Sir/ mam, i want intel 845WN bios flash(bin) file...
  • 32,281 Answers
Normal 0
You can download the motherboard BIOS from Intel WEB site.
Please click on this link and select your model motherboard : -
http://downloadcenter.intel.com/default.aspx?iid=gg_support-au+home_downloadctr
Posted on Oct 06, 2010
Flash bios file bin
here you go https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+945+Express+Chipset+Family+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+D945GCCR&ProdId=2766&LineId=2424&FamilyId=36
Jan 27, 2014 | Intel D945GCCR Motherboard
Tip
Intel 845gvsr mainboard no display problem
this problem is normal because of the BIOS chip failure normally
symptoms:
when u get ram out and start computer it gives beeps and when u put back the ram and power on PC it gives no beep no display.
Fix the problem:
tools required:
1. hot air gun
2. 512kb fresh bios chip/ if the old chip is right then no need of newer one
3. p3 mainboard (with the BIOS socket) for reprogramming the chip
4. dos bootable hard disk
5. bios bin file.
have not the file ,
don't worry: this file can be made from the bios chip of a working mainboard using the bios flash utility.
flashing software: best is Uniflash.
Procedure:
1. with hot gun, get the bios chip out of the board,
2. reprogramme the chio with correct bin file.
3. put the bios back
Reprogramming:
copy the file in dos bootable hd
run the hdd on p-3 board
pull the bios out of running board (with slight care)
put the 845gvsr bios chip in place of p-3 bios
run uniflash and flash the bios
power of p-3 computer and get bios out
for how toprogramme bios chip : check the page
http://www.pcnineoneone.com/howto/biosflash1.html
on Jan 24, 2010 | Computers & Internet
Flash bios file bin
go to intel then support then download bio
D946gzis bios.bin file i need pls help
You need to update your bios interface and to do so, CLICK HERE. It's a PDF file and all you need to do is to click on the 3rd topic which is for the BIOS Update and what you need to do are as follows:
Updating the BIOS with the Intel® Express
BIOS Update Utility
With the Intel Express BIOS Update utility you can update the system BIOS while in
the Windows environment. The BIOS file is included in an automated update utility
that combines the functionality of the Intel® Flash Memory Update Utility and the ease
of use of Windows-based installation wizards.
To update the BIOS with the Intel Express BIOS Update utility:
1. Go to the Intel World Wide Web site:
http://support.intel.com/support/motherboards/desktop/
2. Navigate to the D946GZIS page, click "[view] Latest BIOS updates," and select the
Express BIOS Update utility file.
3. Download the file to your hard drive. (You can also save this file to a removable
USB device. This is useful if you are updating the BIOS for multiple identical
systems.)
4. Close all other applications. This step is required. Your system will be rebooted at
the last Express BIOS Update window.
5. Double-click the executable file from the location on your hard drive where it was
saved. This runs the update program.
6. Follow the instructions provided in the dialog boxes to complete the BIOS update.
Feb 16, 2011 | Intel D946GZIS Motherboard
Hello, I have intel desktop board 845wn mother board and bios version is ''HV84510A.86A.0029.P07'' Actualy i need to update bios. So I downloaded file from below site....
Hello!
I must write again, because my conection is fall.
Upgrade bios first time is very hard, and upgrade bios is always dengerous.
First read from the site what you give with upgrade bios, and read all about upgrade.
The best solution is upgrade from the floppy, because you can save present bios, if something move bad.
In some case some part of motherboar isn¨t compatible with win. xp, and upgrade bios is solution for some bug on motherboard (broken sound, better CPU, better grafik card,ide and usb ).
It is question can you give anithing with upgrade bios in your case.
But if you want upgrade, do this:
X:\hv86ap15bi.exe (X - name drive in comp. from you boot )
Than upgrade give you a possibility to save your present bios, if you have a floppy save to them.
When you save or not bios then go far, and when is done you need to restart you comp.
Good luck.
Nov 08, 2009 | Computers & Internet
I need to know how to bios update
That is the right procedure. The next step is to type the path of the BIOS file. Have you tried D:\(bios file name)?
Nov 06, 2009 | Computers & Internet
I want bios driver (bin file) for my intel destop board d915gav/d915pgn
The BIOS bin file is a BIOS upgrade file. It is used to flash the BIOS to upgrade the BIOS version.
This file is has to be downloaded from the motherboard manufacturer's WEB site.
Jul 24, 2009 | Intel D915GAV Motherboard
Gigabyte Motherboard wont flash bios
your bios has been corrupted.
The AWARD BIOS has a similar procedure to AMI. To recover an AWARD BIOS you will need to create a bootable floppy diskette and add the desired BIOS file (we recommend using the most recent). Award BIOS's generally are in .BIN format, where as AMI was .ROM format. You will also add an AWARD flash utility (usually awdflash.exe) and an AUTOEXEC.BAT file.
The AWARD BIOS does not automatically restore the BIOS information to the 'system block' like the AMI BIOS does. You will need to add the commands necessary to flash the BIOS in the AUTOEXEC.BAT file. The system will run the AUTOEXEC.BAT file, which contains the flash instructions.
Note: 12345678.BIN represents the name of your BIOS.
Step by Step:
1. Create a bootable floppy diskette or bootable dos cd /usb drive
2. Copy the BIOS file and flash utility to the disk
3. Create an text file with any standard text editor and add the following lines
@ECHO OFF
awdflash 12345678.BIN /py/sn/f/cc/r
Exchange the awdflash with the name of whatever flash utility you are using, and replace the 12345678.BIN with the name of the BIOS file you are using. The parameters are explained here:
py = program yes
sn = save no
f = flash
cc = clear cmos
r = reboot
Remove disk and restart computer
If you found this useful , please rate below
Kind Regards
1234s282
Jul 02, 2009 | Intel Gigabyte GA-8S648FX-RZ Socket 478...
NO DISPLAY , BIOS DAED, HOW TO FLASH IT HELP ME . . .
Intel's web site for D845GLVA, click on the link;
http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=947&OSFullName=Windows*+XP+Home+Edition&lang=eng&strOSs=45&submit=Go%21
The site above includes Bios files, drivers & manual.
Intel's Instructions sites;
BIOS Update Instructions for Intel® Desktop Boards
http://downloadmirror.intel.com/10506/ENG/BIOS%20Update%20Readme.pdf
Intel D845GLVA
Desktop Boards, Bios update instructions.
http://support.intel.com/support/motherboards/desktop/sb/CS-022312.htm
The .html site has video you can watch.
Mike
May 03, 2009 | Intel Desktop Board D845GLVA...
Computers & Internet Logo
David Payne
David Payne
