Question about HP OfficeJet 6110 All-In-One InkJet Printer
Printer is stuck on "remove and check cartridges"
    Director Badge:
    Uploaded 100 video answers.
  • 1,751 Answers
Hi
you need to replace your cartridges with new ones
If i help you pls vote
Posted on Nov 01, 2010
HP Photosmart C3180 carriage permanently stuck on right. How to fix this?
If the carriage totally stuck on the right side of the printer, Unplug the printer from Power outlet.
Open the front access door. You will see the cartridges. Remove the cartridges. Check for any paper stuck in the Carriage Rod. Try to manually move the carriage 5-6 times left to right and it should move without any trouble. Put the cartridges back into the Cartridge slot and power on the printer
If the Carriage does not move manually, there could be chances the printer needs mechanical repair as its broken.
Regards,
Sean
Sep 16, 2012 | HP Photosmart C3180 All-In-One InkJet...
When i on the printer the number 3&5 flashes on the printer
Those numbers could indicate a few things.
  • First number 3 means you need to check for paper jams.Turn on the printer.Open the scan unit or the front cover,check for any stuck papers inside and remove them.
  • Check the rear paper tray and remove any stuck papers.
  • Number 5 means you need to check the cartridges.Open the scanning unit and check if the cartridges are installed correctly and are the right cartridges.Install the correct FINE cartridges.
  • Turn printer off and on again.
  • If error continues you may have to replace the printhead.
Oct 10, 2011 | Canon PIXMA MP210 Photo All-In-One Printer
Printers Led Screen apear i.e. "Toner not instaled"
remove and reinstall the cartridge.
Check the switch on the top( Whether smooth operation or stuck) if it stuck then apply little
lubricant .
Jul 23, 2011 | Samsung ML 1610 Laser Printer
My Canon Pixma is brand new just pulled it out the box and plugged it in and it is telling me error 5100 what do i need to do?
Remove the cartridges. Inspect the cartridges to ensure all packaging is removed. Reinstall the cartridges. Press the ON/OFF button for 2 seconds. Unplug the printer and wait 10 seconds. Check the printer for any obstructions including packaging materials.
Remove the scanner cover. Open the lid - check for paper that is stuck; these can be very small pieces, so look carefully. Plug the printer back in and power it on. If that does not solve the problem you will have to contact service or seller depending on your warranty and replacement policies on vendor.
Jan 04, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Papper got stuck . spongy peace 9"x1/2" came out ,
Open the print carriage access door. Check for any packing material that may be blocking the internal components. Check for an orange shipping lock that may still be in place on the left side. Pull the shipping lock out, if present, and discard.
Remove and reinstall the cartridges to make sure they are properly installed. Lift the front center of the print carriage access door to open it. Lift the door up until it locks into an open position. Press down on a print cartridge and allow it to spring back up. Lift the cartridge out of the printer. Do the same for the other cartridge. Slide the black cartridge into the slot on the left and the color cartridge into the slot on the right. Press down on each one to lock it into place. Lower the print carriage access door.
Check the print cartridges to make sure the protective tape has been removed from the ink nozzles. Remove the cartridges from the printer. Remove any tape or labels. Replace the cartridges into the printer.
Push in on the tab on the left side of the clean-out door on the back of the printer to open the door. Lift the door out of the printer. Check for any paper jams. Jammed paper can block the printer cartridge carriage from moving. Pull any jammed papaer out.
Nov 04, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Printer says cartridge error: error 1203
Remove both ink cartridges and check the bottoms to be sure all of the tap is removed. Small pieces of tape frequently are stuck to the cartridge bottom causing errors. Confirm you have the correct cartridges (# 34 for Black(HIGHYIELD) and #33 for color). Reseat the cartridges and try again.
Sep 06, 2010 | Lexmark X7170 All-In-One InkJet Printer
Lexmark x7170 printer cartridge error
Remove the color ink cartridge and double check that the plastic tape, which you removed from the cartridge is completely removed. I've noticed that sometimes a small piece of the protective tape tears and stay stuck on the cartridge causing the printer to give a false error. When replacing the cartridge be sure its fully inserted into the color cartridge holder and the locking mechanism locks securely.
Jan 17, 2010 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Error Light on Brother HL-2170W
Do not try to depress the green lever, since you need to remove the cartridge AND its base altogether. Just grab the front middle part of the assembly, pull it out slowly and steadily. You may need to apply extra force in doing so as it does take some effort to disengage the cartridge assemly from its seated position.
After the cartridge is removed, you may find some jamed paper inside. simply remove it and the printer should work again.
You may email me at stevenjoy@gmail.com should you have further questions.
May 12, 2009 | Brother HL-2040 Laser Printer
Printer cartridge stalled
# Turn off the printer.
# Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it.*
# Remove all paper trays and any paper that may be stuck between the tray and the printer. If the stuck paper is visible manually remove it.*
# Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. If the stuck paper is visible manually remove it.*
# Turn the printer back on. If you continue to receive a printer jam error try repeating the above steps again. If issue still persist and you see no paper that is stuck in the printer it's likely your printer is experiencing another hardware issue
Feb 06, 2009 | Lexmark JetPrinter Z11 InkJet Color...
Canon copier D761's printer cartridge is jammed
That door above the cartridge needs to be open all of the way, maybe even push it back gentley to make sure. Should be at 90-92 degree angle. Then the cartridge will come out.
Jan 08, 2009 | Canon imageCLASS D761 Copier
HP OfficeJet 6110 All-In-One InkJet Printer Logo
56 people viewed this question
Seeker5211
Seeker5211
