Fagor elegance LD 534 -Power was lost during cycle- now door will not unlock - repeating cycle has not helped- how can I unlock door
SOURCE: Code LD
Here we go the problem probably lies in the holding tank tub. So far found one baby sock, clumps of lint, latest underwire from daughters bra. Easy to work on machine. Will need a 2nd person for 1st part of repair. Have a small bucket ready,(I used a empty kitty litter container) 1)Disconnect electric cord, 2)Disconnect water hose's to machine. pull out drain.3)(Will need a 5/16th socket.) Pull out washer remove back panel.(2 screws) 4) Tilt back washer (towards control panel) 5) Remove bottom access panel (3 screws). 6) With a pair of plyers pull back metal clip on hose leading to pump. (this is where all water left in washer will come out.) 7) Remove clip on return hose from pump. 8) Pump is held on by 2 clips, push them back to remove pump. Once a water is drained you should be able to see any objects in the tub area, you can also now place the washer on it's side.WATER MAY STILL COME OUT HAVE A TOWEL OR 2 READY. Check pump for damage. Remove any/all debris (Used a set of hemostats.)(Rubber balls are suppost to be in there.DON'T DAMAGE THEM.) Once everything looks to be removed. Reverse steps reattach hoses, pump, etc. before replacing access panels Use the Express Wash Option to see if all works well. If it does, reattach access panels, and start washing!!
Posted on Jun 30, 2007
  • 326 Answers
SOURCE: Kenmore Oasis Ld code
LD code is long drain one of 2 things the drain pump is frozen and need to be replaced or there is somthing in the pump. Pull the washer a way from the wall a bit and get a bunch of towels. Lean the washer back against the wall towards the middle in the back you will see the pump take it apart and find the clog.
it can be assessed through the bottom.
Posted on May 06, 2009
beltronic205
  • 1474 Answers
SOURCE: I have two washing machines both are failing on
Espares.co.uk will advise...
Posted on Feb 23, 2010
  • 901 Answers
SOURCE: Washer stops and door unlocks frequently during
Looks like power supply problem. Check your plugs for correct tightness. The switch also.
Posted on Mar 29, 2010
SOURCE: Question: FAGOR FE-1158 ELEGANCE WASH MACHINE
Ich habe die Waschmaschine FAGOR FE-1158 schon 7 Jare.Jetzt wenn voll beladen bei wasche stoppen und schlecht Wasser komt.
Ich bedanke vorher!
Mfg
30655 Hannover
Posted on May 31, 2010
Programming keyless entry to 95 landcruiser
1. Start with key out of ignition, drivers door is open all others closed and
drivers door is unlocked.
2. Insert key into the ignition (Do NOT Turn) and Pull key out.
3. Perform these steps within 40 seconds.
A. Using the power lock switch on the drivers door, perform 5 lock/unlock cycles
starting with lock. Use an even pace and try to go about one cycle per second.
(1Cycle = 1 lock and 1 unlock).
B. Close, then open drivers door.
4. Perform these steps within 40 seconds.
B. Insert the key in the ignition cylinder.
C. Turn the ignition to ON (Do NOT Start) then back to OFF.
D. Remove the key from the ignition.
5. Within 3 seconds the power door locks should cycle automatically indicating successful
entry into programming mode. Return to step 1 if the locks do not cycle at this point.
6. Perform these steps within 40 seconds.
A. Press the lock and unlock buttons on the remote simultaneously for 1 second.
B. Immediately after letting go of the lock and unlock buttons, press the lock button by
itself and hold for 2 seconds. Within 3 seconds, the door locks should cycle once
indicating successful programming. If the door locks do not cycle, or cycle twice.
repeat steps A and B in step 6 as your remote has not been accepted.
C. Repeat steps A and B in step 6 for each new remote.
7. Close drivers door.
Oct 29, 2013 | 2008 Toyota Land Cruiser
Fagor Elegance FE 538 washing machine. A copy of operating manual pl.
i dont know how to use that machine.. FAGOR Elegant FE-538 ..
neet guide or manual ....
