New Computer; Windows VISTA; Scanner Canon DR2580C drive loaded from Internet. Capture Perfect 3.046 loaded from INternet. Att4empting to scan a document produces a info box with the words "Scanner is not found check cable" The scanner is connected properly using USB, plugged in and turned on. I have downloaded the Cannon Scanner and the Capture Perfrct 3.046 from the Canon site. HELP
  • 103 Answers
go to device manager and make sure that the device is working properly because if the driver for the scanner may be missing and you will have to acquire it to use your scanner. if you need anything else please feel free to leave a comment.
please rate me. thank you.
Posted on May 28, 2008
Capture barcode at scanner Canon Dr 9080C
You will need to purchase the CD "Canon Barcode Module III" and install it on your computer: Mfg. Part: 1922B001
Then you can select it in Canon's document scanning software/Capture Perfect.
Scan-R-Store
Dec 10, 2013 | Canon DR-7580
Canon DR-1210C scanner does not work with Capture Perfect software
you can download and Install Twain driver for this model and you can scan from Any Image Editor like photoshop and Acrobat PDF editor
download link http://www3.canon-asia.com/downloads/drivers/dr/DR1210C/DR-1210C%20Driver1.1.zip
Feb 06, 2013 | Canon Office Equipment & Supplies
Unable to install canoscan N650U on windows 7 TOSHIBA
I have many years repairing Canon scanners so here is my suggestion for you.
First I would google Canon CanoScan N650U drivers, it should pull up Canons website and take you directly to the newest drivers avalible they are free. Then I would disconnect your scanner from your computer and install the latest drivers. Also while your on Canon's website download capture perfect its free and it works with your scanner for scanning purposes. I would then install the drivers and then hook up the cable to your computer. At that point you should get a pop up saying new drivers are being installed. Once there installed reboot your computer and you should be ready to start scanning.
I hope this helps you out.
Mar 28, 2011 | Canon CanoScan N650U Flatbed Scanner
The cannon DR 2580-C resinstalled to new computer
Capture perfect is scannig software, it is not a driver. You can download driver from this site. http://www.usa.canon.com/opd/controller?act=OPDSoftwareAct&fcategoryid=2341&modelid=11360
Install driver and use Captureperfect to scan.
S. Mohan, Chennai, India
Feb 21, 2009 | Canon DR-2580C Path-Through Scanner
Transfer scan settings from one computer to another?
You need to do it only once! Capture perfect remembers the previous setting. If you install Capture perfect in another system it will be only in the defalut mode. You cannot transfer the settings
S. Mohan
Dec 02, 2008 | Canon DR-7580
Missing the disc
Well the good news is you don't have to pick up a disc :-) . You can actually download the driver for the scanner here (the driver is the software that allows the computer to see the scanner)
http://www.usa.canon.com/opd/controller?act=OPDSoftwareAct&fcategoryid=2341&modelid=7181
On that page you want the second one down (2080INF.exe)
Here is what you are going to need to do:
  1. Download that file
  2. Double Click on the file and then hit "Run" followed by "Unzip"
  3. Click the "Start" button
  4. Click "Control Panel"
  5. Double Click "Scanners & Camera's"
  6. On the left menu (it is the blue menu on the left) select "Add Imaging Device"
  7. A wizard will now come up , click "next"
  8. It will now ask what kind of scanner/camera you want to install, on the bottom right is a button that reads "Have Disk" ; click that
  9. Hit "Browse"
  10. Navigate to the folder where you un-zipped the original download to. By default it went to "C:/DR208C/INF" - In that folder you will see a file named "CANODR2K" , double click it.
  11. Hit "Ok"
  12. Select how it is connected (USB or SCSI)
  13. Finish the wizard
And thats it! Now your scanner is installed on the computer and you can scan......
Also on the original CD is a software called "Capture Perfect" , which is the software that is used for actually scanning with your scanner , you can download that here: http://www.softpedia.com/get/Multimedia/Graphic/Graphic-Capture/Capture-Perfect.shtml
Oct 02, 2008 | Canon DR 2080C Path-Through Scanner
Incompatible with Vista 64-bit
Eine Lösung die geht ist ein 2. kleinPC mit winXP32 den über Remotedesktop anbinden. Das ist komfortabel und funktioniert garantiert immer.
Aug 26, 2008 | Canon DR 2080C Path-Through Scanner
Problem with Canon DR9080C scanner and Capture Perfect 3.0 softwere
Do you have enough disk space? Check if your C; drive has enough space. Normally C: is used as 'scratch area'. Try scanning intoa different location.
S. Mohan, Chennai
Jun 18, 2008 | Canon DR-9080C Path-Through Scanner
I have VISTA, A DR2580C and Capture Perfect 3. When I select Capture 3 a message comes up "Scanner is not found check cable" I previously installed Capture Perfect 3 then upgraded it using the Cannon...
Hey...dont get me wrong...we all make mistakes...am sorry again for that mistake...
if you are intrested try this way again...
> goto device manager > right click that is yellow > select uninstall driver > and repeat it to the other named something scanner
and > do again the installation again (what i told you in chat) for all yellow flags > restart windows >
ask me any prob at my profile? Roshan89...
May 21, 2008 | Canon Office Equipment & Supplies
Canon Unknown Error
Please run Scandisk on your computer. If the problem persists even after this, reinstall OS. You need to reinstall other applications also.
S. Mohan
Feb 07, 2008 | Canon DR-2580C Path-Through Scanner
Computers & Internet Logo
53 people viewed this question
David Payne
David Payne
