Question about NetGear WNR2000 Wireless Router
H. im having problems with my netgear n300. ive moved into my friends house and trying to set both our computers up to it. his worked fine going through a bigpond router (with only one Ethernet connection) but when we changed to the aforementioned n300 only i can connect to the internet. his computer has never been able to connect through ethernet from the netgear n300 but has had success with wireless. however now i am connected it seems has cant even connect to the wireless. my os is vista as his is xp. also.
  • 14 Answers
SOURCE: Server not found} NetGear WGR614 Wireless Router doesn't connect me to the internet.
Dear Loud Nouises,
Your router must be connected properly to the cable modem. This must be to the wan port on the router.
Next, the router must be set-up accordingly to recognize the modem's internet connections. Please ask for the IP address.. and other relevant informations from your internet provider.
Set -up your computer using the internet connections wizard on each of your respective computer.
This should work fine if all connections were correctly configured.
Sidlahora
Posted on Dec 06, 2007
  • 11 Answers
SOURCE: netgear wireless router DG834PN wireless access local only
With Vista on the Laptop it should be just a matter of double clicking the router in the network settings, vista should automatically configure the connection.
This has happened to me before and this is what I did just to see if it worked, and it did flawlessly.
Posted on Mar 07, 2008
tech curly
  • 298 Answers
SOURCE: my router will not connect to the internet
The laptop may not have the correct wireless settings same as the router.
What is the Operating system of your laptop and does it have a builtin card?
Posted on May 21, 2008
  • 104 Answers
SOURCE: Yellow Ethernet Cable
Ethernet cables can come in all colours (very unhelpfully). The cable you need has RJ45 connectors at either end, which are clear.
It goes by many names: you are looking for Cat5e or Cat6, ‘straight’ or ‘patch’ cable, which is used to connect, say, a computer to a router. Do NOT use ‘crossover’ cable.
Netgear has some info here (a little out of date but OK:)
http://kbserver.netgear.com/kb_web_files/n101561.asp
Posted on Jan 07, 2009
anandg27
  • 1272 Answers
SOURCE: Have a new Hughes net HN9000 satellite service and
Hey, Can you perform the task below and paste me the results from the modem:
Connect the modem to the computer. Open command prompt and type ipconfig. Paste me the results for IP address, subnet mask and default gateway.
Also, confirm, how you have connected the modem to the computer. IS it using a ethernet cable or USB?
Once I have this information, I will be able to provide you with an accurate resoultion.
Posted on Jun 30, 2009
I am using my netgear N300 router for wireless access only. But it is slow if multiple devices are using it?
The bandwith is shared between devices, making them slower. DHCP provides an IP and is dynamic, making it easy to add devices, A static IP means you have to assign and keep track of the IP's. Most people use DHCP.
Jan 14, 2013 | NetGear N300 Wireless Router
I just got a Canon Pixma MG5370, Im running an XP cp to network thru Netgear N300 then thru DSL, the N300 dangles a Netgear 8 port wired Switch. I cant get the dam printer to connect correctly to print,...
Set a static IP on the Canon printer
e.g.
IP: 192.168.x.x
Subnet mask: 255.255.x.x
Gateway: 192.168.X.1
DHCP should always be enabled on the router for your other devices to work.
Nov 01, 2012 | NetGear N300 Wireless Router
Netgear n300 will not connect to internet
There should be a little red button that you can push. It is the reset button. Hold it down for around 10 seconds, and try again.
Jul 04, 2012 | NetGear N300 Wireless Router
Internet status light on netgear wireless n300 blinking. internet service on and off. 2 macs in house.
You can do a reset on the router to make a factory settings.On the back of the router you can look for a small hole usually with the word reset.Press it for 20 secs with the router on but disconnected from the Ethernet cable.Start up your PC and surf to the router Web UI (192.168.***) and make your settings.
May 26, 2012 | NetGear WNR2000 Wireless Router
How do I password protect my NETGEAR N300 WNR2000 from outside connection?
Connect a LAN cable from the Netgear to the LAN port on yourcomputer, open a browser and enter the Netgear configuration URL -
http://192.168.0.1
The default login = admin
The default PW = passwordYou can now change the default admin password and configurethe wireless settings.
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Mar 16, 2012 | NetGear N300 Wireless Router
Have NetGear N300 wireless router (wnr 2000v2)fed by motorola surfboard modem. N300 Port 3 output feeds OOMA internet phone system, Port 4 output feeds HP Touchsmart desktop pc (windows 7). PC will not...
hi,
go straight from your motorola to each wired computer to see if its a wire.can you can login to the router through your wired computer(touchsmart) in the settings and see if all your wired devices are listed, look at the parental controls, reset the whole router to default if you can, if your DSL. try a different jack in the house, get everything off that line but the motorola. go straight from the service jack outside the house(in the grey box) if you have to
jm
Jul 04, 2017 | NetGear N300 Wireless Router
Hi folks ive got a damn problem getting on live everytime i try to sign in it just says ive got internet connection but cant connect to live fully..... when i do live connection test it says ive got a port...
I was searching the web concerning this problem, and apparently there's a good amount of people dissatisfied with the results from their netgear dgn2000 router when hooked up to Live. You can pick up a pretty good router from Best Buy for under 40 bucks. That sucks that you're ISP and xbox support aren't helping. I usually go past Netgear and shoot for Linksys or D-Link just because I've had good relations with them. Good luck getting back to gaming, man.
Jan 04, 2010 | Microsoft Xbox 360 Console
NetGear WNR2000 Wireless Router Logo
432 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
