Question about Kenmore 44072 Front Load Washer
Kenmore 44072 Front Load Washer Drain Hose Cleaning
I need to clean the Drain Hose of my Kenmore 44072 Front Load Washer. I have looked in the manuals but I can't find the instructions on how to go about doing it. What I was washing shed its fiber in the washer and now the drain hose is clogged. I got an error F03 and have already tried running the empty washer to try and get rid of the clog but that did not work. Any help is appreciated.
Thanks
  • Anonymous Mar 16, 2014
    My washer won't drain. I tried cleaning the drain hose and filter but still doesn't drain
  • 5,911 Answers
Try this link for step-by-step instructions. More than likely you will have to clean the drain pump as well.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If you are having trouble draining the water from the wash tub, and cannot get it to drain with a shop vac, you can drain it directly from the tub. If you don't own a shop vac, you may have to bail. If your drain pump does not have a clean out trap, remove the inlet and outlet hoses to access the inside of the drain pump. Inspect the pump impeller for obstructions and/or damage. If the water will not drain when you try to pull a vacuum on the drain line, you may have to disconnect the drain hose from the bottom of the wash tub. In some front loaders, there is a ball valve in the drain hose from the bottom of the wash tub to the drain pump. This ball can act as a collection pint from lint and debris. You will need to remove the hoses from the bottom of the wash tub to clean this area. I would recommend doing this as a LAST resort. Often, it can be difficult to reconnect this hose to the tub and get it to seal correctly. I hope this helps you. Please post back if you need further assistance.
Posted on May 28, 2008
  • Jeff Rockwell
    Jeff Rockwell May 28, 2008
    PS Don't forget to check the standpipe. You may also have a clog in your plumbing.
Where is the filter on my Kenmore 44072 washer?
you have a sock or simler item stuck in you pump .adrianxxx
Jun 19, 2012 | Kenmore 44072 Front Load Washer
What does the trouble code f2 mean for the kenmore elite 4t washing machine?
Hello & Welcome to FixYa
F02 is a drain error in your Kenmore washer, if the unit is unable to drain then after 4 minutes it will display suds and then F02. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Oct 22, 2011 | Kenmore Elite 45986 Front Load Washer
I have lost manual can you run something thru a load to clean machine such as vinegar or baking soda my machine smells musty
Hi
The smell usually comes when the washer is unable to drain water completely, you can run your washer at its hottest temperature setting with 1 cup of vinegar inside the unit. After this take off the bottom front panel and clean it completely, also clean the drain hose and drain pump filter, the smell should disappear after doing all this. Hope this helps...please post back for further assistance.
Daniel
Aug 29, 2011 | Kenmore Front Load Washer
Get error f-02 on my front load washer on every cycle. help
Kevin
Jul 25, 2011 | Maytag Neptune MAH5500B Front Load Washer
I have a kenmore elite he 3 front load washer...im getting f error 02. it runs fine until the end of the cycle will not drain or spin.
Kevin
May 22, 2011 | Kenmore Elite 45986 Front Load Washer
Stinking mold smell,wrecking our clothes.if i could return this machine,i would in a second!
you need to throughly clean and disenfect the door boot and the drain hole in the bottom of the boot when the door is open,if this doesnt do it you may need to completely remove the inner drum and clean out the outer wash drum and drain tube of soap and fabric scum
Mar 17, 2010 | Kenmore 44072 Front Load Washer
Too much water after was is finished
your drain pump is probably clogged or the main drian hose is kinked
Jan 12, 2010 | Kenmore 44072 Front Load Washer
E20 error on Kenmore front loader. The water is
E20 is an error code for drainage failure.
Check where the appliance drain hose connects to the house drains for a blockage.
If it's onto a spigot under the sink, take them off and check both for a blockage.
If these are ok then it's likely to be a blockage in the pump.
You'll need to drain the water out manually.
Put a shallow dish below the filter and slacken the filter.
Tighten it to stop the flow of water while you empty the dish.
Once empty, take the filter out, clean out the debris and ensure nothing is left jamming the pump.
Before refitting the filter, put the machine on drain or spin and listen at the filter housing to see if you can hear the pump running.
If you do, fit the filter and try the machine again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 07, 2009 | Kenmore 44072 Front Load Washer
Error code 20
I searched other similar models because mine was not shown. I found a similar problem with the solution provided - took off the front bottom panel, detatched the pump and hose and pulled out the small sock that was blocking the pump.
May 17, 2009 | Kenmore 44072 Front Load Washer
Kenmore 44072 Front Load Washer Logo
2,001 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
