I need to replace the keyboard on an Acer Aspire 5516 laptop. I've got the new one & want to be sure of steps needed to perform the replacement.
  • duhnewbie Oct 06, 2010
    I think someone familiar with this particular brand/model would be best-suited to explain it.
    Thank you a milliom times over.
  • 3,530 Answers
First thing you want to do is disconnect the laptop from it's power supply and remove the battery.
Things you need:
Screwdriver and flast plastic card (credit card or atm card)
Step 1. Remove the two screws from the bottom of the computer that are holding down the Acer Aspire 5516 Keyboard bezel. The bezel is the bar that sits right above all the function keys.
Step 2. Turn the computer over, open the cover and insert the credit card or guitar pick between the bezel and the computer screen. The bezel has pegs that sit in holes, you need to slowly pry up the bezel. It will make a bit of a popping noise as it is removed.
Step 3. Now hold on to the laptop keyboard from the end closest to the screen and gently pull it away from the touch-pad end and flip it over. You will see the ribbon attached to the underside of the Acer Aspire 5516 Keyboard. There is a little plastic connector holding the ribbon to the computer. To unlock it, carefully pull up on the two tabs; one located on each corner of the connector. Be very gentle when you do this as this is the one part that gets broken the most often when changing a keyboard. The ribbon will now be released.
Step 4: Carefully pull the ribbon out of the connector and remove it along with the entire Acer laptop keyboard.
Step 5: To insert the new Acer Aspire 5516 Keyboard, place the board face down so you have easy access to the ribbon. Make sure the keyboard is lined up so when you flip it back over the keys are in the correct position. Keep the ribbon straight at all times; twisting it could damage it. Place the ribbon in the connector; it only goes in one way. Once in place, push down on the connector tabs to lock it. Now flip the keyboard over and slide it down toward the touch pad and take the bezel and line the pegs up with the holes and push it in place. Then turn the computer over and replace the two screws you removed from the bottom. You can now power on your computer and see if the Acer Aspire 5516 Keyboard works. If it is not working, more than likely the ribbon was not inserted properly.
All the best!
Posted on Oct 06, 2010
  • 6,993 Answers
Follow the below steps to successfully perform the keyboard replacement in your Acer Aspire Laptop:
  1. Ensure the laptop is fully powered off, unplugged from the wall, and the battery taken out.
  2. Turn the laptop over. On some models icons indicating which screws are attached to the keyboard are displayed. If not, you may have to "eyeball" it if you can't find a breakdown for your model online.
  3. Remove those screws with a T-8 or Phillips screwdriver.
  4. Turn the laptop back over and open it up. Check and see if the keyboard is tucked under any plastic pieces. If so, find if those plastic pieces are screwed into anything, and unfasten them as well. If not, it probably uses clamps that can easily be removed.
  5. Remove the plastic pieces carefully with a toothpick or plastic pick if there is any in the way.
  6. Unscrew any screws at the top (if necessary) and remove the keyboard itself from top to bottom. You'll notice that the keyboard is connected with a thin, but wide, data cable to the system board at the bottom.
  7. Take that same pick and lift the plastic connectors that hold in this data cable in place.
  8. Carefully remove the data cable. Now the whole keyboard should be free.
Good luck
Aspire 5251-1513 ac adapter broke
Don't do that if you are not good for repairing laptop. That will damage your laptop and be dangerous.
Either repair your laptop adapter or buy a new adapter. If you can't let your laptop charger repaired by yourself, you had better replace a new charger.If you are on a budget on a new charger, consider buying a third party charger:Intocircuit Acer Aspire 5251 AC Adapter 65Watt 19V 3.42A
Sep 30, 2012 | Acer Aspire 5241 5251 5332 5334 5338 5516...
Hi i have got a new keyboard and wish to change it on acer 7520
taken from http://www.batterycentury.com/acer-aspire-7520g-502g25mi-keyboard-p-152819.html
Acer Aspire 7520G-502G25Mi Keyboard Repair and ReplacementAre you considering laptop keyboard repair? You might think twice if you happen to be the lucky owner of a laptop, because replacing the keyboard rather than repairing it could be a lot less expensive. Laptop keyboard replacement on this particular model is very easy and takes just a few minutes. Here is a quick Acer Aspire 7520G-502G25Mi Keyboard repair tutorial with step-by-step instructions. Once you have purchased the new keyboard, all you need to replace the old with the new is a screwdriver and something plastic, flat and thin like a credit card or guitar pick.
