Question about Canon PIXMA MP160 All-In-One InkJet Printer
Paper feed my printer is dragging the paper off to the right hand side (as you look at it from the front), creasing the paper and smugging the printing.
  • dengull Jun 02, 2008
    Exactly the same problem - had a similar problem with another canon model
Thanks, absolutely right found a key that had dropped into paper feed !
Posted on Jun 14, 2008
  • 71 Answers
Hello Dear,
Both the printer has something stucked in the ASF Auto Sheet Feeder Assmbly of the printer try removing it your problem will be solved but if it persists you need to take it to the Canon Care get the printer serviced.
Regards,
Joseph
+91 9352008418
Posted on Jun 13, 2008
Paper printing with creases
Simple, get it replaced as it is obviously faulty and the "engineers" can't fix it. Go back to your supplier and if you paid by card, claim your money back, if they won't help, as it is faulty.
Mar 19, 2014 | Ricoh Office Equipment & Supplies
Paper comes out creased on one side
If the printed image is smudged, as well as creased, you might have a torn Fuser fixing film.
You will need a technician to fix that.
If it is just a crease, just check that
1. Your paper is not damp. Try a fresh packet of paper
2. The paper input tray guides are set to the width of the apaer, to prevent the paper skewing as it feeds.
Good luck.
Jun 21, 2010 | HP LaserJet 1012 Printer
I am getting a crease on top-half, right hand side, when I print.
Your paper is probably getting caught on the roller or rollers need to be replaced. By having a certified technician do a maintenance cleaning this should resolve this issue.
Jun 07, 2010 | HP LaserJet 3030 All-In-One Printer
PICTURE IS SMUGGED
If you're printing on photo paper, make sure you are printing on the correct side. Most photo paper has only one side to print on, the other side is a non-porous backing, and ink will sit on the surface until it dries (15 - 30 minutes, depending on temperature and humidity). And it won't look good even when it dries.
If you're printing on the correct side, try a different brand/type of photo paper.
Dec 28, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
CREASED PAPER
Most likely this is caused by a bad fuser, which can be replaced. Depending on the printer model it might be more economical just to buy a new printer..
Feb 27, 2009 | Brother HL-2040 Laser Printer
Printer is creating a crease and smudge down center of page.
There sounds like there is somthing in the path of the printhead. Using a flash light, remove back cover of machine and look for a small piece of paper,etc. Be careful not to jam anything in to th machine. It may take running a thick piece of paper through manually with your hands to remove the object.
Feb 12, 2009 | HP LaserJet 1012 Printer
Paper Wrinkle when Printing
Its time you need to change the Tension roller of the printer.
Dec 16, 2008 | Office Equipment & Supplies
Paper not feeding on the left hand side of our lexmark 5100
open the backdoor and try to move the rollers in upward direction...if the roller on the left is hard to move then..replace the machine.
Nov 25, 2008 | Office Equipment & Supplies
Ink
On the fuser (under the top cover), there are 2 green levers with envelopes on them. The one on the right is probably flipped up. The purpose of these levers is to decrease pressure on the paper when printing on envelopes which are 2 or 3 layers of paper. It reduces the wrinkling that occurs when printing envelopes on most laser printers. Flip that lever down and you're golden.
Nov 04, 2008 | Xerox Phaser 6120/YN Laser Printer
Dirty printing
The cause of this is a faulty toner cartridge. What happened was some toner spilled out of the cartridge and down into your printer. Take the toner cartridge out and with a damp paper towel just goto town and wipe everything down.
Replace the toner cartridge, and in about 20 pages it should clear up.
Aug 18, 2008 | Samsung ML1740 Laser Printer
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
74 people viewed this question
old marine
old marine
