My router works fine for a while then green lights go and i get red lights on 1 2 and 3 and loose connection.
  • 734 Answers
I hate giving bad news, but your router is damaged and probably no one will tell you for a while because they won't have placed a bid on the answer to your problem. If your router is still under warranty, have it replaced immediately. If it is not, get a new router, immediately.
I wish it wasn't that simple, but it is.
With kind-hearted regards,
TheSelkie
Posted on Oct 06, 2010
I have a D-link DSL-2750U router worked fine till yesterday, but now its power led keeps on giving a red light it should give green a second or two later but it keeps givings
Reset router. There are two resets. A simple push reboots and holding it in clears all custom settings. Try the first.
This is a quick fix and usually does it. Test with network cable and work your way backwards to modem if you still have problems.
Nov 11, 2012 | Computers & Internet
UNABLE TO CONNECT WITH MY LAP TOP ON INTERNET HAVE FOUR LIGHTS ON AND FIFTH ONE FLASHING JUST STARTED YESTERDAY.
So that means its working well and connected to the ISP' server. What is your connection? Is it ADSL?
First make sure that all light have the color of green. If they are Flashing with color RED that means the property associated with the light is having a failure.
Here are the description of Colors and Lights.
Modem Light state: Unlit Flashing Red Flashing Green Steady Green
Cases:::
Power Light
Modem is not getting power - no light Modem has failed POST - Red Power is on - Steady Green
Ethernet (2nd Light)
No Ethernet link detected - No light Problem with ethernet port or cable - Flashing Green Modem has detected a successful link to a PC or router - Steady Green
DSL (3rd light)
ADSL sync signal is not detected - Red Modem is trying to synchronize. - Flashing Green Modem has ADSL sync and is ready for PPPoE session traffic - Steady Green.
Internet (4th light)
Modem has given up or isn't configured to initiate the PPPoE session - No Light PPPoE initiation has failed or PPPoE has been terminated. - Red Initiating a PPPoE session to Internet - Flashing Green. Modem is ready for Internet traffic - Steady Green.
Note: This light sometimes not working even if the connection initiated.
Activity
Normal DSL traffic flow - Flashing Green. Steady traffic flow - Steady Green.
Solving problems.
Case1: You have to connect your machine to the Modem Via the Network cable. Plug the other side of the cable to your Machine. (Not the modem port. Network card port.). Case2: You have to make sure that you have installed the Network Card drives. To check that you have to use Device Manager. Follow these steps. Hit Windows key with R In the "Run" box type devmgmt.msc In the right hand side check whether the network card is installed. If it has a yellow exclamation mark or a mark with red that means you haven't either installed or its having a device/driver problem.
Case3: If its fine then what you have to do is to check your network settings. Heres how: Since you haven't specified the Operating System I m including the Windows XP method here. Not much difference in other Operating Systems as well.
  • Get the Control Panel.
  • Go to Network and Internet Connections.
  • Go to Network Connections.
  • Check the Local Area Connection.
  • Right Click and check "Status".
  • If it says connected
  • Check the Duration and Speed(100 or 1000Mbps).
  • If the settings are fine go to "Support" Tab.
  • Check whether the Machine has received an IP Address. Which is often in the range of 192.168.254.xxx for Siemens Modems/Routers.
  • If you see an IP Address which starts from 169.xxx.xxx.xxx your network card was unable to pick an IP Address from the DHCP router which runs in the modem. (If you run a DHCP in the machine you have to configure to stop leasing IP Addresses to your machine from the Router/Modem. You can try the "Repair" button below and it will try to Release and Renew your IP. If it fail either you have a problem with your network card or Modem/Router (Could be the cable also).
  • If you still see the IP Address which starts with 192.168 the connection with your Modem is fine.
  • Next: Right Click on the Local Area Connection again.
  • Go to "Properties".
  • Double Click on "Internet Protocol (TCP/IP).
  • Check the settings.
