Question about Palm Tungsten E2 Handheld
My e2 frozen on the palm powered logo
My e2 is frozen on teh palm powered logo screen I already tried soft and hard reset and no results. the first time i tried the hard reset it promted me to rase all data which I ok sincce i had already changed the settings on my desktop to override handheld but stayed on the same screen but this time with a thin line at the tor that is blinking and is not responding to anything else not even a new hard reset. can youi help me???
  • jvkenya Jun 02, 2008
    I have EXACTLY the same problem! Device is frozen at the "Palm Powered" screen, with just a flashing line at the very top. Tried soft resets, hard resets, disconnnected and re-connected the battery. I assume it's in a "loop" of some sort.
  • dara_nunez Apr 16, 2009
    I have the same problem. When i turned my device on, it was still working but after a few minutes, there was an error message which said I have to reset it. After a soft reset, the palm powered logo appeared and it froze there. A blinking bar appeared on top. i can't turn it off. I had to let on until the battery dies off.
  • 38 Answers
Okay here it goes, your going to want to leave it on for however many hours it takes to completely drain the battery then you're going to want to recharge it back to normal charge, and try restarting it again. This will delete completely anything that is keeping it from restarting properly. If you did open up the machine without following "antistatic procedure" you may have fried a component on the board and then your in trouble
you'll need to salvage a board from another tungsten and put it back in your PDA and hope you put it back together right
Posted on Jun 20, 2008
Frozen Blank Screen - soft reset doesn't work.... Do NOT want to do hard reset because all my data will be lost and it is my life line. I am panicking. Please help!
If you back up all your data on your desktop it will be restored with your next hotsync after the hard reset. I recommend the hard reset but if you really don't want to try that they I suggest you try using the free palm chat. Here is the link for that. Be sure to scroll to the bottom of the page and you will see palm Chat. Click on the link that says chat now and follow the prompts. Best wishes.
http://kb.palm.com/wps/portal/kb/na/tungsten/e2/unlocked/supportservices/page_en.html
Nov 18, 2009 | Palm Tungsten E2 Handheld
Palm T3 frozen, tried restart in hole, nothing?
Doing a soft reset A soft reset tells your handheld to stop what it's doing and start over again. None of your information will be lost. After a soft reset, a screen appears that lets you reset the date and time, if needed. To do a soft reset, use the tip of an unfolded paper clip (or similar object without a sharp tip) to gently press the reset button inside the hole on the back panel of your handheld.
If a soft reset does not unfreeze your handheld, you need to do a hard reset. Doing a hard reset Only do a hard reset if a soft reset doesn't solve your problem, or if you want to clear all of your information from your handheld. [!] IMPORTANT A hard reset deletes all records and entries stored on your handheld, including the username that identifies the handheld. Before you do a hard reset, be sure to synchronize.
1spacer.gif Press and hold the power button. spacer.gif 2spacer.gif While holding the power button, use the tip of an unfolded paper clip (or a similar object without a sharp tip) to gently press and release the reset button inside the hole on the back of your handheld. spacer.gif 3spacer.gif Wait for the Palm Powered™ logo to appear, then release the power button. spacer.gif 4spacer.gif When you see the message that warns you about erasing all of the info on your handheld, do one of the following: blank.gifPress Up on the navigator to finish the reset and show the Digitizer screen.
blank.gifPress any other button to do a soft reset.
Jan 31, 2008 | Palm Tungsten T3 Handheld
My palm e2 screen brings a frozen screen even after reset and no button whatsoever works, it can reset but freezes on the screen again,that is 0 alerts. even the power button does not work, only reset,...
You can try doing a hard reset. A hard reset will delete everything on your device. All your data will be deleted, and formats, preferences and other settings are restored to their factory default settings. Don't perform a hard reset unless you've backed up your data, or you're willing to lose everything. Here is the link for directions for the Hard Reset:
http://kb.palm.com/wps/portal/kb/na/tungsten/e2/unlocked/solutions/article/42094_en.html#tx
My screen in frozen but the preset buttons work
Try doing a hard reset.
Inset a non sharp object in the hole on the back of your unit. Use something like a paperclip. Hold down the power button and then use the paperclip on the back. When you see the palm powered logo then let go of the power button and follow the online directions for doing a hard reset. it will erase all your data and restore it to a brand new state. From there do a hot sync and that should solve your problem.
Oct 26, 2009 | Palm Tungsten E2 Handheld
My Palm tungsten E2 hand held PDA is totally frozen and locked up
Best thing to do here is to remove any memory cards etc.. and do a hard reset - seems like soft reset will or has not worked...
Press and hold the power button - keep it pressed and gently press the reset button on the back of the handheld.
Wait for the Palm Powered logo to appear and release the power button.
You should get a message warning about erasing all data. Press up on your 5-way navigator to reset.
This will erase all data inlcuding user information from the device, but synchronizing should get it all back - but you will loose anything that was not recently sync'd
good luck
May 27, 2009 | Palm Tungsten E2 Handheld
Palm m515 frozed up when powered on.
Did you install something rare at your palm??? Is your palm Sayin "Fatal Exeption" when you Reset it??? If you install something rare and after that your palm is saying taht you can...
Do a soft reset:
Reset it normally... If after that your palm show again that message you can;
Do a warm Reset:
Pres de up scroll when resseting.. when you so the Palm logo you can stop press the reset botom... There you will see the configuration screen... If it is not more the "fatal exeption" message you can uninstall what is doing the problem... you can hot sync your palm now... after that... do a soft reset and-If you uninstall what is doing the problem- you are not going to saw any more that message... if it is not resulting...
Try to do a Hard Reset
Do a warm reset and copy all you important files or programs to your stick memory...
then when pressing reset botom pres the on-of screen botom.... when you see the palm logo you can stop presing on-of screen botom.
bye.
From paraguay... luis-c
(sorry for my english... im stilll learning)
Apr 14, 2009 | Audio Players & Recorders
Palm will not turn on
have you tried a hard reset?
Todo a hard reset, First press and hold the power button, while holding the power button use the tip of the stylus to gently press and release the reset button. wait for the logo to appear then release the power button.
when you see the message that warns you about erasing all of the info on your hand held press up on the 5way navigator to finish the reset
Dec 21, 2008 | Palm Tungsten E2 Handheld
Urgent response needed
1 press and hold the power button
2 while holding the power button, use the stylus to press the rest button on the back
3 wait for the "palm powered" logo to appear and then release the power button
4 when you see the warning message
either press "UP" on the 5 way navigator to reset
or
press any other button to do a soft reset
Best of luck
Jun 10, 2008 | Palm Tungsten E2 Handheld
Palm Tungsten E2 Handheld Logo
366 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
