Question about Canon PIXMA MP150 All-In-One InkJet Printer
When I printed my assignment sheets, the writing that appeared on that sheets was totally in a mess like in the middle of writing line, there are one blank line. So, I just don't get it why my printer having a problems like that...
  • Canon Master
  • 32,281 Answers
Try re-installing the printer driver.
If you have lost the driver disk then -
Normal 0
You can download the Canon printer drivers from their support WEB site. Please click on this link and select your model printer to download :-
http://www.usa.canon.com/consumer/controller?act=DownloadIndexAct
Posted on Oct 06, 2010
There is a horizontal line grey in color
If this a P2035 printer using a toner cart with a drum in it. The drum has been exposed to light or has a smudge on it. take the cart out and look at the drum. This is a round light blue tube located at the bottom of the cart. It is the drum because it is the only thing in the printer that will print a defect three times on the paper. You could also print about 0 black sheets of paper through the printer and it will go away. This is because the drum coating is in layers like an onion. You must get rid of the exposed layer to get to on that has not been exposed to light.
Apr 02, 2014 | HP P2035N LaserJet Monochrome Printer
Replaced black ink cartridge, but now it only prints a very faint line, cant make out what is printing
Sir/Madam
If your printed pages have a horizontal line in the text or graphics (as shown in the illustration below) or blank text, some of the nozzles may be clogged and need to be cleaned
Go to Section 2 for instructions on how to print the Alignment Check sheet and adjust the print alignment.
Section 1: Checking the print quality and cleaning the print head
  1. Print a Print Quality Check Sheet.
    1. Press Menu.
    2. Press the UP OR DOWN ARROW key or the dial pad to choose Ink Management and press OK.
    3. Press the UP OR DOWN ARROW key or the dial pad to choose Test Print and press OK.
    4. Press the UP OR DOWN ARROW key or the dial pad to choose Print Quality/Alignment and pressOK.
    5. Press Color (Colour) Start. The machine begins printing the Print Quality Check Sheet.
  2. Closely examine the Print Quality Check Sheet. Each of the four colors is represented by a slanted square pattern made up of individual blocks. The colors should appear in the following order from left to right: Black - Yellow - Cyan - Magenta.
  3. Compare the print quality of the Check Sheet you just printed with the three examples listed below:
    (A) One or more complete blocks of colors are missing:
(B) Most of the short diagonal lines are missing from one or more color blocks:
(C)Some parts of the short diagonal lines are missing from one or more color blocks:
  1. The display will then ask you if the print quality is OK for black. Press the DOWN ARROW key or 2 to choose Nofor black with the problem.
  2. The display will then ask you if the print quality is OK for Color. Press the DOWN ARROW key or 2 to chooseNo for color with the problem.
  3. The display will then show Start Cleaning? Yes No.
    Press the UP ARROW key or 1 to choose Yes and the machine will start cleaning the color ink cartridges.
  4. When the machine completes cleaning the print head, press Color (Colour) Start. Another Print Quality Check Sheet will print.
  5. Repeat the cleaning and the quality check process following the Step 4-7.
  6. Compare the second or third Print Quality Check Sheet with the first one you printed in step1:
9. Compare the second or third Print Quality Check Sheet with the first one you printed in step1:
  • If the print quality on the first Check Sheet matched Example (A) or (B) and you do not see any improvement on the second or third Check Sheet, please contact Brother Customer Service from "Contact Us."
  • If the print quality on the first Check Sheet matched Example (A) or (B) and you see some improvement on the second or third Check Sheet but it's not perfect, repeat the cleaning and the quality check process three more times (totally five times). If you do not see any further improvement after that, please contact Brother Customer Service from "Contact Us."
  • If the print quality on the first Check Sheet matched Example (C) and you do not see any improvement on the second or third Check Sheet, repeat the cleaning and the quality check process three more times (totally five times). If you still do not see any improvement, please contact Brother Customer Service from "Contact Us."
