Question about LG WFT1071TP Top Load Washer
I have LG wfc5856tc. One day it filled with full of water and switch pannel not responded. So i switched it off and switched it on. But it's not power on. Please help me Thanks
Posted on Feb 26, 2011
LG Turbodrum DD 8.5kg WT-R852 washing machine, will not completely fill with water to water, to initiate the wash cycle, wash process stops there.
THE WASHER IS OBVIOUSLY HAVING A PROBLEM DETECTING THE WATER LEVEL? IT DETECTS AS FULL WHEN ITS NOT AND THEN GOES INTO DRAIN CYCLE? THE FILLS AGAIN? I would suspect the water pressure switch but if it was detecting a full cycle it would sent it into wash cycle? the water inlet valve only allows the amount of water it is told to send in and does not control the amount or drain cycle. Im not sure here but Im thinking maybe the water level switch may be flawed, the one that has low-medium and high? all these can be checked with a multimeter
Mar 01, 2015 | LG Washing Machines
How to fix a GE Topload Washer leaking down the inside center of the machine back pannel?
check the tube that goes from near the bottom of the tub up to the level control switch
Jul 09, 2017 | Washing Machines
My td c700e no longer collects water in the condenser but comes out of the bottom. why?
at bottom on the back pannel should be a trough that water collects in.............there should also be a micro switch and a float.......when float rises it trips micro switch that starts pump to send water to the collectin tank.........
cheers
Jul 31, 2014 | LG Dryers
Lg tromm wm0642hw
I'm guessing it has a float switch that shuts the water off when its full, and if it were bad it would not stop filling. Until the float switch tells the valve to close its also is not going to tell the pump to come on.
Mar 21, 2014 | Washing Machines
Water won't turn off
Sounds like the pressure switch is not working.two reasons for this the tube that operates the switch to turn off the water sits outside the drum and is normally full of air.as the drum begins to fill it increases the air pressure in the tube to the point where it trips the switch to turn off the water input.if the tube fills with water it will not operate the turn off part of the operation.you either check the tube for water by open inning the top and disconnecting the rubber hose from the drum and empty out any water.this should make it operational again.if not then it is probably the switch itself.easily replaced by parts obtain through eBay for your model machine.not difficult to do, tutorials on YouTube are available on this topic.
Mar 08, 2014 | LG WM1814CW Front Load Washer
LG WM2277HW washer not filling with water. All filters and water pressure checked, still not enough water to get the clothes clean. Any ideas?
PRESSURE SWITCH
Your pressure switch stops the water and allows it to start the next cycle. It's a switch either in the control panel or at the top of the tub with a small tube connected to it which goes down between the inner and outer tub. As the water level increases the air in the tube is compressed until there is enough pressure to "make the switch" stopping the water from filling. This tube can get clogged and the switch won't work. Remove the tube and clean it out. Blowing on the tube when it's still connected to the switch will make the switch if it's working and clear.
Water inlet valve
If it fills with water and starts the cycle and the water keeps running in then your water inlet valve on the back where the water supply comes in is sticking. It needs replacing.
Mar 24, 2011 | LG WM-2277HW Front Load Washer
Machine fills up with water constantly
Check for a faulty water level/pressure switch. This is a diaphragm like device with a small plastic tube (which you were blowing into) attached between the switch and the bottom of the washer's outer tub. As the water level rises, so does the pressure on the air in the plastic tube and when it reaches a certain leve it activates the switch to shut off the water. Make sure there is no obstruction in the tube and that it is not damaged in any way. The switch can be tested using a multimeter or ohmmeter and checking continuity. A lack of continuity will mean a bad switch. Sorry for your trouble and I hope this helped. Best wishes.
Oct 15, 2009 | LG WFT1071TP Top Load Washer
LG TROMM WM1814CW won't stop filling. Says
Over flow error
Water is overflowing , (water level frequency is over 213). When FE is displayed, the drain will pump out automatically.
Replace the Overfill pressure switch(AKA-Switch assembly sensor swi)
Jul 12, 2009 | LG Washing Machines
Kenmore washer stopped full of water, will not click etc
possible bad lid switch..if switch cks ok ck for wiring connection on motor
Nov 15, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Low water level
One of 2 problems is causing this.  Either you have a bad float switch which is located on the left side of the dishwasher, or you have a water leak and is losing water when it is in the wash mode.  You will need to have it checked by a qualified LG technician.
Jul 21, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
LG WFT1071TP Top Load Washer Logo
329 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