Jun 15, 2011 | Washing Machines
I need to know how to program a remote alarm control for a toyota 4runner 2000
f
1. Start with the following conditions: you are in the vehicle
a. Key is out of the ignition
b. Drive door is open ( all other doors are closed)
c. Driver door is unlocked (other door locks don't matter)
2. Insert the key into the ignition (don't turn it) and pull it out.
3. Perform these steps within 40 seconds:
a. Cycle the power locks 5 times. Use an even pace and try
to go relatively fast.
b. Close, then open the drivers door.
4. Perform these steps within 40 seconds:
a. Cycle the power locks 5 times (same as before).
b. Turn the ignition to ON then back to OFF.
c. Turn the ignition to ON then back to OFF.
d. Remove the key from the ignition.
5. Within 3 seconds, the power door locks should cycle (automatically)
indicating successful entry into programming mode. Return to step 1
6. Perform these steps within 40 seconds:
a. Press the LOCK and UNLOCK buttons on the transmitter
b. Immediately after letting go of the lock and unlock buttons,
press the lock button by itself and hold for 2 seconds.
Within 3 seconds, the door locks should cycle ( LOCK then
UNLOCK) once-- indicating successful programming. If
the door locks don't cycle, or cycle twice. Repeat steps
6a and 6b--this remote has not been accepted.
c. Repeat steps 6a and 6b for EACH transmitter that will
operate the vehicle. Including any old transmitters.
7. Close the driver door.
Also can check this procedure: http://www.toyota-4runner.org/60925-post2.html
Hope this help.
Mar 22, 2010 | 1997 Toyota 4Runner
Need to program a new remote
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Here are the instructions for programming the 99-02 4Runner Keyless Entry factory remotes:
c. Driver door
6a and 6b--this
Hope this helps you, it did me greatly-- Good luck,
Mar 04, 2010 | 2000 Toyota 4Runner
Lost remote and like to program new remote. HELP. 2000 prado vx.
1. Start with the following conditions: you are in the vehicle a. Key is out of the ignition
3. Perform these steps within 40 seconds: a. Cycle the power locks 5 times. Use an even pace and try
4. Perform these steps within 40 seconds: a. Cycle the power locks 5 times (same as before).
6. Perform these steps within 40 seconds: a. Press the LOCK and UNLOCK buttons on the transmitter
Good luck and hope this helps.
Nov 04, 2009 | 2000 Toyota Land Cruiser
Fagor, washer dryer , model 2F-3611 flashing code F07 can you tell me what this is please
F07 - Motor Control Unit (MCU) Error - Disconnect power and unplug unit. Check wire harness connections between drive motor and Motor Control Unit (MCU), and between MCU and the Central Control Unit (CCU). Reconnect power and plug unit in.
Check the MCU by looking for operations of the drive motor, and check drive motor for powered rotations. Replace failed component.
Note: If this failure occurs during high-speed spin, the door will be unlocked after three minutes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 12, 2009 | Washing Machines
2000 Toyota Sienna Minivan car alarm goes off.
1. Start with key out of the ignition, drivers door is open all others closed and
2. Insert key into ignition (Do not turn) and pull it out.
A. Using the power door lock switch on drivers door perform 5 lock/unlock cycles starting
(1 cycle = 1 lock and 1 unlock.)
D. Turn the ignition to ON (Do NOT Start) then back to OFF.
E. Remove the key from the ignition.
5. Within 3 seconds the power door locks should cycle automatically indicating successful entry
Press the lock button by itself and hold for 2 seconds. Within 3 seconds the door locks
should cycle once indicating successful programming. If the door locks don't cycle or
cycle twice, repeat steps A and B, your remote has not been accepted.
C. Repeat steps A and B in step 6 for each new transmitter.
Apr 25, 2009 | Chevrolet Malibu Cars & Trucks
We have a 1 yr old Bosch wash machine w/o problems till now. We have a problem with the centrifuge program-it does not start, although the machine can spin slowly. Is it a motor problem or a problem with the programmer? Thanx for the help in advance!
Oct 16, 2008 | Washing Machines
Washing Machines Logo
48 people viewed this question
Top Washing Machines Experts
