Question about ErrorExpert
After using recovery disks for toshiba laptop satellite l305d i get error message 10-fa12-045d, please help??
    Guru:
  • 846 Answers
Toshiba recovery error seem likely to be due to a failing/failed HDD. If your laptop is in warranty then visit Toshiba service center. Otherwise try this--------> I would like you to try checking the HDD with an error checking program from floppy or CD or with the drive removed from the laptop and tried in a USB external enclosure in another PC.
If the HDD itself is made by Toshiba (which seems likely) you would need a generic testing program since Toshiba don't provide their own HDD checking program.
HDTune can be used from another PC.
Have a nice Day
Posted on Oct 06, 2010
How can I restore my Toshiba L305D-S5895 laptop from the recovery disks when the laptop don't even turn on to windows or recognize the HDD? Please help or is the HDD wiped clean somehow? I have windows...
You should be able to boot the computer from the operating system recovery disk. Most likely your harddrive crashed, or one of (many) other issues. It could have just erased your MBR, in which case you can boot with a live cd and recover most (if not all) of your data.
Jun 15, 2011 | Toshiba Satellite L305D-S5895 Notebook
Want to reformat satellite l305d-s5943 back to factory settings but have no disk.
Toshiba puts a recovery partition on the hard drive.Here is how to access it to return it back to factory settings.
1.Turn the PC on and hit the F8 key repeatedly until the Advanced Boot Option Screen appears.
2.Click "Repair Your Computer" if you are not already on it and then press ENTER
3.choose your country and click OK
4. On the "System Recovery Options Screen" click "Restore Application" which is the last option.
5.Follow the on-screen instructions
6.When prompted, click on "Full Factory Recovery"
7."Next"
8.. Click "Yes"
9.you will notice for a while it seems like nothing is happening, give it some time.
10. After some minutes, recovery will complete and you click "Finish"
If you have replaced the harddrive you may still be able to get a disk from toshiba HERE
Jun 12, 2011 | Toshiba Satellite L305D-S5943Notebook
I want to restore my L305D-S5943 back to factory settings but do not have disk,Please Help.
Procedure:
1. Power on the computer while pressing the F8 key to enter Advanced Boot Options.
2. Under Advanced Boot Options, press the Enter key to select Repair Your Computer.
3. System Recovery Options will appear, click Next.
3. Log On as a local user to access the System Recovery Options.
4. Under Chose a Recovery Tool, select Toshiba Recovery Wizard.
May 27, 2011 | Toshiba Satellite L305D-S5943Notebook
I have toshiba satellite L305d-s5934, Blue screen error appear and hang, when i boot or when i press F2 to enter bios... if i full out the hard disk the computer says: no bootable disk and if i press F2 to...
Sounds like your HDD may have gone bad. What is the name/number of the blue screen error? Google it and see what it means. It may be possible to reinstall the operating system to the original factory settings using the recovery partition (this is usually accessed by tapping F10 or F11 while booting, although I read somewhere that you might be able to gain access to the Toshiba recovery partition by pressing "0" (zero) while the computer is powering on).
You can try to recover the computer to factory settings. If your hard drive has enough life left on it, you might be able to then clone it to a new drive. Drive Image XML is a free software that will do this for you (get that from www.download.com). This way, when you clone the drive, you will also clone the recovery partition, so you don't lose that option. Once you have a new hard drive up and running, use the Toshiba Utility to make System Recovery Disks for the future.
One more thing: If you have recently upgraded/replaced the RAM - this might be your problem. Put the original RAM back in and see if the computer boots. If so, you found the culprit.
Feb 26, 2010 | Toshiba Satellite L305D-S5881 Notebook
Ok, here it goes. I have a Toshiba satellite L300 Series. It shutdown and has these errors..10-FC06-000D and 10-FC12-045D. I installed recovery disk 1 and then it ask for disk 2. After 15min of disk 2 the...
Hi
Thank you for your query
From what you are describing the recovery disks are faulty, and as things stand you have no operating system.
The only thing you can do about it, is to contact Toshiba to obtain replacement discs
If this has been useful please leave positive feedback/vote/testimonial - Thank you again
Feb 14, 2010 | Toshiba Satellite Pro L300-EZ1004X...
I have a toshiba 305 and get the error message the instructions at 0x760f6770 referenced memory at 0x760f6770. the required data was not placed into memory because of an i/o error status 0f 0xc000000e.
It is memory related issue.
First check in back side of laptop and refix RAM memory .
Also you have remove bugs in harddisk for that boot your laptop with recovery disk or bootable winxp disk then enter in recovery console mode then type in prompt "chkdsk /r" then press "y' then it fix error on harddisk.
For refix RAM you have open 1 small plate in back side of laptop it is for RAM module.
Aug 18, 2009 | Toshiba Satellite L305D-S5904 Laptop
Unable to create recovery disk.
Hi there.
Sounds like the software could be corrupt, but there is an easier way to create a recovery disk, check this tutorial out >>>>>
http://createrecoverydisk.com/
If you need more advice please feel free to post back.
Good luck and thanks for using FixYa!!
May 14, 2009 | Toshiba Satellite L305D-S5895 Notebook
My satellite model laptop is now formatted.and having error no boot mgr. help me can i use recovery dvd to solve this
Recovery Disc has preinstalled Windows Vista. So don't worry. the Recovery disc came with the laptop do the rest job. only notice not to put laptop on soft surface like bed or a movinf table. plz ensure that laptop is in hard surface like table.
you will get ayour factory settings back.
May 01, 2009 | Toshiba Satellite L305D-S5904 Laptop
I cant make recovery for my laptop and idont have cd recovery
what type of laptop do you have? there should be a recovery partition in your C drive. You could also try contacting the manufacturer if your laptop originally came with a recovery disk.
Mar 14, 2009 | Toshiba Satellite L305D-S5895 Notebook
CHEHCO
You can use the recovery disk which came with your laptop. If you no longer have it or if you think you never had it, please call Toshiba for it. Hope this helps. Thank you.
Sep 22, 2008 | Toshiba Satellite L305D-S5881 Notebook
Computers & Internet Logo
445 people viewed this question
Top ErrorExpert Computers & Internet Experts
David Payne
David Payne
Are you an ErrorExpert Computer and Internet Expert? Answer questions, earn points and help others
