Question about Konica Minolta bizhub C250 All-In-One Laser Printer
Reset fuser My fuser on the bizhub C-550 says Replace fuser and has stopped the machine. error message 50_45C-km I have ordered a new fuser but I need to finish a job. Is there any way to get the machine to start running while a I wait for a new fuser 2-3 days.
    Scholar:
  • 60 Answers
Unforunately once a fuser goes, you are out of luck. I don't know of any printer that will continue to work once the fuser has gone bad. It's best to keep an extra fuser handy for business-critical printers.
Posted on May 28, 2008
  • 44 Answers
You can reset the fuser. On the left side of the fuser behind the side cover (3 screws) you'll see a tiny fuse wrapped in a clear tiny tube within the group of wires. Go to Radio Shack and buy one and solder it over the old one. The fuse blows to start the life cycle.
Posted on Nov 29, 2009
How do i reset fuser unit error message on bizhub c253
TROUBLE RESET
FIRST, If this code comes back. Have a technician look at it DO NOT CONTINUE TO RESET the code!!!! AS this is for the Hot Part called the FUSER. It can catch on fire! And that will ruin a perfectly good day!!!!
1. Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
Jun 27, 2016 | Konica Minolta Bizhub C253 Copier
How do i re-set fuser unit replacement message on bizhub c253
SIR/MAM
TROUBLE RESET
Develop ineo 501, machine stopped, showing " have the fusing unit replaced soon, contact the service representative" -no error code. There is also "license management error occurs" but this promt was way...
that unit is manufactured my konica minolta. it is a Konica Minolta Bizhub 501 and will use the same fuser even though the image units, toners, and transfer belt have to be chipped for the ineo. There is a picofuse in the fusing harness that blows as soon as it is installed and that starts the fuser life counter. the counter is reset when a new fuser (or new fuse, if the fuser is still good) is installed. You will need to replace the fuser for the message to go away.
Jan 05, 2015 | Office Equipment & Supplies
How to reset error c3451 in konika minolta 215
clear/stop held down and turn the machine on, IF THIS CODE COMES BACK DO NOT RESET AGAIN IT IS POINTING TO FUSER UNIT IT CAN CATCH ON FIRE GET TECH OUT AND REPLACE THE FUSER
Feb 14, 2014 | Konica Minolta bizhub 200 Printer
My kyocera km-2550 multifunctional copier has started showing a error message "call for service c6000" and a phone number in asterisks. kindly advice on what to do or if there any online help.
This is fuser unit error code, you can try to reset it might work, but if the erorr code came back then you need to change the fuser unit.
In order to reset this code: follow those steps
on the panel press 1087 1087
The screen will change to service mode
on the panel again press 163
now look at the screen and you will see Excute.
Select Excute and press the Start key.
The Machine will rebot or it will asks you to turn it off and on.
After the machine load again, it should be good, if the Error came back!! Then change the Fuser Unit.
Oct 13, 2011 | Kyocera Mita KM-2550 All-In-One Laser...
We have a Bizhub C250, yesterday it gave us message that all the color toners needed replacing. After replacing and the warm up it shows an error message 'C-2553'; we thought this was another...
This issue refers to the fuser core, I feel its not the toner that is the cause at this point. You will need to order a maintenance kit for this machine. The kit includes the fuser core and the feed tires, the process roller. This kit should solve your issue. Now there could be somthing in the Module but at this time I would lean on a kit first.
Let me know if you willing to make this step.
you might also have to replace K (black) IU (Item #A0DE02F )
Sep 30, 2011 | Konica Minolta bizhub 350 All-In-One Laser...
My machine says fusin unit need to be replace i replace ir already and nothing the message still in the scren waht can i do\/
you need to replace a whole new fuser or come with full new PIKO fuse to reset the fuser counter,
its useless if you change an used fuser,
Mar 14, 2011 | Konica Minolta bizhub C250 All-In-One...
I have a Konica Minolta bizhub D2510F it gives me this error C0501. after searching around I found out that this error is a Fuser error. I replaced the Fuser and the PhotoConductor but I still get the same...
The error has to be manually reset. Here is what I found from the official procedure. Hope it works. How to clear a fuser error code (C0500, C0501, C0510, C0511, C0520, C0521). Solution To clear the fuser error code, perform the following after correcting the cause:
1. With power ON, open the front door and locate the small, rectangular hole below the imaging unit removal tool.
Note: It is not in the same location as the models 7915/7920.
2. Insert a suitable object into the hole to actuate the reset switch .3. The code should clear and a message to close the front door should appear.
Feb 03, 2011 | Konica Minolta bizhub 350 All-In-One Laser...
Have a BIZHUB 550 with a C-3724 error on it. I had to select the 450 below as the 550 is not listed.
Fusing abnormally high temperature detection
The fuser section reached a temperature outside of safe operation. You can reset the error by: Turning the main switch off, leave the operation panel switch on, hold down the utility/counter key and turn the main switch on. As the screen loads you will see a black dot in the top right corner, at this point you can release the utility/counter key. The machine will take a minute to load. When the screen loads you will have a key that says "Trouble Reset" press it and you will get a "OK" message. Turn the main power off for 10 seconds and turn back on. If message returns you must replace the fuser. Attempt Trouble reset again at your own risk!! Fusers are a Fire Hazard
Apr 27, 2010 | Konica Minolta bizhub C450P Laser Printer
Put in newer fuser unit but machine still says to replace
If you want to clear the fuser message you have to be sure you replaced the fuser web. Then go to 25 => counter clear(items 13)=> Clear fuser counter or 36=>counter clear(items 8)=>Clear fuser counter.
May 28, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
545 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
