Question about Magic Chef Kitchen Ranges
I have a Magic Chef gas range/oven/stove model #3468VTV. Fault code F1 apprears and the range continually beeps. According to the Manual it states F1: Condition: touchpad membrane defective or clock (ERC) is defective. What to fix: to determine which component is at fault, disconnect ribbon strip. If NO fault code is displayed replace the membrane, otherwise replace the clock essembly (ERC). I do not understand how to disconnect the ribbon strip? What is this? Do I need a service technition to view item? Would it be more cost effective to purchase new appliance? this one was purchased in 1994.
  • 770 Answers
UNPLUG...Then you need to open the control panel and there is a ribbon cable you remove from the main control board then plug the unit back in to see if the F1 is gone if so you need to replace the Touch pad
Posted on May 28, 2008
The oven on my magic chef range does not work..broiler and burners ok ,,,get a F1 code and beeping noise ...model number 3488VTV
Hi hockeyhoskin,
F1 error indicates a bad touch pad or clock (ERC). To fix this error code, replace touch pad or clock (ERC). Touch pad is a more common problem.
Hope it helps.
Thank you for using FixYa.
Dec 06, 2009 | Magic Chef 31000 Gas Kitchen Range
Our magic chef oven f1 code keeps coming on
MAGIC CHEF
Range/Stove/Oven Fault Codes
F1 1. Watchdog on board
2. Touch membrane defective To determine which component is at fault, disconnect ribbon strip. If NO fault code, replace membrane, otherwise replace board F2 Oven too hot Check oven temperature sensor F3 F4 Open or shorted oven temperature sensor Replace F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Replace clock assembly (also called the ERC) F7 Function key shorted Replace touch pad F8 Analog/Digital converter Replace clock assembly (also called the ERC) F9 Door latch Check door lock circuit F10 Function key stuck Replace touch pad
Feb 07, 2009 | Magic Chef 31000 Gas Kitchen Range
Magic Chef Gas Range, model CGR3740ADW
magic chef fault codes
Jan 27, 2009 | Magic Chef 31000 Gas Kitchen Range
F0 fault code on magic chef gas range
Do not recognize a F0 code only F1-F10. Recommend unplugging and replug.
Dec 09, 2008 | Magic Chef 31100 Gas Kitchen Range
"F1" error code on Magic Chef gas range Model 3488XRA
I'm not sure how to fix this, but my mom's magic chef has been doing this for close to 10 years. She's managed it by plugging a power strip into the wall outlet and plugging the stove into the power strip. Then she can just turn on the strip when she needs to use the oven. It only requires moving the unit once, and is easy for the technological/ home repair novice.
Sep 18, 2008 | Kitchen Ranges
the burners on my magic chef stove work but the flame is not as high as it should be on one burner. I switched the top of the burner with another and it did not solve the problem.
Jan 03, 2008 | Whirlpool 30" Self-Cleaning Freestanding...
Have a magic chef oven, f1 display after self cleaning, stove top works fine, any thoughts
F-1 is a fault code.
Disconnect the power plug or turn range power off at circuit breaker. Wait a couple of minutes, then plug the range in or flip the range circuit breaker to ON.
Oven control beeps & displays any F  code error (for example
F11) - Electronic control has detected a fault condition. Press
CLEAR/OFF to clear the display & stop beeping. Reprogram
oven. If fault recurs, record fault number. Press CLEAR/OFF
contact an authorized service agent.
Dec 01, 2007 | Magic Chef CER3725AA Electric Kitchen...
MAYTAG MAGIC CHEF SELF CLEANING GAS RANGE
Here are the codes for magic chef:
Nov 18, 2007 | Maytag MGR5751AD Gas Kitchen Range
Magic chef electric range model 38HK-6TXW
MAGIC CHEF
Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F1 1. Watchdog on board
2. Touch membrane defective To determine which component is at fault, disconnect ribbon strip. If NO fault code, replace membrane, otherwise replace board F2 Oven too hot Check oven temperature sensor F3 F4 Open or shorted oven temperature sensor Replace F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Replace clock assembly (also called the ERC) F7 Function key shorted Replace touch pad F8 Analog/Digital converter Replace clock assembly (also called the ERC) F9 Door latch Check door lock circuit F10 Function key stuck Replace touch pad F6 means no ac signal and will need to replace the oven control.
Oct 18, 2007 | Magic Chef CER3725AA Electric Kitchen...
What is this F-! mean
Oven control beeps & displays any F  code error (for example F11) - Electronic control has detected a fault condition. Press CLEAR/OFF to clear the display & stop beeping. Reprogram oven. If fault recurs, record fault number. Press CLEAR/OFF & contact an authorized service agent.
Sep 03, 2007 | Magic Chef CER3725AA Electric Kitchen...
Kitchen Ranges Logo
272 people viewed this question
Top Magic Chef Kitchen Ranges Experts
Paul Carew
Dan Webster
Dan Webster
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
