Question about Kenmore Elite HE4 Electric Dryer
Door does not open,seems jammed or locked - Kenmore Elite HE4 Electric Dryer
    President:
  • 1,891 Answers
The door latch assembly has locked . this is come times caused by bad connection or broken wiring . . try unpluging the unit for 5 min then repower and see if it will open . if not take the 3 screws out of the bottom panel and remove . you can now reach up inside and there is a pull string that will release the lock. this will get you in .. and you will have to replace door latch . mm hope this helps . .
Posted on Oct 06, 2010
How do I fix a lock that is jammed?
Contact the builder of the doors of the Summerhouse or go to the lock companies website. There may have been a faulty batch or known fault identified on these locks you have fitted.
Alternatively contact a local locksmith who could give tyou advice..
Mar 01, 2015 | Locks & Locksmithing
Hi I have an iseo lock on my reasonably new summerhouse and although i have the key and the key turns both ways in the lock, apparently engaging and disengaging the lock on a single turn each way, i cannot...
You should be able to feel the lock disengage. Also feel the latch moving. If you can feel this, then the door is jammed, not the lock or handle. They do swell. You'll just have to force it open. You might try spraying some lube at the top and bottom, where you suggested it feels stuck.
Mar 01, 2015 | Cars & Trucks
Door jammed,,not he locking,,seems to be hinges
Check the leaver that stop,s the door from closing hasn't fallen apart ,spray hinges with WD40.
Jul 20, 2014 | Rover 25 Cars & Trucks
2000 civic drivers door will not open
Can you roll down the window, disconnect the battery, then unlock the door with the key or from inside and open the door ?
You could have a short in the wiring for the electric lock, or a problem with the latch inside the door.
Apr 06, 2013 | Cars & Trucks
Kwikset door lock jams inside and out.
Is sounds like the door settled or shifted and jammed the bolt in the jamb. I would put a pry under the door and gently lift while turning the key. That is only for the up and down but could be that the door needs to be pushed in or pulled out while turning the key. If you want to get real crazy just pop it off the hinges and investigate. If the lock still does not work with it free from the jamb then you will just have to replace the lock.
Jan 21, 2013 | Kwikset Locks & Locksmithing
Left hand back door will not open. Seems to be jammed all of a sudden. Have taken off door panel, what should I look for now?. Central locking works on all other doors, and seems to be working on the...
there are 2 sets of rods one is for door lock the other is for door lach pull it one way or another which ever makes it move one of the will open the door
Aug 31, 2010 | 2005 Volvo V50
We have a bi-fold door in our kitchen. It has an ERA multi lock. The lock seems to have jammed, first we couldn't open it. Then it opened and I played with lock and now it is again stuck in lock mode but...
It sounds like the rack inside the centre part of lock has snapped, remove from door and you should be able to shake fragment out lock may continue to work without but may need a new gearbox.
Sep 15, 2009 | Locks & Locksmithing
97 park avenue. I have a rear door that will not open from inside or outside. I cannot get the door panel off with it closed to try and find the problem. seems like the lock is jammed in the locked...
it is possible the rod that goes to the door latch has fallen off or the door latch is jammed,try to pull off the door panel inside the car to try and free the latch(it is hard to do ,might damage door panel
Aug 08, 2009 | 1996 Buick Regal Olympic Gold
2004 model - locks jammed
It sounds like the latch on your door is in the closed position. to fix this, first make sure that the door is unlocked, then pull on the door handle( as if you are trying to open the door) then at the same time using your finger or a pencil open the latch on the door. (try closing the door)
Sep 18, 2008 | 2007 Volvo C70
Door jam!
Probably you need a new doorlock. I really dont have a good answer how to open the door with this problem.
Jan 24, 2008 | Electrolux EW1000i Front Load Washer
Kenmore Elite HE4 Electric Dryer Logo
37 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
