Question about Brother HL-2040 Laser Printer
Paper continually feeding
I just had to change the toner cartridge in my Brother 2040, after putting the new one in it just keeps on feeding paper through. What can I do to stop it. It also does print while it's doing this either.
  • wanewee May 28, 2008
    IT doesn't print while feeding all this paper through.
    Genius:
  • 1,224 Answers
On your printer or i should say in your printer you have memmory the extra paper being loaded is from previous print jobs that havent completed in your manual that came with the printer should show you how to clear the memmory out and start printing properly again also a printers memmory can be corrupted the software that came with your printer should be able to do a memmory dump and clear the cache out and then be back to normal
Posted on Jun 01, 2008
3 Suggested Answers
Soulvisitor
  • 1113 Answers
SOURCE: brother 2040
Broken carona wire in drum replace drum or non gen toner not working correctly
Posted on Dec 28, 2007
  • 3 Answers
SOURCE: brother 2040 all lights keep blinking
Just got the following solution that worked for me:
1. Power Unit off
2. Open front cover
3. Press and hold GO and turn power on
4. When all 3 lights lit release and press GO twice
5. All lights turn solid
6. With all solid, press GO 5 times
7. Ready light GOes red
8. Close door and you're all set
Got it from here:  http://www.fixya.com/support/t612015-print
Posted on Jun 10, 2008
My brother HL-2040 Printer is not giving licking sound during startup as well as it also not reading the toner/paper why?
Not sure what you mean by "licking sound during startup"
As for the Toner not reading most often this is caused by the toner cartridge being empty. Try replacing your toner cartridge. If you have recently changed the cartridge it may not have triggered the Toner Reset microswitch. The reset gears on the side of the cartridge will need to be changed back to the ready position. If it is an OEM cartridge then take it back to the place you bought it from and they can replace it and send it back to brother. If it is a remanufactured cartridge then take it back to where you got it from and they can reposition the gears for you.
Not reading the paper can be because there is no paper in the machine or the paper feed system is worn and needs to be replaced.
Oct 02, 2014 | Brother HL-2040 Laser Printer
How do i change the toner on m my HL 2040 brother printer
How to Change a Toner Cart in a Brother HL 2040
The Brother HL 2040 laser printer has a toner cartridge that supplies toner to the drum assembly so that the printer can print properly. When the LED on the front of the printer indicates you are low on toner, you will need to replace the toner cartridge to maintain good print quality. Fortunately, the toner cartridge can be replaced without any special tools.
Instructions
Things You'll Need:
* Replacement toner cartridge (part number TN350 or TN360)
* Paper towel or scrap paper
Grasp the front cover of the printer and pull it toward you to open the toner door. Reach into the printer and grab the combined toner cartridge/drum assembly. Lift up slightly and pull it out of the front of the printer.
Place the cartridge and drum on a paper towel, spare sheet of paper, rag or other surface that can get dirty. Loose toner particles may spill from the cartridge.
Press the blue locking lever on the cartridge/drum unit to unlock the toner cartridge from the drum. Lift the toner cartridge up and away from the drum unit. Dispose of the old toner cartridge in accordance with your local regulations. Seal it in a plastic bag to keep loose toner from spilling.
Gently shake your new toner cartridge back and forth a few times to distribute the toner evenly across the width of the cartridge. Remove the plastic protective cover from the bottom of the cartridge.
Place the new toner cartridge onto the drum unit and press it down gently until it locks into place. The blue locking lever will automatically click into place. Verify that the toner cartridge is securely connected to the drum.
Locate the corona wire cleaner tab at the front of the drum unit. Slide it back and forth several times to improve the print quality of the drum. Set the tab back in the home position when finished.
Slide the combined toner cartridge/drum unit back into the printer and close the front cover.
Hope it helps...
Dec 02, 2010 | Brother HL-2040 Laser Printer
Paper light keeps blinking, paper full, won't print
Paper light blinking could mean a few things on this machine.
There could be a paper jam in the machine. Open the front cover remove the drum and toner and look in the machine. You can also check in between the drum and toner by removing the toner from the drum. Open the back cover and look for a Jam as well.
