Question about Leupold Optics
I have a Leupold 3X9 varilux Scope which is probably 30 years old. The problem I have is that I can't get the elevation adjustment to work as it should. How can I fix this?
  • kmz053 Oct 07, 2010
    In attempting to zero the scope out, I can move the elevation up but I need to adjust the elevation down and can't lower the elevation far enough to set zero.
  • 11,896 Answers
Hopefully it's not stripped. Turning clockwise should lower it I believe. and counter-clockwise should raise it. Or vice versa. If you turn it and nothing happens, then I would say it may be stripped out.
Posted on Oct 07, 2010
    Brigadier General:
  • 3,006 Answers
Sorry but your question is presently impossible to answer. In what way is the elevation adjustment failing to work as designed?
Posted on Oct 06, 2010
  • Obertelli
    Obertelli Oct 07, 2010
    Thanks for the additional information.
    Your problem is very common on older scopes, especially if they have spent long periods unused. The elevation and windage controls operate via what I'd describe as sliding turrets. These are precision engineered to be a very close fit and only just allow enough space for lubrication. Over time, the lubricant film can dry out, dust can work it's way in or worst of all moisture gets in and causes corrosion. It's not infrequently a combination of all three factors.
    Another cause is that there are unfortunately a large number of Chinese counterfeit Leupold scopes and accessories around. These look very similar indeed to the genuine article but are poorly made and unreliable. To check yours click here.
    Leupold are superbly designed and constructed and have sealed for life lubrication and also seals against moisture getting into the adjustment mechanism. These seals remain effective even when the adjuster dust caps are removed, but if the caps are missing or have been left off unnecessarily, dust can work its way down to the seals and damage them allowing the lubricant to dry out and moisture and dust to get in. The assembly is not designed to be user-serviceable and if you can strip it down you'll have to replace the seals and any worn parts which Leupold do not supply separately and accurate reassembly is easy to get wrong and can cause permanent damage. Leupold also don't provide details of the lubricant they use and this is important as you need a long life lube which doesn't dry out, doesn't attack the seals, and which operates throughout the full temperature range the scope is designed for.
    You have a valuable precision instrument, but it will be worthless if you attempt an inadvised DIY fix. The good news is that Leupold stand by their products. Their website states:-
    "If any Leupold Golden Ring® product is found to have defects in
    materials or workmanship, we will, at our option, repair or replace it.
    FREE. Even if you are not the original owner. No warranty card is
    required. No time limit applies."
    Obviously this will not apply if the scope has been subject to misuse or unauthorised repairs, but there's an excellent chance that you can get a free repair from them. If they do have to charge, then there really isn't much work to do so labour charges will be modest and the bill effectively comes down to the cost of the spare parts which you would have needed for a DIY repair anyway. The used value of your Leupold will also be higher if you can show buyers proof that the manufacturer has carried out servicing and repairs.
    In summary then, you may be able to perform a DIY repair but it would be foolish to do so in this instance. There's certainly no quick fix option as these tend to let go when you're miles from anywhere and stalking your prey: after all the time and financial investment in a hunting trip, anything which ruins that one vital shot is a false economy. Although Leupold will be busy as hunting season has just started, I can only recommend that you return the scope to them for servicing.
    Sorry that I cannot provide you with a realistic DIY option on this occasion but I hope that my answer has been of some use to you. Good hunting!
Leupold 3x9x40 vari-xIIc on BAR30-06. Adjusted windage as far to the right as possible and I'm still 6-8 inches off center. 12 year old scope been dead on till the middle of this season.
from my experience owning a bar they tend to lose accuracy badly after a lot of rounds are put through them especially if they are shot rapid fire style allot ( the barrel gets very hot and i am also not impressed with how the barrel is attached to the receiver) i shot mine until it just would not shoot accurately at all. (i sold it). its possible that your scope or mounts are loose defective or there may be a screw that may be broken under the mounts that you cant see.
