Question about LG WM1812C Front Load Washer
Machine washes but will not spin and finish the cycle, has OE or DE on screen ??
    Scholar:
  • 135 Answers
OE and DE means Open Error and Door Error.
a sensor or wire is loose or broken.
the next question is who is going to do it ? you, a repairman or service center ?
Posted on Oct 06, 2010
LG wm1832CW Front load washer , error code OE and shut down, drain cleaned pump ok, ?
Yes, could be that the pump has dropped down on the efficiency.
check this link for tips to reset or rework the pump
Click on Pump
Jan 15, 2013 | Washing Machines
Every other load we have OE coming up, also the drowm will not spin
LG washing machine error code - OE
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc
Nov 28, 2010 | LG WM2277H Front Load Washer
My washer machine keeps displaying OE. We have checked all the hoses, and everything seems fine. Will not empty water or finish cycle
Error Message : the OE is (outlet error).
1) If OE error occurs, clean & empty the filter.
2) If this doesn't solve the problem, and it won't drain, then provided that you can hear the pump spinning (the normal whirring the machine makes that should be accompanied by the water going down the drain) then the hose pipe leading to the pump is probably blocked.
I'm sure a lot of dodgy service people might just charge you for a new pump & labor, but if you can hear the pump spinning then you just need to remove the blockage.
Aug 12, 2010 | LG WM-1832C Front Load Washer
Getting a E1 code one the front panel and will not finish the cycle
There is not a reference for an E1 error code.
The listed LG error codes are:
IE, UE, OE, FE, PE, dE, tE, LE, EE, and PF.
May 18, 2010 | LG WM2016C
Washing machine problem
"dE"
- Lid open error Lid is open during wash cycle. Close lid.
· Check wiring harness
· Check lid switch
· Check unbalance switch
· Check circuit board "OE"
- Water overflow error Water supply does not stop after sensing an overflow condition. Turn off household water supply to washer and unplug power cord.
· Check water inlet valve
· Check pressure sensor switch
Apr 30, 2009 | Washing Machines
LG washing machine keeps stopping and it says OE
The LG error code OE simply means “the pump is blocked”. Presumably the water isn’t being emptied properly. Check the exit hose, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Apr 11, 2009 | LG WM2042 Front Load Washer
Tromm lg washing machine keeps having an OE error and the machine shuts down. We have cleaned the little filter on bottom front and also cleaned the little black drain hose, used a vac pump so **** out,...
The OE error is really a DE error. (Drain error) Drain all water out of machine as you have done before and remove the square recess around the filter by removing one screws and using a putty knife from the side of the recess. Now you will be able to remove the two more screws holding the pump to the front housing. Tip machine back (best to just lean it against an object like a wall that's about a foot and a half away) and reach under machine to remove pump. Pump is held by a plastic tab which should be depressed to release pump. If you take off wires to pump and the two bigger hoses you can pull the assemble completely out. Take the three screws out which are holding the pump motor on. Replace pump motor with a new one. Reinstall pump assembly.
If you list a model number I can look up a part number.
Not too sure how you got water to come out vent, as machine should not spin with water in drum. Possibly you may also have to clean out the water level hose. Remove four screws holding back cover, take off cover, remove and clean out thin black hose from bottom back of machine and the nipple it was pushed onto.
Dec 03, 2008 | Washing Machines
LG WM1812C Front Load Washer Logo
98 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
