Question about HP LaserJet P3005 Printer
Why my printer always stuck while i print more than 5 paper?? it is need to change a roller??
  • HP Master
  • 11,800 Answers
The picker roll at the back of the unit is badly adjusted, it presses to strongly on the papers and creases them.
You must open the printer and adjust it.
Posted on Oct 06, 2010
2 Suggested Answers
yooperbud
  • 8637 Answers
SOURCE: Paper stuck
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Posted on Jan 26, 2009
Hello paper jam error appears with no paper jammed. Then printer refuses to print or doesn't print well
To resolve paper jam issue, follow the steps
1. Open the rear access door.
2. Remove any bits of paper stuck.
3. Clean the rollers using lint free cloth ( upward position )
4. Close the rear access door
5. Open the front panel door
6. Check for any paper stuck between the rollers.
After doing all these steps, to make sure if your printer is working fine, try to make a copy.
If the printer can make copy, Click on the link to resolve printing issue -> Link
Oct 12, 2010 | HP Photosmart 2575 All-In-One InkJet...
Printer will not print...it jammed ......the paper jammed in the machine..and I pulled it out....
1. Inspect the paper trays to make sure they are not overloaded. To determine if this is the problem, do a test print with only one piece of paper loaded in the paper tray. (If this turns out to be the problem, keep the paper tray half-full in the future.)
2. Check that the type of paper being used falls within the printer manufacturer's recommendations. For example, paper designed for ink-jet printers doesn't necessarily work well in laser printers. High-quality, bonded paper will cause paper jams in some printers; look for bonded paper that is "laser and ink-jet compatible."
3. If someone has recently printed labels on this printer, check to see if a label has come unglued from a sheet and become stuck inside the printer.
4. Check the gears and rollers for stuck shreds of torn paper from previous jams. Turn off the printer before you attempt to remove the bits of paper.f you have a laser printermag-glass_10x10.gif, inspect the printer's paper rollers. They should be smooth but not shiny. Rollers that are cracked or glazed are a frequent cause of paper jams and should be replaced by a technician.
5. if you have a laser printer, try cleaning the printer's paper rollers with a lint-free cloth and isopropyl alcohol (available atelectronics shops or drugstore.Try changing the toner or ink cartridge.
Feb 04, 2010 | HP Office Equipment & Supplies
Hp 5440 not printing, changed ribbon and now getting flashing arrow key. Restarted, took ribbon out and put back in....usually it works.
Step 1
Step 2
Step 3
Step 4
Step 5
If you have a laser printer, inspect the printer's paper rollers. They should be smooth but not shiny. Rollers that are cracked or glazed are a frequent cause of paper jams and should be replaced by a technician.
Step 6
If you have a laser printer, try cleaning the printer's paper rollers with a lint-free cloth and isopropyl alcohol (available at electronics shops or drugstores).
Step 7
Step 8
If you hear a clinking sound during printing, your printer probably has a broken gear and needs to be serviced by a technician.
Nov 19, 2009 | HP DeskJet 5550 InkJet Printer
Wasting alot of paper printing out on Hp Designjet 500
Step 1
Step 2
Step 3
Step 4
Step 5
Step 6
Step 7
Step 8
Nov 19, 2009 | HP PRINTER,DESIGNJET 500 42'' InkJet
When I turn on the printer, the paper will not feed. Then I receive an "out of paper" light.
Step 1
Step 2
Step 3
Step 4
Step 5
Step 6
Step 7
Step 8
Nov 19, 2009 | HP DeskJet F380 All-In-One Printer
I have only used my printer 7 times and now no matter what i do it pulls the paper in crooked and bent
  • Step 1 Inspect the paper trays to make sure they are not overloaded. To determine if this is the problem, do a test print with only one piece of paper loaded in the paper tray. (If this turns out to be the problem, keep the paper tray half-full in the future.)
  • Step 2 Check that the type of paper being used falls within the printer manufacturer's recommendations. For example, paper designed for ink-jet printers doesn't necessarily work well in laser printers. High-quality, bonded paper will cause paper jams in some printers; look for bonded paper that is "laser and ink-jet compatible."
  • Step 3 If someone has recently printed labels on this printer, check to see if a label has come unglued from a sheet and become stuck inside the printer.
  • Step 4 Check the gears and rollers for stuck shreds of torn paper from previous jams. Turn off the printer before you attempt to remove the bits of paper.
  • Step 5 If you have a laser printer, inspect the printer's paper rollers. They should be smooth but not shiny. Rollers that are cracked or glazed are a frequent cause of paper jams and should be replaced by a technician.
  • Step 6 If you have a laser printer, try cleaning the printer's paper rollers with a lint-free cloth and isopropyl alcohol (available at electronics shops or drugstores).
  • Step 7 Try changing the toner or ink cartridge.
  • Step 8 If you hear a clinking sound during printing, your printer probably has a broken gear and needs to be serviced by a technician.
Nov 19, 2009 | Canon Pixma iP2600 Photo InkJet Printer
Says document is in queue and don't print
Step 1
Step 2
Step 3
Step 4
Step 5
Step 6
Step 7
Step 8
Nov 19, 2009 | Lexmark X7350 All-In-One Printer
Epson print LQ-590 always paper jammed at roller when printing continuous 5 sheet of paper. May I know how to fix this?
the paper you are using may be moisten. pls try another paper sheets . purchase new papers.
if the problem continue clean the paper feeder assembly roller with moist cotton using cleaning liquid eg petrol or spirit etc.
Aug 21, 2009 | Epson LQ-590 Matrix Printer
Paper stuck
Jan 03, 2009 | Konica Minolta magicolor 2300DL Laser...
Always paper jam.
Check to see if something isn't blocking the paper path.
You could try cleaning the feed rollers as well.
Jun 12, 2008 | HP LaserJet 2420 Printer
HP LaserJet P3005 Printer Logo
43 people viewed this question
Seeker5211
Seeker5211
