Question about Whirlpool Washing Machines
In a Whirlpool AWG 371 washer (15 years old), which program provides slow or short spin cycle? David
Buffalo12980
  • 625 Answers
SOURCE: Maytag top load washer leak
underneath the agitator is a graphite seal ring and nut that seals the inner tub and the outer tub. a suitable spanner wrench or a 6 inch channel lock plier will remove this locknut. replace the seal.
Posted on Sep 02, 2007
dididsaythat
  • 291 Answers
you have a bad water valve.. replace the valve where the hoses are hooked to your washer
ginko
  • 19396 Answers
SOURCE: Whirlpool AWG 354: Water flowing can not stop
Thet happens because either the water level switch/membrane switch is faulty, or because the water inlet valve is defective and stuck on open. See also : It's overfilling
Posted on Dec 19, 2008
robocop
  • 90 Answers
SOURCE: whirlpool washer wont spin during high spin cycle
Try www.Repairclinic.com.
Posted on Jan 19, 2009
  • 2468 Answers
SOURCE: loud jet noise in spin cycle on Kenmore stackable top load washer
it is the drum bearing seal and it has gone out and ruined the bearings,you would need a lip seal kit and appropriate bearings for that particular unit,i do a lot of maytag front loads and it can take anywhere from 2 hours up to 8 hours depending how the old bearings come out and the damage to the bearing and seal surfaces,the sooner you get to it the less chance of severe damage it will cause,because water will kep on destroying bearings till they lock up and destroy the drive pulley
Posted on Mar 05, 2010
I have a Whirlpool Ultimate Care 2 Imperial Series washer that doesnt spin out very well. It will sometimes spin out but leaves the clothes very damp. Sometimes the washer will try to spin itself out but ...
First thought is that the cycles are off.we have the same problem with ours right now. That slow spin speed concerns me. The motor could be going bad. If this washer is 10-12 years old, you may want to look at replacing it. Does the machine ever start agitating before it finishes filling. If so, the cycle mechanism is going bad. This has a whole host of potential problems. Ave a rep look at it. He can narrow it down quickly.
Feb 06, 2013 | Whirlpool Washing Machines
Hello PHILIPS WHIRLPOOL Washing machine AWG 371 Washer front door - the plastic handle does not function so you can not open or close the door. Can I replace just the handle (were I can get this...
You can buy a handle no problem quite easy to fit buy from Espares.co.uk if you live here or any Philips/whirlpool agent.....Cost about £12.....
Feb 24, 2011 | Whirlpool Washing Machines
Spins on one cycle, but not the other
sounds like timer is loosing contacts and time to replace.
Jul 21, 2010 | Whirlpool LSR7333 Top Load Washer
Spin Cycle is slow
new belt or there is a thrust bearing above the drive pulley that wears out.
May 22, 2010 | Maytag PAV2300 Top Load Washer
Agitator will not spin easily from pully below or
transmission out buy new washer cost to great to repair 15 year old washer
Feb 03, 2010 | Maytag LAT3600A Top Load Washer
15yr old Whirlpool Estate does not stop filling
umm well it is 15 years old so maybe its just ready to go. get a new washer machine.
Feb 10, 2009 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Removing Back Panel of Kenmore Washer Model 11020902990
if its less than 15 years old its a direct drive whirlpool, no belt, remove the cabinet, not the back panel. look up direct drive whirlpool washer cabinet removal on internet, and replace the coupler, most likely, if it drains.
Jan 30, 2009 | Kenmore 22422 Top Load Washer
Whirlpool ingis washer will not engage rinse cycle
make shure the cold water is on and also if it worked before then it cold be two parts 1 the timer is bad or 2 the water inlet valve
Jan 17, 2009 | Whirlpool Inglis IP4400 Washer
Whirlpool washer will not spin just clicks
you must have a faulty transmission or spin tube I could check the top of the spin tube..let me know if you want to go into it..
Aug 31, 2008 | Washing Machines
10 year old Whirpool Top Load washer
hi thanks for the question the problem you have is with a part called drive coupling which is situated on the motor and transmission replace this part thanks te appliance doc
Aug 09, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Washing Machines Logo
209 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