Step one: Remove the two screws from the bottom of the computer that are holding down the Acer Aspire 7520G-502G25Mi Keyboard bezel. The bezel is the bar that sits right above all the function keys.
Step two: Turn the computer over, open the cover and insert the credit card or guitar pick between the bezel and the laptop screen. The bezel has pegs that sit in holes, you need to slowly pry up the bezel. It will make a bit of a popping noise as it is removed.
Step three: Now hold on to the laptop keyboard from the end closest to the screen and gently pull it away from the touch-pad end and flip it over. You will see the ribbon attached to the underside of the Acer Aspire 7520G-502G25Mi Keyboard. There is a little plastic connector holding the ribbon to the computer. To unlock it, carefully pull up on the two tabs; one located on each corner of the connector. Be very gentle when you do this as this is the one part that gets broken the most often when changing a keyboard. The ribbon cable will now be released.
Step four: Carefully pull the ribbon out of the connector and remove it along with the entire Acer laptop keyboard.
Final step: To insert the new Acer Aspire 7520G-502G25Mi Keyboard, place the board face down so you have easy access to the ribbon. Make sure the keyboard is lined up so when you flip it back over the keys are in the correct position. Keep the ribbon straight at all times; twisting it could damage it. Place the ribbon in the connector; it only goes in one way. Once in place, push down on the connector tabs to lock it. Now flip the keyboard over and slide it down toward the touch pad and take the bezel and line the pegs up with the holes and push it in place. Then turn the computer over and replace the two screws you removed from the bottom. You can now power on your computer and see if the Acer Aspire 7520G-502G25Mi Keyboard works. If it is not working, more than likely the ribbon was not inserted properly.
May 16, 2011 | Computers & Internet
How do I enable Bluetooth adapter on my Acer Aspire 5516 laptop?
if it's anything like my 7720z, then your laptop should have an activation button at the top bezel, between the keyboard and LCD, where the power button is. It's logo is an ellipsis with some scribble inside.
Jan 17, 2011 | Acer Aspire 5516-5063 Notebook
I'm trying to open up an Aspire 5516 and I have all the screws out I think but it won't open up.
Go to Youtube and search under Acer 5516 cpu upgrade. There is a video showing you how to open an Acer 5516.
After you take out all the screws on the bottom. You still have to take off the keyboard, the display screen, the battery, the memory, the harddrive, the dvd drive, and the modem.
Feb 15, 2010 | Acer Aspire 5500 5570-2609 Laptop
Acer aspire 5516 replace keyboard how to
did you snap the strip cover off the top? The bar that has the power button and everything? Once that comes off the keyboard should be able to be disconnected and replaced easily.
Jan 19, 2010 | Acer Aspire 5610-4648 Notebook
Copy of acer aspire 5516 manual
I think this is the one. http://www.user-guides.co.uk/cddownload/Acer/AcerAspire/Acer-Aspire-5500-Service-Guide-Manual-Disassemble-Remove-Replace-Repair-50381.html
Jan 12, 2010 | Computers & Internet
Acer Aspire 5101 AWMLI. Keyboard & usb ports non functioning
I would check out ebay. I have seen them on there.
Nov 23, 2009 | Acer Aspire 5100 Notebook
Need to replace aspire 4330 keyboard.
Not that I'm endorsing this person...but heres 1 example. The price is reasonable as well.
http://cgi.ebay.com/New-Acer-Aspire-4730-4930-4330-Keyboard-&-Skin_W0QQitemZ170350771635QQcmdZViewItemQQimsxZ20090629?IMSfp=TL090629201003r30405
Jul 20, 2009 | Apevia Laptop Keyboard for Acer Aspire...
Computers & Internet Logo
161 people viewed this question
David Payne
David Payne