  • The settings should be "Obtain IP Addresses Automatically" and "Obtain DNS Server Address Automatically". (But if you know the router's/Modem's IP Address you can configure it and you can give a "Static IP" to your PC as well. It must not be the Router's / Modem's IP and must be in th SAME SUBNET. If router uses 192.168.254.xxx you can assign it as 192.168.254.2)
  • Then Apply the Settings and go to the "Status" again and then click on "Details".
  • Except Wins Server all others must be populated with values in 192.168 range. Check the "Default Gateway" Setting. Its very important that you have pointed the machines Default Gateway to the Router/Modem.
  • Final Check:
  • Go to the "Internet Protocol (TCP/IP) again and click on "Advanced".
  • Check IP Settings (first tab) too make sure DHCP is enabled on you machine.
  • Go to "Options" tab and Check TCP/IP Filtering. Click on properties and make sure that the Filtering is not enabled. If it enabled make sure your network adapter Permits all routers traffic in to the machine.
By following these options will let you surf the internet.
Check for the behaviors of indicators as well.
Case 3 :Browser settings
In the Internet Explorer go to: Tools -> Internet Options ->Connections -> LAN Settings -> Its fine if any box is not checked. Or you can check the "Automatic Detection".
Last thing is If you have a Firewall or Antivirus Suite Please make sure that you are not blocking adapters and traffic/application. You can try to disable Windows Firewall and check whether it works as well.
Hope this will solve your issue. Please be kind enough to rate the answer with a comment (testimonial) if this helps you to overcome the issue. Feel free to contact us further. Thanks for contacting Fixya
Jun 05, 2010 | Siemens SpeedStream Modem (4100) (SS4100)
Linksys router will not connect with motorola 2210 modem
Your problem may be timing.
Make sure you have all your cables connected correctly.
Do not have power to either the modem or router.
Plug in you modem and watch the lights go to work. Wait for them to settle down. Now plug in your router, again watching the lights. It should work now.
You can download Linksys' LELA program to monitor the network. Shows green lines to your computers, etc. when working and red lines when not. It will also give your status and make suggestions if you loose your connection.
Good Luck
Feb 24, 2010 | Linksys Wireless-G WRT54G Router
Computor doesnt connect to internet states a local network cable is unplugged 4 green lights on routerand one red light turn off all power and unplugged cable also reset button but no internet connection...
If the red light is your DSL light it means you have a line fault or no internet connection. Contact your provider
If the red light is your broadband / internet light - it means you are not logged on properly. Chck your username and password are correct - especially after the reset!
Oct 06, 2009 | Belkin (F5D5231-4) Router
My broadbank link flashing red
Hi
Flashing red light means system restarted due to power outage and or system was restarted, Wait for system to boot. The power adapter may not be connected firmly in the power socket or the wire connected at the back of your router may be loose.
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Jul 10, 2009 | 2wire 1800HG Router (RG1800HG00)
2Wire 473 router problem
Take the modem and plug it into a GFCI outlet. You can find one in the bathroom or the kitchen.
If the power light comes on solid green and the dsl comes on red then the modem is good. Was it plugged into a power strip by the computer? If so, plug it straight into a wall outlet.
If the power light comes on solid red then the modem has hardware failure. I would contact your ISP and have them replace it if it is still underwarranty.
Mar 23, 2009 | 2wire (1000-400108-001) Router
Internet Light Stays Red on WAG54GS Wireless Router
If your router's internet light is red it means to say that there's no connection. You really have to call Tesco.
Aug 21, 2008 | Linksys (WRT54GC) Router
Red lamp issue
the color which you see has problem i think you might be seeing white slanting lines also with this. it mainly due to 1 supply to green video supply 2 loose cuntact in g.video section 3 green tr. defective 4 ckt from ic to green input is defective 5 chroma ic defective if supply is ok. regards
Sep 14, 2007 | Pioneer SD-533HD5 53" Rear Projection HDTV
Computers & Internet Logo
140 people viewed this question
David Payne
David Payne
