I have an issue with a computer. one day it stopped turning on all of a sudden. checked PSU and its not getting any power. (usually fan will turn a bit then stop), now decided a faulty PSU is the problem and replaced it, only to find out that the main power switch is broken. replaced the switch eventually and got the tower going again(fan on PSU spinning for a few seconds) but after that it stops with a beep and dies. how can i check this?.. IT s generic pc by the way...
    Scholar:
  • 181 Answers
Good day.
You are down with your motherboard as the main suspect of the problem. To isolate it, remove all the devices (hard disk, optical drive, video card, memory) that is connected to your board. Turn-on your PC. If your PSU is still acting abnormal then your motherboard is defected and you need to buy a new one, else, you can replaced one at a time the devices you have removed earlier.
Feel free to post again here at Fixya if you still have a problem.
Good luck.
Tedmac
Posted on Oct 06, 2010
Testimonial: "Thanks a lot. seems like it is the Mobo is the culprit. Helped me a lot.. "
  • teodoro macaraeg
    teodoro macaraeg Oct 07, 2010
    Thanks, but sorry for the typo error, its should be defective and not defected.
    Tedmac
My hp pavilliona6400f tunrs on but thats all
a desk top, why not lead off with that lil' fact.
the screen never glows that it, not once messsagge of any kind.
called dead black screen.
no battery to pull. like laptop has
so DT, 101, BScreen.
1: fans in the PC run ok? yes, /no
mine has 5 but yours maybe 2, 1 for PSU, one on CPU.
do that?
yes, good
no ! , PSU is bad, or not turned on, the PSU some have hidden rear switch, 0/1 mine does. used for lightening protection, (off)
yes, fans run, then hope is possible but not assured
ok fans keep running? not die in 1second? yes/no.
yes, the BIOS works next the BIOS screens work even with the HDD not present, that should tell you a lot.
hit the BIOS hot key. im not reading your hp manual to you but it told you every day what to push with prompts from day one.
Ill stop here, most give up at, what's a PSU.
mine says, hit ESC to enter setup (BIOS)
every day. same message, never ending.... unless PSU takes a dump. (or worse there is always that due to the 1,303,000,000 transistors inside. can MALF.)
bad ram.
bad PSU
power switch front case fell off.
mobo bad.
and more. I can list many more, but stop here.
get a A+ certification?
Jun 14, 2017 | HP Computers & Internet
My Magimix will suddenly not turn on after working perfectly 2 days ago. Everything is locked into place as usual and can't understand what the problem is.
Hey i fix computers and to me it sounds like your psu (power supply unit) has gone down the toilet and if thats the case its done :( sorry but if everthings right its technical and its most likly the psu
May 07, 2011 | General Food Processors
First of all, I have a Gateway Model FX7026 desktop computer. My daughter was using it when suddenly the monitor screen becomes black. She tried to turn the computer on again but nothings happen. I open...
check if the cpu fan its working fine, maybe is damaged o dirty, you clean up with an air compress can
if still doesnt works you can try to replace the fan and see if it works
Mar 31, 2011 | Gateway FX7026 PC Desktop
Computer won't boot - fan on cpu does not run - cd drive does not power up -
Hi.
If there is no sign of life, then it is usually a power supply problem. Check PSU connector. If PSU fan does not turn on check the power cable. If power cable is good, test power from PSU using a multimeter and eventually replace PSU.
Dec 03, 2010 | E-Machines eMachines Refurbished EMA...
Not booting up
Examine your poser supply.
Nov 02, 2009 | Acer Aspire E650 PC Desktop
Deep freeze computer inresponsive
it sounds like your computer power supply went bad.
go to your local computer store and buy a power supply, install it and you should be up and running.
that is if you didn't fry everything from running it without the proper cooling.
make sure that you have proper cooling fans in your computer, a fan outside will not do it.
It sounds like your power supply fan stopped working and it just got to hot and died
May 24, 2009 | E-Machines eMachines Desktop PC
CPU fan switching on and off repeatedly, computer not switchingon
Check the power supply switch of your cpu casing, make sure that it will not stuck when you switch on the power.
May 08, 2009 | Intel Motherboard
Emachine t5026 not power on. replaced psu.
I would test the memory. Also I think some computers will shut down if the fan on top of the CPU quits working. Or maybe one of the other fans or the Hard Drive quit and is drawing too much juice causing the PSU to shut down. It sounds like something may be grounding.
Jan 02, 2009 | E-Machines T2642 PC Desktop
Profile 5 shuts off on its on
Sound either like a Overheating or a Power Supply Unit issue. You may need to clean the thermal gel off the CPU and heatsink with a small amount of rubbing alcohol and apply new gel. Make sure your fans are working correctly and make sure there isn't any dust under the fan on the heat sink it self, as this will cause overheating issues... Also, if you suspect the PSU you can usually get a nicer one than you have now for $50, so it is better to go ahead and replace it if it is old. The pop sound makes me lean more towards the side of power / PSU but this sound could simply be from the hard drive lossing power suddenly.
Dec 11, 2008 | Gateway Profile 5 PC Desktop
New motherboard and cpu: no post
I have encountered that kind of problem before in the AMD processor. When your turn on the switch the fan is spins and then suddenly stop. The processor is shorted or there is defective parts you need to return it to the supplier. But can you check first if the motherboard and the processor is match . Maybe the motherboard cannot carry the speed of the processor it's better to ask to the supplier or ask them to test both the processor and motherboard .
Apr 17, 2008 | MSI 945GCM5 Motherboard
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