10. Press Stop/Exit.
Section 2: Checking the Print Alignment
  1. Press Menu.
  4. Press the UP OR DOWN ARROW key or the dial pad to choose Print Quality/Alignment and press OK.
  5. Press Black (Mono) Start or Color (Colour) Start. The machine begins printing the Alignment Check Sheet.
  6. By reviewing this Check Sheet, you can determine if the alignment needs adjustment.
  7. Examine the 600 dpi and 1200 dpi test prints on the Alignment Check Sheet. If the number 5 sample of both the 600 dpi and 1200 dpi most closely matches the 0 sample, press the UP ARROW key or 1 to choose Yes.
    If one of the other samples is a better match for the 0 sample, press the DOWN ARROW key to choose No. The display will then prompt you to choose the sample that most closely matches the 0 sample for 600 dpi and then 1200 dpi.
  8. Press Stop/Exit.
If the print quality continues to be poor, go to Section 1 to clean the print head.
If your question was not answered, please check...
Improve poor print quality Brother
Or
If You Still need Brother Printer Help then I suggest You follow Us On For: Brother Printer Support
Oct 09, 2012 | Brother Ink for Dcp-6690cw and Lc-1100
CP1215
Clean the pickup rollers. dedust unit.
Dec 01, 2011 | HP LaserJet CP1215 Color Printer
The colour not sharp and got vertical line when print
A reason for the non-sharp collorcould be that the ink is not dried correctly, so open the printer settings andclick at the Slow Drying Paper in the Basic tab. Thus, theprinter will let the paper to dry better.
Regarding the vertical line (and not sharp color) we could check the printquality and then align the nozzles:
Checking the print quality: 1. Print a Print Quality Check Sheet.a. Press the Ink or InkManagement key on the control panel of the machine.b. Press the up or down arrow keyto choose Test Print and press OK. c. Press the up or down arrow keyto choose Print Quality and press OK. d. Press Color (Colour) start.The machine begins printing the Print Quality Check Sheet. 2. Closely examine the Print QualityCheck Sheet. Each of the four colors is represented by a slanted square patternmade up of individual blocks. The colors should appear in the following orderfrom left to right: Black - Yellow - Cyan - Magenta. 3. Compare the print quality of theCheck Sheet you just printed with the three examples listed below:
(B) Most of the short diagonal lines are missing from one or more colorblocks
(C)Some parts of the short diagonal lines are missing from one or more colorblocks4. The display will then ask you if theprint quality is OK for black. Press the down arrow key or 2 or "-" to choose No for black with the problem. 5. The display will then ask you if theprint quality is OK for Color. Press down the arrow key or 2 or "-" to choose No for color with the problem. 6. The display will then show StartCleaning? Yes No.
Press the up arrow key or 1 or "+" to choose Yes andthe machine will start cleaning the color ink cartridges. 7. When the machine completes cleaningthe print head, press Color(Colour) Start. Another Print Quality CheckSheet will print. 8. Repeat thecleaning and the quality check process following the Step 4-7. 9. Compare thesecond or third Print Quality Check Sheet with the first one you printedin step1:o If the print quality on the firstCheck Sheet matched Example (A) or (B) and you do not see anyimprovement on the second or third Check Sheet, please contact BrotherCustomer Service from "Contact Us".o If the print quality on the firstCheck Sheet matched Example (A) or (B) and you see some improvementon the second or third Check Sheet but it's not perfect, repeat thecleaning and the quality check process three more times (totally five times).If you do not see any further improvement after that, please contact BrotherCustomer Service from "Contact Us".o If the print quality on the firstCheck Sheet matched Example (C) and you do not see any improvement onthe second or third Check Sheet, repeat the cleaning and the quality checkprocess three more times (totally five times). If you stilldo not see any improvement,, please contact Brother Customer Servicefrom "Contact Us".10. Press Stop/Exit.Setting the Alignment:1. Press the Ink or InkManagement key on the control panel. 2. Press the up or down arrow keyto choose Test Print and press OK. 3. Press the up or down arrow keyto choose Alignment and press OK. 4. Press Black (Mono) or Color(Colour) start. The machine begins printing the Alignment CheckSheet. 5. By reviewing this Check Sheet,you can determine if the alignment needs adjustment. 6. Examine the 600 dpi and1200 dpi test prints on the Alignment Check Sheet. If the number 5 sampleof both the 600 dpi and 1200 dpi most closely matches the 0 sample,press the up arrow key or 1 or "+" to choose Yes.
