Question about Lowrance GPS
My lowrance x97 screen it comes up with the bottom half black can not see anything how can i fix it
2 Suggested Answers
SOURCE: half screen showing , resets do not help
reset finally did work
Posted on Jan 08, 2009
My lowrance elite 4 HDI goes black when i get on plane so my backtrack feature doesnt work
The speed of your boats travel only directly affects your sonars ability to read the water depth.
your backtrack feature is GPS based. These is not affected by your boat being on plane.
Your screen being black sounds like your sonar is losing bottom contact due to air bubbles passing under the transducer. This is a common occurrence with most boats.
Add some details regarding what your seeing and we can help you get a better handle on your difficulty.
May 24, 2015 | Lowrance Boating
How do i fix the bottom half of my laptop screen which is all black
It is unfortunate that the bottom half of the laptop screen is black. You may try performing an LCD BIST using the below link:
http://dell.to/1irqbYp
Also try connecting an external known good monitor and check if that helps.
Thanks and Regards.
Kiran Kumar.
#iworkfordell.
Jul 06, 2014 | Dell InspironTM 1501 Notebook
The GPS component of my Lowrance Elite-5 Gold is malfunctioning about 50% of the time.
Hey Les, Since you have replace both the unit and transducer, you have eliminated/diagnosed most of your problem.. Its in the wiring... sometime when I am in full GPS mode I get erroneous depth readings..?? Have you tried a different GPS module (the "puck")?
https://www.lowrance.com/Root/Lowrance-Documents/US/ELITE-5-7_HDI_OM_EN_988-10647-001_w.pdf
Apr 22, 2017 | Lowrance ELITE 5 GOLD COMBO
Lowrance Lms 522c 5" Screen Color Internal Gps And 200 Khz Sonar
If it is normal in deeper water, it is most likely just returning stuff in the water (debris, algae, anything floating around...choppy water can cause this). Try installing the latest updates from http://www.lowrance.com/en/Downloads/Product-Software-Updates/
If it doesn't help, adjusting the sensitivity or setting the SURFACE CLARITY option from the SONAR FEATURES menu to LOW, MEDIUM, or HIGH...whichever gives the best results.
Jun 09, 2009 | Lowrance Lms 522c 5" Screen Color Internal...
Visio LCD TV - Partial Picture blacked.
Hello! I have a 32" Vizio LCD...within 30 minutes of the tv being turned on, black lines start running through the bottom half of the screen and eventually blacking out the bottom half of the tv screen. It also doesn't have anything to do with the ratio as I have tried that. HELP!
Jan 06, 2009 | Toshiba 42HP66 42 in. LCD Television
Phillips 42 inch Plasma -Screen Issues!!!
intermittent loss of picture on either bottom or top half of screen is specific to y buffer boards located on left side of screen going from top to bottom when looking at back of tv. the y lower buffer would be the board to replace to resolve the loss of bottom half of picture. if the top half also is going out intermittently could tied to upper buffer as well but just a note the y main board to right of these buffers drives those two boards so in some cases could also be part of the problem. if only bottom half is affected i would recommend replacing lower buffer only
Aug 07, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Half black screen on projection tv
Sounds like the vertical area like Output, but I would look for bad caps first and resistors. In this area
Sep 14, 2007 | Televison & Video
GPS Logo
69 people viewed this question
Top Lowrance GPS Experts
Andrew Taylor
Andrew Taylor
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