Try putting a piece of paper in the manual feed tray which is right above the paper tray, sometimes on certain documents the margins are too big and asks to go into the manual feed slot.
Apr 12, 2010 | Brother HL-2040 Laser Printer
Paper light flashing on my brothers HL-2040 printer. I fanned the paper still keeps flashing
Hello ,
Please follow the below steps to try and clear this message.
  1. Turn the power off on the unit.
  2. Open the front and back cover of the unit.
  3. Remove the drum and toner cartridge from the unit.
  4. Check thoroughly inside for any paper jams or any other foreign objects and remove them.
  5. Reinsert the drum and toner and close the front and back cover.
  6. Turn the unit back on.
If the light keeps flashing you will want to check to see if you need to feed paper through the manual feed.
The manual feed is the opening on the front of the printer, just place a page there.
This should clear the error message on the display screen and allow you to resume normal use of the printer.
Thanks,
Pat
Mar 28, 2010 | Brother HL-2040 Laser Printer
Won't feed paper
It has toner? if not replace new one. If it has toner then try to remove the catridge and place it again. This might help you.
Mar 02, 2009 | Brother HL-2040 Laser Printer
Hl 2040 laser printer
Check for a piece of paper caught in the fuser section. Sometimes a small piece will wedge itself in. Vacuum out any residual toner that may be in the paper path.
Dec 01, 2008 | Brother HL-2040 Laser Printer
Hl 2040
You must have refilled the first (starter) cartridge or didn't reset the toner reset lever. There is a reset lever on the left side edge of the cartridge. Look at the left end of the cartidge (not the fill cap end) for a round white gear end and a white lever in a hal moon shaped slot. If you can see only the round white gear and the hlf moon is emty of a white lever, it's a non-restting starter. If you have two white spots we will be addressing the one in the half moon slot. The used cartidge will have the lever at the "3 O'clock" position. To reset the cartridge as new you must remove the two screws on that end cap and move the lever to the "11 O'clock" position. Put the scews back in and reinstall in the printer. The sweeper lever will turn in the machine and reset the toner count.
***Important For Brothers**
Make sure when refilling that ALL WASTE TONER is completely cleaned out of the cartridge before adding new toner to it. Brother re-uses its old waste toner and over time the toner hopper gets contaminated with paper dust and too much old toner inside causing them to fail. It you just add toner to the cartridge without thoughly cleaning out, you will soon have a bad cartridge again. You'll see it when dumping out the old as white specks in the toner. That's actually contamination from paper dust and talc from the paper.
Hope that helps you.
Jul 27, 2008 | Brother HL-2040 Laser Printer
My brother hl 2040
Your not resetting the toner reset lever. It's on the left end (not the fill cap side) of the cartridge. If you have a resettable cartridge on the left end you will see to white pieces. One round and one like a lever in a half moon slot. We will be addressing the lever in the half moon slot only. The lever on a used cartridge will be at the 3 O'clock position. Remove the two screws from the end cap and then move the gear to the 11 O'clock position. Put the end cap and screwss back on. Put it back in the printer and close the door. When the printer powers up it will sweep the lever across the sensor and reset the toner level to full.
****Important Note****
When refilling, make sure you dump out and clean ALL OF THE OLD TONER from the cartridge before refilling. Brother reuses it's old toner putting it back into the fresh toner supply (along with debri) and slowly contaminates it's supply with paper dust and talc from the paper.
If you don't clean out the supply hopper well before refilling, it will quickly mix your new toner with the old toner and more quickly contaminate the entire supply. USE GOOD PAPER, NOT CHEAP PAPER and your supplies and refills will last much longer.
RED LIGHT BROTHER 2040
light explain link check first!.... paper jam light indicates a few things ie paper mismatch.
possible dirty feed roller, confirm by using bypass slot.
slightly damp rag on rubber feed roller to clean if the issue
Dec 22, 2007 | Brother HL-2040 Laser Printer
Brother HL-2040 Laser Printer Logo
128 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
