Question about Dell OptiPlex GX60 (SFFDELL-C2G) PC Desktop
Could not recognized IDE 01 from bios - Dell OptiPlex GX60 (SFFDELL-C2G) PC Desktop
Messed up an IDE partition now BIOS won't recognize drive, can this be fixed or is there a workaround?
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key this will vary depending on your operating system and computer Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter Change the first boot device to your hard drive.
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ? Hope this helps.
Dec 09, 2012 | Computers & Internet
Hello, I've got a WD 200BB IDE drive I'm trying to install in a Dell Optiplex GX620. Since there are no IDE controllers on the mobo, I'm using an "Ultra" SATA to IDE ATA adapter. I cannot get...
Go into the BIOS and hold down the key and then press the and keys in succession. This should force the motherbrd to go out and detect all connected devices.
Apr 10, 2011 | Dell OptiPlex GX620 PC Desktop
How to download the driver of Hitachi Travelstar 5K100 HTS541060G9SA00 ? plz plz help me
I am not familiar with Linux but have you checked your Bios to see if Sata Hard Drive is recognized in there??? Most of the time you have to set the bios to recognize a Sata drive because 90% of Hard Drives are still IDE and most bios software is still recognizing the IDE drives. I know I had to reset everything on my Motherboard and Bios when I changed over from an IDE to SATA Hard Drive.
Nov 01, 2010 | Hitachi Travelstar 5K100 HTS541060G9SA00...
Dell optiplex will not recognize hard drive
Is it SATA or IDE? Have you tried another cable? If it's IDE, have you checked the jumper settings (usually Cable Select is easiest)?
Feb 19, 2010 | Dell Optiplex GX60 PC Desktop
New ECS G31T-M won't recognize IDE devices
Locate the boot options in your BIOS and set it to boot from the Hard Drive
Oct 13, 2008 | EliteGroup ECS G31T-M Motherboard - Quad...
Secondary hard drive
I had this trouble had to reset BIOS to default then it worked but would either recognize IDE drive and not SATA remove IDE SATA was recognized
Its something in the BIOS setup As I do not know your BIOS you will have to check it out with *********** board manual how to do it to setup both drives
Aug 08, 2008 | Intel Motherboard
Computer won't recognize sata dvd burner
is jumpers on corect cant u just use ide cable instaed u said your going from ide to sata cable ?
Jan 19, 2008 | EliteGroup P4VXMS (P4VXMS-R) Motherboard
Hard drive
Have you gone into the BIOS to see if the IDE drive is recognized? If not, you may need to alter a BIOS setting to tell the system you'll be using both SATA and IDE drives. If the drive does appear in the BIOS then it may be a Windows setting that's causing the problem.
Let us know.
Dec 09, 2007 | Acer APFV MT (APFVUP5152) PC Desktop
Replaced Motherboard HELP
So the HD is not recognized at all or do you see it in the BIOS? If you don't see it at all then obvious things to check are the power cable, and the IDE or SATA cable. If it's an IDE drive it's not too difficult to bend a pin while attaching the connector. I would check that. I'm guessing you did not change any jumpers on the drive. Last thing I can think of is to be sure the BIOS settings are correct depending on if it's an IDE or SATA drive.
Nov 19, 2007 | Dell Dimension 8400 PC Desktop
Dell OptiPlex GX60 (SFFDELL-C2G) PC Desktop Logo
mukhtar21 shaikh
mukhtar21 shaikh
