Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Tv is dead LED light is flashing 9 then 5 then repeats
  • RCA Master
  • 5,138 Answers
UED has replacement Boards for this set.
1-800-648-6657
Deflection Board.
Posted on Oct 07, 2010
The sky remote will not operate the volume on my grundig gu22dvd have tried all the usual things codes etc but still doesnt work
Try an auto search with the remote, you might have already tried it :
1. press tv
2. press select and the red button simultaneously untill the LED light flashes twice
3. Then keep pressing the TV and Standby buttons one after the other (not at same time) until the tv swithches off, then press select to store the code, the LED should flash twice to confirm this.
Once you have the remote working the TV, you can get the remote blink back the TV code so you can write it down for future reference.
  • Press the TV button on the Sky remote
  • Hold down Select and the Red buttons together for approximately two seconds until the LED blinks twice
  • Key in 9, 9, 0
  • Key in 1 on the numeric keypad and count the number of times the Red LED blinks. This is the 1st digit.
  • Repeat for 2 and 3
  • Note: no Blink = 0 (zero)
Sep 09, 2014 | Grundig GU22DVDPX 22 in. LCD TV
Have grundig gu22dvd tv and can not get volume on the sky remote have tried the normal things and have code but still doesn't work
1. press tv
  • Key in 9, 9, 0
How can i set up my direct tv remote to my Haier tv
How to scan for TV codes on your DIRECTV remote
  • Make sure your TV is turned on.
  • Slide the mode switch at top of remote to "TV".
  • Press and hold the MUTE button. This is located above the number 1 button.
  • While still holding down MUTE, press and hold the SELECT button until green light at the top of the remote flashes twice.
  • Then enter 9-9-1, the green light on remote should flash twice.
  • Point remote at TV and press CHANNEL UP button. Tap the CHANNEL UP button repeatedly until the TV powers off.
  • When the TV powers off, press and release the SELECT button.
Feb 13, 2013 | Haier HL22XLE2 - HL22XLE2 22 LED-LCD TV -...
I forgot the code of my chunghop universal remote RM - 133 E my tv is JVC
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then do these procedures
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
3. ENTER 9-9-1 (two blinks on the remote)
4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
1. PRESS and HOLD the SETUP button until the red LED flashes twice.
2. PRESS 9 - 7 - 5, the red LED will flash twice.
3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
4. PRESS the button that will receive the learned function, the LED will flash rapidly.
5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through
6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
Feb 15, 2011 | RCA Universal Remote Control
My sharp Aquos LCD TV LC37D44U while watching TV suddenly witched off. Both the power led light and the OPC led light together started to flash twice, and then only the OPC led light three times, then...
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope this help in solving the problem......
Jan 27, 2011 | Televison & Video
My Sharp LC-42-D62U won't power up. The power light blinks twice, then the power light and the OPC light blink together once. any fix to this problem?
Ur Tuner signal board have problems or dead.Ur power LED light indicator stable for a few mins before the power LED light,and the OPC LED light indicators flashes?After the POWER light and OPC light indicators flashes,just push the power button again for the power recycles again.Probally have to pushes the power button 3 or 4 for power light and opc light indicators flashes,the LCD backlght will lght up and work.Sharp tv have this problems alot,very common in Sharp LCD tvs.
Apr 17, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Samsung HLP4674W - changed bulb - still no picture - lights flash
If the lamp has been replaced I would think the Lamp ballast would be most likliest followed by the color wheel and then the Digital board. You can get any part needed for your model at www.tvrepairworld.com just leave them a email they respond quickly.
Aug 28, 2009 | Samsung HLP4674W 46" Rear Projection HDTV
I want to find the Sky remote code for this Tv.
Just got an LG 42LH2000 and code 0206 works
May 16, 2009 | LG Televison & Video
Trouble Turning On
is this a lcd projection or just tube projection
Nov 15, 2007 | Sony KP-46WT500 46" Rear Projection...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