If one of the other samples is a better match for the 0 sample, press the downarrow key or "-" to choose No. The display will thenprompt you to choose the sample that most closely matches the 0 samplefor 600 dpi and then 1200 dpi. 7. Press Stop/Exit.
Aug 04, 2011 | Brother MFC-5860CN InkJet Printer
My brother MFC 665CW printer shows a 4F error and unable to clean. How do I get to the head to clean it?
Do the following to clean the print head:
1. Press INK key on the control panel.
2. Press the DOWN arrow key until CLEANING appears on the LCD.
3. Press OK.
4. Press the DOWN arrow key to select BLACK, COLOR or ALL depending on what you want to clean.
5. Press OK.
The machine will clean the print head. When cleaning is finished, the machine will go back to Ready automatically. If you are experiencing a print quality issue, we recommend you repeat the print head cleaning for each color showing an issue at least five (4) times.
If you are experiencing a print quality issue and want to see if the cleanings are improving the print quality, print a Print Quality Check Sheet (PQCS) after the first cleaning and then print another PQCS after repeating the print head cleaning steps at least three (3) more times (4 total cleanings). You can then compare the two Print Quality Check Sheets.
Do the following to print a Print Quality Check Sheet:
1. Press INK key on the control panel. TEST PRINT will appear on the LCD.
2. Press OK. PRINT QUALITY will appear on the LCD.
3. Press OK.
4. Press COLOR START.
NOTE: The machine will generate the Print Quality Check Sheet (PQCS). On the PQCS each of the four colors is represented by a slanted square pattern made up of 96 individual blocks. The colors should appear (from left to right): Black - Yellow - Cyan - Magenta. Cyan is the light blue color and Magenta is the pinkish color.
Feb 21, 2011 | Brother MFC-665CW All-In-One InkJet...
Print head is not printing seems to be clogged from non-use. Have tried test printing through several new cartridges and still not working. Can the old - dryed ink be cleaned off of the print heads?
Hi, below is from the brother website for your model. Very common for the ink heads to become clogged /dry out. You probably have done this but here it is anyway. your print head is part of the machine, so it will need to be disassembled to clean it, That can be very difficult. Try the following anyway, it might help you. also, you could try using a Q-Tip wet with vinegar water to get under to the bottom of the print heads, if you can get the head to move off its dock and then unplug it when its moved over. anyway here is the Brother link info (without pictures-see the link above if you need the pictures)
  • Print a Print Quality Check Sheet.
    1. ress the Ink or Ink Management key on the control panel of the machine.
    2. Press the up or down arrow key to choose Test Print and press OK.
    3. Press the up or down arrow key to choose Print Quality and press OK.
    4. Press Color (Colour) start. The machine begins printing the Print Quality Check Sheet.
  1. Closely examine the Print Quality Check Sheet. Each of the four colors is represented by a slanted square pattern made up of individual blocks. The colors should appear in the following order from left to right: Black - Yellow - Cyan - Magenta.
  2. Compare the print quality of the Check Sheet you just printed with the three examples listed below:
  3. The display will then ask you if the print quality is OK for black. Press the down arrow key or 2 or "-" to chooseNo for black with the problem.
  4. The display will then ask you if the print quality is OK for Color. Press down the arrow key or 2 or "-" to chooseNo for color with the problem.
  5. The display will then show Start Cleaning? Yes No.
    Press the up arrow key or 1 or "+" to choose Yes and the machine will start cleaning the color ink cartridges.
