Question about Sharp AR-M350U Copier
Client install Sharpdesk 3.1 ,scan form AR-M351U via network can't work , error code NG800000.
007tech
  • 95 Answers
SOURCE: Sharp AR-M350/M450 scan to desktop
Network scanner tool (or NST) comes bundled with the Sharpdesk application. It can be loaded as a standalone but it is bundled software. If you have dealer access to Sharp's website you could download the software from there.
If this is a client of yours you should be selling them another copy of the software as it is no fault of your own that they misplaced the CD plus its extra revenue.
I would love to help you otherwise, but this is copyrighted software.
Posted on Mar 24, 2009
SOURCE: sharp ar-m237 default username and password
admin
Sharp
Posted on Apr 04, 2008
SOURCE: Sharp AR-M450 can't scan to e-mail
You should use a USB connection from your pc
Posted on Apr 18, 2008
mickspaceNET
  • 115 Answers
SOURCE: Network Error on display
If you’re getting this on both machines, it is your network...
There a few possibilities...
1. SMTP / DNS Info. Is that correct? Your It can help with this?
go to the Nic page of the machine (IP Address in win explorer) , go to admin page, which the pass word should be sharp , look for the network settings. look at both the smtp info and the gateway and dns info.. Verify that it is correct.
2. Have you changed your Internet Service Provider?
For example, Comcast is making a habit of blocking port 25. Embarq DNS information is a mess, their mail relay is a real hassle.
3. E Mail server information changed? Does your server require authentication, is the Time out set correctly?
Posting the correct codes really help in resolving these issues
Below are a few of the codes...
CE 01 The network card is not installed or broken
CE 02 the specified mail server is server is not found.
CE 03 The specified server suspends response during Transmission of images.
Posted on Oct 23, 2008
goodgold
  • 389 Answers
SOURCE: Scanner on Sharp AR-M350u is showing NG800000 and
This mistake NG800000 offset scanning device.
1 Try reinstall a driver on local on cord USB
2 Remove glass of the scanner and check displacement scanning device, it must softly move. Smazhte nodes mask, продуйте the sensors, check join a wire. Do Not use the long cord USB gets lost the signal, appear the hindrances.
Write, help. Good luck
Posted on Sep 16, 2009
Sharp AR-m162 is printing from my computer but refuses to scan to the computer. It worked fine yesterday.
Run Sharpdesk network scan tool. in low right of your taskbar click on network scan tool
create a profile in profile tab, This will show up on sharp display as an avaiable location to scan to.you can choose where to scan to and what program if any to open when recieving a scan. Next in scanners tab click "auto detect" it will find available sharp scanners on the network. check one you want to use in the box in the list click "ok" close it make sure it is running in the task bar and add it to startup if need be but you should be good to go after this
David
Nov 13, 2017 | Sharp AR-M162 All-In-One Laser Printer
I need the driver 4 sharp ar-c260 scanner driver
Has scanning been turned on with the product key? Is your Image Send button working? If so you can go to the web page and set up a scan to a network drive folder. Or buy Sharpdesk v.3.2 with the network scanner tool.
Aug 12, 2010 | Sharp AR-C260M All-In-One Printer
Sharp AR-BC260 shows the network error CE-02
You need the Sharpdesk Software CD and you will have to install it in order for the scanning function to work.
Feb 03, 2010 | Sharp AR-BC260 Color Copier
Serial number for AR-M207 Sharp Printer Scanner Fax
The sharpdesk ser # is located on the documentation that came with the installation disk.
Dec 29, 2009 | Sharp AR-M207 All-In-One Laser Printer
Sharpdesk Scanner only works with certain computers?
Chances are it's the configuration of SharpDesk that's in question here. SharpDesk is designed to work with a myriad of systems as a scan interface, but older versions (pre 3.2) can be buggy, especially with Adobe Acrobat/Reader below version 7.
What you should do is go to each PC with SharpDesk installed and launch the program, then go to the pulldown menu and click on 'Tools'. Next, highlight 'Product Configuration', then choose the sub-menu item 'Network Scanner Tool'.
Once the tool launches, click on the 'Scanners' tab. In the 'Known Scanners' window make sure the IP check-marked matches that of the copier you're scanning from. Once you've highlighted that IP address, click on the 'Auto Detect' button to the right.
This will send a command to the copier to confirm communications pathways and test them. Once that's completed, click on 'Apply' and you should be able to scan to that PC.
If this doesn't work, you may need to check and verify the actual scan setup entries on the copier's webpage. Launch your normal web browser and plug in the IP of the copier in the address line. If you get a security prompt it's 'admin' (all lower case) for the login name and 'Sharp' (capital 'S', all other letters lower case) for the password.
You'll need to go to 'Destination Management', then whatever setup option you're using (i.e. e-mail, ftp, desktop, etc.) and confirm the existing entries for the scan functions are correct.
Hope this helps!
Sep 03, 2009 | Sharp AR-153E Copier
Scanner on Sharp AR-M350u is showing NG800000 and is not sending scanned items.
Jun 22, 2009 | Sharp AR-M350U Copier
We own a Sharp AR-M277 copier, scanner, fax machine that we use on our network. The scanner feature worked great, however, after 500 scans it stopped working. Someone told us that it was just a trial &...
The machine was put in a demo mode for scanning. What you will need to do, is contact an authorized Sharp dealer and purchase an MX-NSX2 kit and that will enable scanning and also purchase you a copy of a program called Sharpdesk.
May 13, 2009 | Sharp AR-M277 All-In-One Printer
Mar 23, 2009 | Sharp AR-M350U Copier
Check your primary and secondary dns entry.Also a return admin address is required.
Regards Ed
Mar 27, 2008 | Sharp AL-1641CS Laser Digital Copier
Have you setup your smtp address on the machine? From any workstation in the same network open your web browser. Key in the IP address of the mfp copier. Goes to network setup and key-in your smtp address.
Sep 14, 2007 | Sharp AR-M277 Black and White Copier
Sharp AR-M350U Copier Logo
709 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
