Question about Samsung Washing Machines
Spin dryer on my twin tub washing machine does not drain properly. There is water at the bottom of the tub
I 've got twin tub w/machine service is not spinning and draining, can you pls tell me how to solve the problem?
Thanks
Posted on Nov 07, 2010
    Top Expert:
  • Samsung Master
  • 42,828 Answers
Call a service tech sounds like the final spin is not happening .
Posted on Mar 24, 2015
How to spin dry
Hi there
A short history Around fifty years ago the washing machine and the spin dryer were two separate machines. After that came the twin tub, where the two machines were put into one, then we got the washing machine-front loaded. As well as the dryer. Now we have got the dryer and the washing machine combined.
My guess is that you have to push a spin button and decide which speed you want the spin.
good luck
Kolbrun
Apr 15, 2012 | Washing Machines
Spin cycle not working properly. A little water (1 inch) is left and clothes are heavy with water. I tried the spin cycle repeatedly - water still at bottom of tub.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 10, 2011 | Maytag Centennial MTW5800TW Top Load...
Kenmore stack washer/dryer combo. Model # 417-94812301 The water will not spin out. It spins but the water does not go out. When we took the drain hose out of the drain and laid it out stright the water...
There is a water pump in the machine which pumps the water out of the outer tub and into the drain, after the wash and rinse cycles.
It is possible that this pump isn't working properly. I think if it weren't working at all, you wouldn't be able to get beyond the wash cycle.
It has been my experience that small articles of clothing may get washed or spun out of the inner tub and into the area around the pump pick up, thus partially blocking the flow to the pump.
It's also possible that the drain hose from the pump to the drain may be partially clogged.
It is also possible that the pump doesn't run sufficiently long to get all of the water out because its' motor gets hot and shuts down or because of a problem in the control mechanism which manages the the starting and run time of the pump.
First, I would unplug the washer from the wall outlet and probe under the inner tub, or possibly remove the tub to see that there is no blockage from clothing.
It's also possible that things left in clothing pockets like paper clips, small plastic items, etc. can get into the pump and lock up the impeller.
If you're sure it isn't blocked you can then run a "short cycle", no load and water only, and watch to see how much water comes out of the discharge hose where it's hung on the drain pipe.
It should gush out, and tub should be free of standing water prior to the start of the first rinse cycle.
If it does not, then you'll have to access the pump and clear it of obstructions or replace it, if defective.
As it drains, it should start spinning slowly, then speed up as it drains; the final portion of the spin cycle is very fast.
Essentially, the spinning tub wrings out the clothes using centrifugal force.
With the water remaining in the bottom of the tub, it would appear that it is:
a) not spinning long enough, or
b) there is something preventing all the water from getting out in the time allotted by the timer to perform this task.
A fair handy man can get to pump either from the rear of the machine with back plate off, or by removing the cabinet cover from the frame, depending on the model of the the machine.
As always - before attempting any repair, UNPLUG THE UNIT!
When clothes are wet at the end of a cycle, check these:
Motor coupler
To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
If it's spinning when you lift the lid, the coupler is fine.
If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle
If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning
If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve
Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 12, 2010 | Kenmore 98702 Stacked Washer/Dryer
My washing machine will not spin. Eveything else works fine
do you have any drain blockages and does it drain properly,if all or at least most of the water won't drain it will not spin because it senses water still in the tub
Apr 14, 2010 | Washing Machines
Water still in bottom of tub after drain/spin cycle
I removed the drain hose from the bottom left rear corner of the washer & cleaned a large amount of gooey sludge from the bottom of the drain inside the washing machine.
Feb 14, 2009 | Kenmore 12502 Top Load Washer
Washer will not spin dry enough for dryer
sThere is a water pump in the machine which pumps the water out of the outer tub and into the drain, after the wash and rinse cycles.
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Jan 24, 2009 | Washing Machines
Water after spin cycle
remember ,,the tub has a balance ring on top..and that filled with water,,,if your getting water at bottom make sure your drain hose is at proper height,,,+theres always water between the pump and the drain hose no unit can drain 100 per,,
Nov 05, 2008 | Kenmore 24902 Top Load Washer
Twin machine wont spin
the lid swich is defective,,,on the right hand side push down on the little switch with a non metal probe ..listen for a click..if no click or you have to push to far down change lid switch
Oct 13, 2008 | Whirlpool LTE5243D Top Load Stacked...
Hitachi twin tub spin dryer won't spin and pump out water if I have more than two light items in it. The washer is perfect and I love it. Does it have a belt for the spin that needs tightening or what...
you probably have a sock or some other item in the bottom of your spin tub that is blocking the flow of water out of your spin tub an that prevents the spinner from spinning properly you need a wire long enough to reach in there and remove whatever is blocking it
Aug 04, 2008 | Washing Machines
Leaking when entering the Rinse/spin cycle
what is happening is the pump is not pumping the water fast enough. your washer sounds like its a frididaire built washer. there should be a pause where the washer just stops and drains, then go into the spin cycle. so if there is water in the tub and the washer spins it will splash out from the top of the wash tub. you need to make sure the drain is clear, the drain hose is not blocked or kinked, and that the pump is functioning properly. your unit has a electric pump and even though you might hear it running the impellor my be damaged and able to pump the water fast enough.it could be as simple as removing the hose from the bottom of the tub that go's to the pump and removing a sock that found its way in. or just a bad pump. its a simple job to replace it.to get to the pump remove the 2 screws on the bottom of the front panel tilt the washer back a little and slide the panel down. you wil see the pump on the lower left. so check all the things i listed and you should find the problem..Id check the pump first it most likley the problem. good luck
Aug 04, 2007 | Kenmore 88732 Top Load Stacked Washer /...
Washing Machines Logo
1,042 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