  6. When the machine completes cleaning the print head, press Color(Colour) Start. Another Print Quality Check Sheet will print.
  7. Repeat the cleaning and the quality check process following the Step 4-7.
  8. Compare the second or third Print Quality Check Sheet with the first one you printed in step1:
    Press Stop/Exit.
Aug 29, 2010 | Brother MFC-5460CN InkJet Printer
I want to connect my SCX 4500w to a new network (wireless). when i try to use a web page to configure the printer settings it doesn't response... I check the IP and write in in my Internet Explorer,...
You could try having your Samsung SCX-4500 print out a network configuration sheet. It will have the printer's IP address, default gateway etc.:
1) Press the <Menu> button on your printer panel
2) Scroll using the (<) or (>) navigational arrows until "Network" is displayed
3) Press the <OK> button
4) Scroll using the (<) or (>) navigational arrows until "Network Info" is displayed
5) Press the <OK> button
Your printer should print out a network configuration sheet. The IP of the printer appears in the TCP/IP information on this configuration sheet.
Note: Your printer's IP assignment should be "Static" not "DHCP" (You may skip the following steps if your printer's IP assignment is already "Static")
To change your IP assignment from DHCP to Static:
1) Open up your Windows browser
2) Type in the printer's IP address in the address (location) bar of your browser:
Example: http://192.160.0.100 (use the real IP you found above from the network information sheet)
3) SyncThru should load - Click "Network Admin" or "Network Settings"
4) Click on the "TCP/IP" option on the left side
5) Change the IP address METHOD to "Static"
6) Click <Apply>, then <OK> or <Exit>
Now your printer is ready to be added to your network. You have the information you need from your network configuration sheet. Your install should now proceed smoothly.
I hope this information was helpful!
Mar 07, 2010 | Samsung SCX-4500 Laser Printer
How can I tell how many prints have been done on my dell 3000cn printer
All of the following is done on the Printer, not your computer keyboard.
Press the printer's Menu button. Then press the down arrow until Configure appears. Press return. Press the down arrow until Reports appears. Press Return. Press the down arrow until Printer Settings appears. Press return again. You will now get a report sheet printed which will include the Total number of sheets printed, the total Colour sheets and the total B/W sheets plus other information.
Oct 05, 2009 | Dell 3000cn Laser Printer
Faxing up or down
Look at the hopper. It will almost certainly have a little graphic on it to tell you which way up the document goes.
If it looks like a sheet of paper with lines of writing on, the paper goes in print side up.
If it looks like a sheet of paper with one corner folded over, and lines of writing visible only on the turned over corner, then it goes in print side down.
If you can't find the graphic, then experiment: Take a blank sheet of paper. Write "Up" on one side and "Down" on the other then stick it into the machine so the writing is telling the truth. Most fax machines have a copy mode - use this to see which side of the paper the machine reads (if you can't get it to copy, fax your page to somebody and get them to phone back to tell you which side of the page they've received).
A.
Jan 18, 2009 | Brother Office Equipment & Supplies
Not working
Astonishingly, assignment of announcement to phone line is not documented in the user manual. Tech support was totally worthless concerning this issue. I had to discover it by trial and error. To assign an announcement to a specific phone line do the following:
1) Record your announcement message for a, b, c, ao, etc. as documented
2) Press program
3) Keep pressing the feature button until ANNC appear at the bottom of screen, line 1 appears at the top, and the letter 'a' appears in the middle.
4) Choose the announcement to be assigned to Line 1 by pressing the select button
5) Press the feature button again. Line 2 appears in the display.
6) Repeat step 4 to select the announcement to be assigned to Line 2.
7) Press program button, or take phone off-hook to end the sequence.
Shame on AT&T for such shoddy documentation, and lack of support for their products!
Nov 09, 2007 | Lucent 1872 Corded Phone
Canon PIXMA MP150 All-In-One InkJet Printer Logo
32 people viewed this question
old marine
old marine
