Power supply for hp color laserjet cp 2025 (58.04 error)
HP color laser jet CM6040MF cod eror disply 58.04 problem
Posted on Feb 05, 2013
  • 5 Answers
SOURCE: We have tried to reset
pls!... check the power supply of your printer....
Posted on Feb 19, 2010
  • 223 Answers
SOURCE: HP Color LAserjet CP 2025 printer fails to print.
Make sure the printer is connected directly to the outlet. If there is no display there is no use trying anything else as this is a formatter failure and the printer requires service.
Try a nvram:
Try doing a hard or reset or nvram:
1. Turn the printer off
2. Hold down the right arrow and the cancel button
3. Reboot the printer while holding the buttons and hold until permanent storage is displayed. Let go of the buttons and wait for the ready message on the display.
If there is a display,
print out a configuration report
check network settings ipv4addr, check port under driver properties. and make sure the same ip address is selected.
if using usb download a universal print driver and try installing the driver and selecting the usb virtual port
Al
Eliteprintersolutions@gmail.com
Posted on Jul 14, 2010
  • 27 Answers
SOURCE: Brand new HP Laserjet printer
hi the chairman..
when do bought that printer..from my experiance the paper curl couse of fuser got problem...
need to bring to hp centre...
Posted on Nov 07, 2008
  • 4 Answers
SOURCE: problem in hp cp 2025 color laser printer that
This error typically indicates that the cartridge was moved (e.g. previously installed) from another printer to your printer. The error should not affect your ability to print. If you want to clear the error, replace the affected cartridge with a genuine HP replacement.
Posted on Oct 01, 2010
  • 304 Answers
SOURCE: Hp color laser jet cp 2025 error 59.70
The product has experienced a problem with one of the motors.
Turn the product off, wait at least 30 seconds, and then turn the product on and wait for it to initialize.
If you are using a surge protector, remove it. Plug the product directly into the wall socket. Turn the product on.
Posted on Aug 23, 2011
Supply error
make sure you have removed an orange small plastic piece if u don't remove printer will detect it as a Supply memory error
hp laserjet pro m1213nf mfp driver Software downloads Hp Drivers
Apr 01, 2014 | HP LaserJet Pro 400 color M451dn - Printer...
Error 50.2 hp printer laserjet cp1525n color\
error 51.23 printer CP 1525n is laser yellow damage, replace new laser yellow.
Sep 28, 2013 | HP Laser Jet Pro CP1525N
10.xx.xx errors all relate to supplies. If you recently replaced a toner cartridge then likely the chip on that cartridge is bad.
Jun 08, 2011 | HP COLOR LASERJET CP 3505 N PRINTER
Hp printer cp 2025 erorr code 58.04
This error code indicates "Low voltage power supply error"
Jul 18, 2010 | HP Laserjet Cp2025n Printer
10.92.00 cartridges not engaged error on Color Laserjet 3500. Replaced black cartridge. What should be my next step
check the contacts on the transfer unit, or replace the transfer unit. could also be the dc controller or the high voltage power supply pcb.
Aug 11, 2009 | HP COLOR LASERJET CP 3505 N PRINTER
HP Color LaserJet 4500 Printer
Here is your problem. Hope that this helps you.
54.1 PRINTER ERROR
Description:
Indicates that an internal power failure has
occurred.
Action:
1. Turn the printer off, and then turn the printer
back on.
2. Replace the high-voltage power supply.
3. Check the fuser to ensure jams have not
occurred.
Caution When clearing jams, the
thermistor can be damaged
causing this error.
4. Make sure there is not a fluctuation in the
power supply to the printer. Check that the
electrical specifications (see Chapter 1) are
met.
5. Replace the low-voltage power supply.
Apr 02, 2009 | HP Color LaserJet 4500 Printer
2,553 people viewed this question
k24674
jasbo
jasbo
