Question about Stanley 77 115 Intellisensor Plus Stud Sensor
The ac continues to blink on my sensor 100? its not supposed to keep
My genie garage dooropener is blinking red on the opener motor. It is suppose to be blue.
1. If both round and long LED's are blinking, unplug the opener motor for five seconds, and replug. If the lights go back to normal, it was just a program error. If they both continue to blink, it's probably not user-serviceable.
2. If the round LED is blinking and the long LED is off, it is usually the door sensors that are obstructed or knocked out of line.
3. If the Long LED is blinking and the round LED is off, it is usually a bad roller or hinge that won't let the door move freely, something stuck in a track or a bent track.
Jul 09, 2017 | Building Materials
Radiator fan continues to run. Fan won't shut off when engine is turned off.
Its supposed to keep running even with the car turned off if the car is still to warm, they work off a sensor,, now if it keeps running way to long,, the sensor is bad,, ( if you have to pull the fuse to make it quit after a while,, then check the relay , and then the sensor )
Sep 02, 2011 | 1995 Honda Accord
The HP Photosmart R707 Viewfinder video light keeps blinking in red even when the Camera is switched off.
If you actually mean the power light, that is supposed to blink when you plug it in and it is charging.
If you mean the one in the viewfinder, that is an error condition, and an error message is supposed to show up in the back image display viewer.
There may not be enough battery voltage left to display, so plug it into the AC adapter to be sure.
Aug 14, 2010 | HP Photosmart R707 Digital Camera
2007 yukon tpms keeps blinking to check tire pressure
The TPMS is a pain in the you know what. Have you changed tire sizes? There could be a bad sensor and may need replaced. We continually get problems all the time with the TPMS. We have reset then they reset again.
Sep 11, 2009 | 2004 GMC Yukon
Door ajar lights blinking. Stops when A/C and radio turned off.
Don't suppose you have a custom stereo with big woofers by chance?
Does blink when windows are down? Blink to the beat of bass?
I'm suspecting Interior pressure builds up when AC fan on, and windows closed. You can try adjusting your door catches on door posts in slightly to keep doors closed more tightly, if I'm on right track.
Jun 28, 2009 | 1992 Honda Accord
AC Blows Hot Air while stopped at light
usaully when a car does that its a vacume hose bad,,
May 17, 2009 | 2010 Honda Insight
Laptop won't turn on, battery and power lights keep blinking
Looks like you are having a no post situation, generally a failed motherboard. Replacement motherboards are available on Ebay for around $100
Apr 06, 2009 | Dell Inspiron 5150 Notebook
Water does not drain completely, mostly but not completely and just stays there Maytag Quiet Series 100
If the machine has a auto sensor or auto clean cycle it is supposed to keep water in the bottom. The sensor has to stay wet for it to work properly. My Maytag drains, then fills slightly to do this.
Jul 03, 2008 | Maytag Dishwashers
Sony Vaio Laptop Battery - increase charge
Hi Sony battery,
did you mean to say that you battery only remain at 50% and never exceed this amont ??
Normally all the notebook if you keep charging it should come up to 100%, but only a few case that will face the problem
1.problem with battery itself.
2.problem with ac adapter (I face very much problem here not continues power suplly)
3.problem with motherboard the module that deal with charging battery.
Goodluck,takecare.
May 08, 2008 | Sony VAIO PCG-K35 Notebook
Red blinking light on my acs-100
I've actually no idea but instead of troubleshooting it you might want to try to reconnect it by following this guide: [url=http://download.adaptec.com/pdfs/user_guides/acs_100_ug.pdf]ACS 100 User Guide[/url].
Sep 19, 2005 | Adaptec 1 Bay ACS-100 (2177400) USB 2.0...
Stanley 77 115 Intellisensor Plus Stud Sensor Logo
96 people viewed this question
Top Stanley Measuring Tools & Sensors Experts
Lawrence Oravetz
Vernon Taylor
Steve
Are you a Stanley Measuring Tool and Sensor Expert? Answer questions, earn points and help others
