Question about Refrigerators
We have a sise by side Samsung fridge mod DA99-00258A. The temp is at 3 c and keeps flashing and the fridge side is not being cooled.Please advise
  • jean cuomo Aug 13, 2013
    my freezer is collecting water at the bottom which freezes and eventually u can't open the bottom draw
SOURCE: Have a 2 year old SAMSUNG RS2545SH Side by Side
Control board has gone bad....
What happens is the defrost is controlled electronically from a circuit board, when this goes bad, the freezer quits defrosting, and freezes the fans that circulate air through the fridge side of things.
To check this, unplug the entire fridge, leave the freezer open, wait for it to defrost a bit, if this causes the fridge to start cooling again when you plug it back in, then its the defrost. You should also see ice crystals on the back of the freezer just under the icemaker.
http://forums.partselect.com/refrigerator-freezer-repair/rerifgerator-side-not-below-54-degrees-6699.html
Posted on Mar 08, 2008
SOURCE: my samsung fridge freezer da99-00494v
just had same problem
you can
1. turn off and defrost
2. remove all panel of fridge ( inside) fan has got bloked with ice and cannot cool fridge.
Posted on Jun 15, 2008
SOURCE: Samsung twin cooling fridge/freezer model
My husband removed the covers inside the fridge which contain the lights and the cooling fan. The problem was the icing up of the cooling fan (which circulates the cold air) preventing it from rotating also the drain hole at the bottom of the fan was also iced up.
The fridge was switched off at the wall socket whilst working on it. After removing the panel containing the fan and unplugging the connection take the panel outside. A hair dryer was used to thaw out the ice. The drain hole was made slightly bigger to hopefully prevent this happening again.
When panel is screwed back in fridge make sure the black sealing tape is in position also take care not to damage cooling pipes which are attached to the evaporator unit. Defrosting a couple of times a year might prevent this happening again. It seems to be a design problem which im sure the makers will be aware of and modify future appliances. Q Will the makers repair this problem free of charge even if the warranty has expired !?
Posted on Aug 01, 2008
tborn6
  • 700 Answers
SOURCE: samsung rs2533sw fridge not cooling
it sounds like the refrigerator evap is frozen up causing the compartment to get too hot. shut the unit off and let it thaw out. then take the screws out of the cover to check the stryrofoam on the back side of the cover to see if theres broken spots on it causing the air to bypass the evap causing it to freeze. Theres two screws behind the light cover and two at the very bottom of the cover and two behind the decorative plugs about 1/2 way
Posted on Dec 22, 2008
SOURCE: Samsung RS2533SW freezer not cooling problem
I was having the same problem but with the refrigerator side. I know your problem was with the freezer side but I hope this works in your situation too. I was also told to unplug the fridge for 20 minutes and that did not do a thing to reset the circuit board in my situation. Unplug the refrigerator first. In the back of the refrigerator at the bottom is a metal panel. Remove that panel and off to the right side of it should be a white looking plastic box. Unscrew that box from the fridge and open it up to get to the circuit board. Remove ALL harnesses from the circuit board and capacitor. After doing so plug them all back in and reassemble everything back together and plug in the fridge. This should reset the board and allow it to function correctly. This is advice I got from someone else and everything as of today is cooling down like it should. I hope this helps everyone else out. Best of luck.
Also since the evaporator was frozen solid at the bottom on the refrigerator side I had to leave the power off until it thawed and then had to soak up all the water that collected at the bottom of it.
Posted on Apr 20, 2009
Samsung SRS583DW Fridge / Freezer not freezing
The unit has a built in defrost cycle that is controlled by the main board. You need to replace that board.
Nov 20, 2013 | Samsung Refrigerators
We have an stainless steel side by side Electrolux fridge and the freezer sise is fine but the fridge side keeps getting too warm reaching temps of 70 degrees...We adjust the temp settings and it sometimes...
On a side by side unit, the freezer actually cools the refrigerator side of the unit by the use of a "damper" door or switch. Check this between both doors for any ice blockage or damage and go from there. You might need to contact a professional to diagnose the entire unit if you don't "see" any issues.
Jul 21, 2012 | Electrolux Refrigerators
Whirlpool sise by side fridge mod # ED5FHEX5SNOO Whirlpool side by side: --------------Fan running -------------------------Compressor not running (not clicking) --------------------Freezer ok, FRIDGE NOT...
YOUR SAFETY SWITCH IS CUTING OF. THIS SWITCH IS NEAR THE COMPRESOR. SHOULD COMPRESOR GET VERY HOT IT IS INDICATION THAT IT NEEDS TO BE REPLEACED. IN THIS CASE SOMETIMES IS BETTER TO GET NEW FRIDGE AS REPAIRES MIGHT COST TO MUCH
Mar 02, 2011 | Whirlpool Refrigerators
I have an Amanda side by side, the fridge temp
Look in the freezer side for a ice buildup on the back wall.
Ice= defrost parts issue.
Check the fan in the freezer. Is it running?
Not running? Could be a defrost thermostat issue or a bad fan motor.
Mar 03, 2009 | Amana ASB 2623 Side by Side Refrigerator
Samsung fridge
Defrost by turning off for 48 hours and the unit will work ok (for a while)
Its a design fault common to many Samsung Side By Sides
Aug 19, 2008 | Samsung 24.8 Cu. Ft. Side-by-Side...
Fridge tempertature
I have the same symptom too - freezer temperature flashes at -2. "Power Freezer" or setting it to any other temperature is not working either.
As a result, no ice being made. Please help!
Aug 03, 2008 | Samsung RS2630SH Side by Side Refrigerator
Samsung side by side
you can reset the fridge by pushing "Power Freeze" and "Power cool" at the same time
it worked with my fridge Samsung RS21DAMS which stopped after a power cut and was also flashing at the digit of the fridge temp display
Mar 28, 2008 | Refrigerators
Refrigerators Logo
328 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
