log into the router's admin console. (Often http://192.168.1.1/)
  2. Release the IP address. (Method varies by router manufacturer)
  3. Turn off router, ethernet hubs/switches, and the cable/DSL modem.
  4. Leave off overnight.
  5. Turn everything back on.
Jul 04, 2012 | Computers & Internet
There is power to the external hard drive but not booting up
It is possible that the IP address is lost in the unit. Or, the drive could be bad (connection to the drive inside the enclosure.) Call techrx. http://techrxgb.com and I can help you get it resolved.
Jul 16, 2010 | Western Digital My Book Essential Edition...
We forget the ip address for the MGMT port, we changed the default one
use arp .
find the mac address and then use arp to assign an ip address to the mac address . the you can enter the web front end using the ip address you assigned to the routers mac address and then find out or change your ip address. might not be any use to you
Mar 03, 2010 | IBM System Storage DS3400 Dual Controller...
Can't find the IP address of the Maxtor Shared storeage II drive.
Download and install Wireshark(www.wireshark.org) on your PC. Attach the storage box and your PC and nothing else to a switch. Start a capture and you'll start to see all of the packets that your PC sees on its network interface. They will include a column for source address. The one that doesn't match your PC has to be the storage box.
If this doesn't help, connect the two devices directly together(you'll need a crossover cable if your PC NIC doesn't support MDIX and try the Wireshark capture again - this WILL work. The first option is dependent on the storage box sending out some sort of broadcast packets which is likely but not certain.
Jul 18, 2009 | Maxtor Shared Storage II 2TB Network...
Stored static ip address in nas server and cant
I have a similar problem. There is a reset pinhole switch just beneath where the Ethernet port is that if you push it is supposed to reset the drives name and switch it to DHCP. You can see this in the manual. Unfortunately, this hasn't worked for me and I'm working through another solution to see if I can find the IP it is attached to.
Apr 21, 2009 | Maxtor Shared Storage II 2TB Network...
I can not link up with My Book World Edition 500GB
That is because the MyBook is set with a default IP address of 192.168.1.257. You will have to put a static IP address in that subnet range in order to be able to see the external drive. Hope this helps....
Dec 13, 2008 | Western Digital 500GB My Book World...
Setting up a network drive to router
I have never actually set one up, but I have done printer servers & lots of other devices, so I imagine this will be the same.. The Brand & model should give you a default IP. Usually you can change that after installation. So look at the device, go to the vendors website or if you have documentation, it will tell you there. Or tell me the brand & model, so I can find the IP for you. With these kinds of posts, you need to provide as much information as possible. Worst case, there is various software solutions (for networking) that can discover the device. But thats the hard way in this case. Let me know how you go..
May 10, 2008 | Computers & Internet
Western Digital 500GB My Book World Edition 500 GB Hard Drive Logo
1,965 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
