Question about Metrologic Instruments MS9535 VoyagerBT Barcode Scanner
I m using metrologic mi9535 547 and I cannot connect with pc working with win7 i connected with pc2 port.where the another cable \has to connect?
3 Suggested Answers
SOURCE: Can't even start Metrologic voyager 9520
The MS9520 with RS232 needs the AC adapter plugged in to operate, the adapter plugs into the serial cable at the plastic "bulge". Cable part number is 53000c-3
Hope this helps, Terry @ TAG Technical INC
Posted on Nov 25, 2008
rdiodoro
  • 13 Answers
SOURCE: Connecting Problems with Metrologic MS9535 BT
hi
that you have cable usb?rs232?ps2?
You have the power adapter?
you have windows xp?
is not difficult
Posted on Dec 17, 2008
Drivers for ms5145
A standard PS2 to USB cable will not work with these scanners. You'll need to purchase cable # M009-3MA7C. They are expensive, so shop around for price.
Jun 06, 2012 | Metrologic Instruments Eclipse MS 5145...
I got 1 modem (pldt dsl) cdrking wireless router and 2 desktop pc. i can connect to the internet in my host pc but unable to access the internet on the 2nd pc. when enabling the LAN on the 2nd pc it says...
It could be a faulty wiring connection from the ethernet cable to the RJ45 (plug). Exchange the cables from your PC1 and PC2 to confirm it. If that worked then you can either buy another set of cable (just make sure to try it in the store first). Or if you have a wire cutter especially made for ethernet cables, then just cut the RJ45 and replace it with a new one. You can buy those on CD-R king too.
Jun 24, 2011 | Computers & Internet
Need metrologic MS 951 driver
This scanner does not need any driver. If you connect via keyboard, the connection is transparent. If connecting via RS232, you need a program to receive data in the com port and send the keyboard buffer.
Roberto Martinez
Sep 24, 2009 | Metrologic Instruments Metrologic MS 951...
Fail to configure metrologic usb barcode scanner to use virtual RS232 port interface
First check the com port speed of computer port which you connected scanner .Com port speed should be 9600.
To change com port speed in computer go to computer/properties/device manager.
Select the ports eg com1 .Right click communication port go to properties and select port settings Bits per second should be 9600.
Serial scanner can not be test in word or note pad.you can download the RS232 software from below link and test the scanner
http://www.lookrs232.com/
Oct 30, 2008 | Metrologic Instruments MK9540...
Connecting 2 PCs to the HP PSC 1610 Printer at the same time
Hey,
This usb printer can only be connected to one pc at a time, you could use a USB SWITCH to connect both computers to the switch and printer into the other end, so with the press of a button you could connect the printer from port 1 (pc1) to port 2 (pc2)
Click here
Thanks,
Ekse
Aug 30, 2008 | HP PSC 1610 All-In-One InkJet Printer
hi
is not difficult
May 20, 2008 | Metrologic Instruments MS9535 VoyagerBT...
2 Eth Cards one for Internet & one for LAN
First of all, I would really recommend you to buy a Cable/DSL router. It is quite cheap, usualy more secure, much easier to configure and troubleshoot. Also, it does not require to have one PC up and running all the time, hense saving energy. Do you know that a PC running 24/7 may cost between 60$ and 100$ in electricity annually? This is more than the cost of a basic router!
But, since your question is about sharing your Internet connection with a PC, here are some guidelines. I will assume here that you are using Windows XP.
On PC1:
1. Connect the modem to Eth0 in the PC. Do not connect anything in the USB port of the modem.
2. Make sure that the link lights are lit both side. If they are not, you may need a cross-over cable (this is usualy not the case)
3. Configure Eth0 to get IP address DNS automatically
4. Disable (uncheck) all protocols except TCP/IP on Eth0.
5. Run the Network Setup Wizard (Start > All Programs > Accessories > Communications > Network Setup Wizard) and follow the steps.
On PC2:
Simply run the Network Setup Wizard (Start > All Programs > Accessories > Communications > Network Setup Wizard) and follow the steps. Specify and you Internet connection is through a Home or LAN network.
That should do it.
Apr 25, 2008 | Computers & Internet
Mar 13, 2008 | Metrologic Instruments 9520 Voyager
Metrologic Instruments MS9535 VoyagerBT Barcode Scanner Logo
495 people viewed this question
Top Metrologic Instruments Computers & Internet Experts
xak_tay98
Level 1 Expert
Daniel Dollive
Daniel Dollive
jackcity
jackcity
Level 1 Expert
Are you a Metrologic Instruments Computer and Internet Expert? Answer questions, earn points and help others
