Question about Vacuums
Looking for user manual for a Home Essentials Portable Fan Forced Oscillating Heater Model PH-780R
I am looking for a user manual for a Bissell 1653-6 portable little green machine. Not sure how to operate this machine.
Hello, this is Ava with Think Crucial.
You may find the User's Manual for your Bissell model by clicking the link below.
Bissell Little Green 1653 4 User Manual
You can purchase a wide variety of high quality Bissell replacement parts for your Bissell vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/vendors?q=Bissell
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Sep 05, 2011 | Vacuums
Looking for a instructions manual for brother sewing machine VX-920
Hi lynie32...
Go to the following website and download your free user manual for the brother VX-920 sewing machine.
Please take time to rate me
http://the-manuals.com/user-manual-singer-futura-ii-model-920-manual/
Aug 18, 2011 | Vacuums
I'm looking for the user manual for the delonghi de500 dehumidifier...
First of all, here is a direct link to the ONLINE USER'S MANUAL for that model:
http://dl.owneriq.net/8/88e23cb9-80fb-4340-b43e-60b13037ea08.pdf
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
I hope that was helpful to you, good luck and take care.
Joe.
Jun 21, 2011 | DeLonghi Vacuums
How do i put the water in a euro-pro select professional portable steamer model # sc 500 h
here is the link to the user manual. you will find all the info you need
http://www.sharkclean.com/manual/SC500_REV_0902F.pdf
Good luck and thanks!
Please rate FIXYA
Apr 08, 2011 | Vacuums
How to assemble the hawaiian breeze oscillating floor fan
I cannot find exact instructions but I did find a general guide to assembly. they are usually very easy to assemble.
A standing fan is a portable fan that has a set of three oscillating blades on a long neck. The neck, also called the pole or the leg, is mounted on the floor. Standing fans have evolved from their origins as noisy accessories that blew away papers in their vicinity to silent fans whose direction can be controlled remotely. When placed at a convenient location, a standing fan can distribute air evenly to the entire room. Its speed can be controlled, and many standing fans can be programmed to stop at a set time.
  1. Installation Requirements
    • The only requirement for installing a standing fan is making sure it is near a power source. The entire unit can be assembled manually with only a screwdriver. A single standing fan, either an oscillating or pedestal fan, is very simple to assemble for basic home use.
    Pole and Base
    • The first step is to lay the parts on a floor. Then assemble the pole on the base of the stand. This is very simple, because the grooves for the screws are already drilled, so the screws just need to be inserted and screwed in. Screwing the pole into the base of the fan is required on some models; on others, the pole and the base are molded together and no screws are needed.
    Motor and Fan Installation
    • One some fans, you have to install the motor and oscillating arm to the pole. This again is done by screwing screws into predrilled holes. Grooves for long screws are at the top end of the pole, where they attach to the motor of the fan. Once the motor is placed on the top of the pole, insert the screws in the predrilled holes and tighten the screws. The next step is to wire the three blades. This is done by taking the wires from the motor and joining them to the sockets in the pole. This finishes the assembly procedure.
      To turn the fan on, ensure that the wires fit securely together. A loose connection cannot not only hamper the performance of the fan, it can also lead to problems such as electrical shocks or burning wires.
I hope this helps
good luck
Please rate FIXYA
Apr 07, 2011 | Vacuums
I'm looking for the user manual for the JET343G-002 Microwave/Heater
the User manual(also called "Use & Care") part# 49-8332 at Sears Website or Service Center and cost about $9.00 plus tax,shipping.
Feb 09, 2011 | GE Vacuums
I have a Century Jumper 1000 with no user manual. How do I recharge it?
Portable Power Source Owners Manual Units Manufactured Pre 03/99 Price $8.00
Portable Power Source User's Manual. This Operators manual provides specific information for your model. This manual contains information such as the Important Safety Instructions, Usage and Maintenance of your Booster Pac. This document is provided as a download PDF format. We suggest you save it to your computer for future reference.
Model Coverage: ES2500, ES5000, J1000, JUMPER 1000, J850, JUMPER850, For Models with Old Style Manual Charging Board "Cigarette Lighter Style Charging Jack" (pre 03/99)
Oct 13, 2010 | Vacuums
Looking for user manual for Irobot vacumn model # 4000
The iRobot website has all the manuals under their Troubleshooting section.
Mar 15, 2009 | iRobot iRoomba 4000 Robotic Vacuum
Need manual
To all the users looking for this manual.
Check the links below:
Online User Manual and Guide for Hoover F6020-900
Regards.
Jun 29, 2008 | Hoover F6020-900 SteamVac Upright Vacuum
Vacuums Logo
67 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
