Question about Acer Aspire One PC Notebook
How much does it cost to repair abroken screen it is punctured so will need to replace
    Master:
  • 633 Answers
If u are going to Acer u will be charged $99.
If u are doing the repair from outside, just the LCD panel will cost u near to that amount.
Posted on Oct 06, 2010
  • Acer Master
  • 11,800 Answers
The replacement screen - about $125. The labor at the shop to replace it - about $100 - but you can do that yourself: all you need is a screwdriver.
  • Acer Master
  • 32,281 Answers
Replacement LCD screens are available on the Internet. Here are a few WEB sites for you to contact :-
Normal 0
www.lcdparts.net
http://www.nylaptopparts.com/
http://www.ccflwarehouse.com/
Normal 0
http://www.yallstore.com
http://www.shope2.com/
How could i fix my ref i was able to puncture it? .. how could i fix it?
you cannot fix a punctured evaporator coil. The cost is not economical and the repair is unreliable. best consider another fridge.
Jun 20, 2014 | Kelvinator 12 cu. ft. / 340 liter Chest...
Is it possible to repair a small puncture in the freon line inside a small fridge
The hole can most likely be fixed with epoxy and a filter drier added to the refrigerator by an experienced refrigerator technician but the problem involved will be the cost to have the repair done. It would be less expensive to replace the refrigerator, Thanks Sea Breeze
Dec 04, 2012 | Haier Black and Decker 2.7 Cu. Ft....
My grandaughter has a puncture on her bicycle. I have a puncture repair kit but no instructions. Any ideas.
For $7-8 you can get a whole new inertube. That is what you should do. A patch kit should only be used when you are out on the trail miles from home and you get a flat. If you dont know how to do it, let a bike shop do it. You can damage the rim which costs $70-80 to replace if not done properly.
Jul 24, 2011 | Cycling
Will trying to chip away ice in the small freezer part i punctured something. How will this effect the fridge? Will the fridge still stay cool, and just the freezer part not work, or do i need to buy a...
If you've punctured a section that allows the refrigerant gas to escape, the following can happen:
1. If you switched the unit off immediately after, then the puncture can be sealed, and the unit 're-gassed'.
2. If the unit was left to run, there is a real possibility that the compressor could sieze, resulting in repair costs that would exceed replacement costs.
Jun 08, 2011 | Refrigerators
I have a 2006 Pontiac Vibe. The AC went out. When I took it to a repair shop, the guy told me that it looked like debris was puncturing the condensor. After 1 hot summer and spending $600 to replace the...
My experience with A/C Condensors is that you can take it to a Radiator Shop that welds aluminum and they can repair it by welding the hole closed. I had it done twice on my truck's condensor and it works great. To try and resolve the problem you can put some fine mesh screen in front of the condensor to keep debris from puncturing it.
May 13, 2011 | Pontiac Vibe Cars & Trucks
I punctured a hole in the freezer part will it still work?
UUUUUUUgh....not sure....
if you punctured the part that has the freon zig zagging through it and allowed the freon gas to escape then...nope...it will no longer work and it may cost quite a bit to get it repaired.....but...if you are lucky you may have only punctured the covering and not got into the part with the freon...turn it on and see how lucky you are.
Aug 21, 2009 | GE Refrigerators
I HAVE A HOLE IN THE REFRIG.LINE OF A HAIER MO.HC125FVS
Hi, unfortunate, sorry to hear that, but it could be repaired, you should immediately dried up water/ice around punctured area, prevent water/ moisture entering punctured area (evaporator. lines), it's one of the worst thing, that could happened to any refrigeration system, it will be costly to repaired, if water get into your evaporator lines, compressor oil have to be replaced, evaporator will need to be flush out, repair puncture, change filter drier, it's better to replace compressor, vacuum system for about 2hrs. then recharge. it's better to use welding/ soldering, to repair punctured line, epoxy repair kit can be used to repair punctured (evaporator) lines . you will have to call a mechanic, if very little water entered punctured( evaporator) lines, then flushing of evaporator, (internal cleaning of lines (tube) changing of filter drier, with overnight vacuuming will do the job. take note, job like this, cannot be guaranteed. check cost for repairs, sometimes it's better to purchase a new one, and save yourself some headaches.next time never use sharp instruments in your freezer, it happened to me sometimes, it's what you get your hands on, what's available at the moment, good luck.
Aug 15, 2009 | Haier HC125FVS Wine Cooler Beverage Cooler
Chiseling the freezer compartment I punctured one of he elements and now obviously not freezing.
hi, need new refrigerator. punctures in evaporator, is one of the worst thing that could happened to ref. to repair you'll need to replace oil in compressor, replace filter dryer, repair puncture with special epoxy, or soldering of aluminum, which is difficult, vacum and recharge, if done properly, system would be o.k. water in system is refrigeration biggest enemy, it's better to buy another one.
Aug 02, 2009 | Haier HSB03 Compact Refrigerator
REPAIR or REPLACE?
OMG ROFL!!!
Well... here's an idea.
Drill a 1/2 inch hole where you punctured the wall of the freezer, make sure you don't hit the coils. Then goto lowes/home depot and get that expansion foam that is used to insulate windows and holes in houses. Grab a razor blade and scalp off the excess after it's dried. Now cover the foam on the inside of the freezer with 2 part epoxy or "shoe goo" or e6000 (these are the toughest glues I have ever used) which is available at a hobby shop. Make sure you do a test with the foam and the glue on cardboard first to make sure the glue won't eat at the foam.
Are you sure you punctured the coil? If you did you can goto an auto part place and ask for a compression fitting (most commonly used to repair brake lines on cars) for what ever tube size the coil is, use a fine ruler is the best. Then you can repair the coil by using a pipe cutter to cut the coil and put it back together with the compression fitting. Now call the appliance service guys and have them come out and recharge the system.
Fixed, total cost... about $50 bucks
Other solution, replace entire fridge, total cost $$$$$
Sep 04, 2008 | Thetford Norcold® Model DE0061
Sanyo punctured evaporator
It isn't always more costly to repair provided that the system isn't contaminated by water and air entering it at the time the evaporator was punctured. Unfortunately it is in most cases. However if you can get the parts cheaply enough and your tech's labor rate isn't exceedingly high in a worst case scenario you should expect a job of this magnitude to approach and even cross half the cost of a new refrigerator. That's the point at which most people decide not to repair it. My suggestion would be to see any repair companies might want to buy it for parts or donate it to a local trade school
May 18, 2008 | Refrigerators
Acer Aspire One  PC Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