Mar 06, 2012 | Leupold ® Rifleman® 3-9x50 mm Scope
Why does my 30 yr old redfield, widefield ,range finder accu-trac scope that has operated great for all these yrs, now I cain,t get it hit in the same zone a target. The rifle is clean and operates great...
well if the bullet hit is jumping about its all down to your scope,,,it could be that its just "lose on its mount!" or its died on you,,like the cross hair is bouncing about inside the scope so with the recoial it jumps into a new place with every shot fired there by giving you a new point of impact,,,
this can happen if the scope was wound right up or down or left or right and strain was put on the adjusters,,,you may need to buy a new scope,,,,a good "air rifle!" scope will work quite well on most full bore rifles,,,yer right i here you say!!! ok,,iv got air rifle scope's on my .303 + 7.62 + 22-250 + .357 under leaver marlin cowboy, all 3 of my .22 rim fire's and they have been on these rifles for years now,,,1000,000, of rounds fired so far, with no problems! and no drifting so far,,,
an air rifle scope is very strong you know,,,but they only cost £150,00p or less for a good one?????
ps,,,,dont buy a tesco scope there cra*y
Nov 22, 2010 | Redfield Optics
Leupold VX II 3x9x50mm scope on a rem. 270. One year old. Worked fine last year. Sighted in last week at range. Windage was dead on. Wanted to move up 1 inch in hieght at 25 yards. Tried to adjust hieght...
16 clicks is about 4" at 100 yards not 25. did you try shooting it at 100 yards? remember the scope is mounted at least an inch and probably higher than that above the barrel. at close range you will always hit low with a scope because the bullet has to climb at least an inch or more before it will be right on at 25 yards. if it is dead on at 25 it should hit way high at 100. (or the scope/ mounts are bad).
Nov 05, 2010 | Leupold ® Rifleman® 3-9x50 mm Scope
This is my first Leupold scope, I don't understand the friction adjustments 1/2 MOA dials, I need to adjust 3 inches up and 1and 1/2 to the right, I have moved the dials in the direction indicated to no...
minute of angle is not the same as 1/4" per click at 100 yards. if it doesn't click something is wrong. i would call leupold and probably try to get a replacement from where you bought it. moa is an angle value not an inch value.
Oct 23, 2010 | Leupold ® Rifleman® 3-9x50 mm Scope
In the process of zeroing the scope in I noticed that I can adjust the elevation of the scope up but can't set the adjustment down as far as I need to go in order to be sighted in. This is the first time...
There are a few things that it could be. Make sure you have the scope mounted with the elevation screw on top and the windage screw on the right side. Next, carefully check the distance of the scope from the receiver. If the mounts aren't exactly the same, the scope could be tilted upward. Try switching the front and rear mounts. Make sure you don't have either of the mounts on backwards. Make sure the scope is built for the caliber you are shooting.
If none of these fix your problem, Leupold scopes are guaranteed for life.
Oct 07, 2010 | Leupold Rifleman Rifle Scopes BHK290
I have a Leupold 3x9 VX II I'm finding that both windage and elevation adjustment screws are very difficult to turn. Is there a special tool I should be using for this or should I just be careful with a...
Leupold has a very good service policy, They'll repair it no matter what.
Send it in to them and let the experts fix it.
Here's their contact info:
1-800-LEUPOLD
Hope this helps, Mark the Gunsmith
Dec 06, 2009 | Optics
As the scope is adjusted up or down, the point of impact also moves left or right
As the scope is moved up, the impact moves down. As the scope moves to the side the impact moves to the opposite side. First, set your elevation. A bench clamp is best. After you hit paper, adjust the hairs to meet the hole. Do this repeatedly, until the bullet hits where you aim.
Sep 28, 2009 | Leupold Optics
Adjusting Range on Redfield Scope
There should be a set screw or screw that you can loosen to make that adjustment. Once you have it where you like it, just tighten it back up and enjoy you ability to make those quick adjustments when needed.
Mar 29, 2009 | Optics
Tasco scope issues with elevation adjustments
Take the lens caps ff.Then run a new Leupold under it..
Jan 16, 2009 | Zeiss CONQUEST 3-9X40 MATTE Z PLEX
Optics Logo
450 people viewed this question
Top Leupold Optics Experts
ray gallant
Bill Boyd
Are you a Leupold Optic Expert? Answer questions, earn points and help others
