Question about Samsung YP-U3 MP3 Player
Will not switch on. Do I have to wait until it's fully charged?
  • 64 Answers
Try to press the reset button while it is connected to the computer. It will restart by it self, then unplug it.
Posted on Oct 06, 2010
Tip
How to Revitalize/Restore a Laptop Battery
After many hours of usage a laptop battery loses its' discharge time - it doesn't last as long as when it was new. The reason for this is because the internal memory of the battery has shortened the original capacity. Thus it remembers a shorter capacity than the longer one. This is due to charging the battery when it has not fully discharged. Here is a tip to reset the memory.You will need the following items:
  1. 19 and 10 Volt DC lamps with leads.
  2. A multimeter to measure resistance and Voltage.
  3. Two thin gauge wires about 3 inches long (should be able to fit into battery terminals).
  4. Electrical tape.
Locate the positive and negative terminals with a Volt meter using the two thin gauge wires - there may be more than two terminals. You just need to find the positive and negative. The voltage should be around or lower than 19 Volts. If the Voltage is higher than 10 Volts, insert the 19 Volt lamp to the terminals. The lamp should light.
Secure the lamp's leads with electrical tape to the battery and wait until the lamp extinguishes or go dim. This may take several hours depending on the level of charge the battery has.Then insert the 10 Volt lamp and wait again until it extinguishes. If the battery read 10 Volts or lower when first measured, then start with the 10 Volt lamp instead of the 19 Volt.We want to fully drain the battery with the lamps.If no voltage measures from the terminals, chances are the battery is bad and cannot be revitalized. Measure resistence between different combinations of each terminal with the Ohm section of the multimeter. If you read a short or low resistence, then the battery is bad - do not attempt to charge it. It could damage the laptop's power adapter.When you are confident that the battery has fully discharged, it's now time to charge the battery. Connect to the laptop and wait until the battery fully charges while the power adapter is connected. Do not power the laptop while the battery is charging - wait until it fully charges by observing the charging indicator on the laptop.When the battery has fully charged, test it by using the laptop and make note of how long it operates until it warns of a low battery level. If the duration has improved, congratulations! You are done. If it doesn't, then perform the above process again.
on Jan 17, 2011 | Computers & Internet
Tip
How to reset ECU,Throttle and Accelerator Position Learning
Hi.
Below the procedure to reset ECU,Throttle and to perform Accelerator Position Learning on Nissan. It works on Titan, Altima, Infinity, pathfinder and other models.
ECU Resetting
While performing the procedures below, ensue that you are respecting the times stated. If the steps are not done within the specified times, the module will not reset. You will need to use a watch or a chronograph while performing the procedures.
Procedure:
1. Ensure that the accelerator pedal is fully released, set ignition switch to the “ON” position, then wait 3 seconds.
2. Follow the steps a and b below, repeat the two steps in sequence quickly for five times within 5 seconds.
a. Push hard the accelerator pedal untill fully depressed.
b. Release the accelerator pedal in full.
3. Wait 7 seconds, then depress the accelerator pedal completely, and hold it for about 10 seconds until the CEL (check engine light) starts blinking.
4. Release the accelerator pedal while the CEL is still blinking.
5. Wait 10 second.
6. Depressthe accelerator pedal in full and hold it for 10 seconds or more.
7. Fully release the accelerator pedal while the CEL light keeps flashing.
8. Turn the ignition switch to “OFF” position and start the vehicle. If procedure has been done correctly, then the light light will turn off.
If the light continues to stay on, repeat the procedure.
Accelerator Pedal Release Position Learning
Procedure
1. Ensure that the accelerator pedal is completely released before starting the procedure.
2. Turn the ignition switch “ON” and wait at least 2 seconds.
3. Turn the ignition switch “OFF”, and wait at least 10 seconds.
4. Turn the ignition switch “ON” and wait 2 seconds.
5. Turn the ignition switch “OFF” and wait 10 seconds.
Throttle Valve Closed Position Learning
Procedure
1. Ensure that accelerator pedal is completely released.
2. Turn ignition switch to the “ON” position.
3. Turn ignition switch to the “OFF” position and wait at least 10 seconds.
Ensure that the throttle valve moves after turning the switch off.
Idle Air Volume Learning (Throttle Position Learning)
Procedure
1. Follow the Accelerator Pedal Released Position Learning described above.
2. Do the Throttle Valve Closed Position Learning also described above.
3. Start the engine, and allow warming up.
4. Turn the ignition on “OFF” positionand wait 10 seconds.
5. Ensure that accelerator pedal is fully released, then turn the ignition switch to “ON” position, and wait 3 seconds.
6. Repeat the steps a and b below five times within 5 seconds in sequence.
b. Release the accelerator pedal until reaching full extension.
8. Wait 7 seconds or more, depress the accelerator pedal completely and hold the pedal down for about 20 seconds until you see that the Check Engine Light stops blinking and starts getting steady..
9. Rrelease completely the accelerator pedal within 3 seconds after the light coming ON.
10. Start engine and let it run at idle for about 20 seconds.
12. Test the engine to ensure the idle speed and ignition timing are set correctly.
Regards.
on Mar 25, 2010 | Nissan Titan Cars & Trucks
I am new to all this. How long does it take to fully charge my equipment? Must I wait until fully charged to download anything?
Welcome to Fixya. Can you provide the make and model of your mp3 so that we can provide you an accurate information.
Thanks
Jun 09, 2011 | Audio Players & Recorders
I want 2 format my nokia3250 phone and i need the code to do that.
All you have to do is.
  1. Ensure that the battery is fully charged.
  2. insert the battery and power on the phone.
  3. ones it comes on, enter this code *#7370#.
  4. then enter your security code which is 12345 (if not yet changed)
the phone will automatically restart
just wait until it comes on again, then your phone will be formatted.
NOTE
it might show "SELECT COUNTRY " select your country, and continue...
i believe this will solve your problem
Jan 12, 2011 | Nokia 3250 Cellular Phone
Tip
To unlock Nokia N73(all S60 phones)
Make sure your phone is fully charged. Ads by Google
'; for(i = 0; i '+ '' + google_ads[i].line1 + ' ' + google_ads[i].line2 + ' ' + google_ads[i].line3 + '
' + '' + google_ads[i].visible_url + ''; } s += ""; document.write(s); return; } google_ad_channel = '+7733764704+1640266093+9911500640+5009222491+6529619144+3607312525+8962074949+8941458308+6876289738+7122150828' + xchannels + gchans; google_ad_client = "pub-9543332082073187"; google_ad_output = 'js'; google_ad_type = 'text'; google_feedback = 'on'; google_ad_region = "test"; google_ad_format = '250x250_as'; //--> google_protectAndRun("render_ads.js::google_render_ad", google_handleError, google_render_ad);
Backup your contacts list and personal files to MMC memory card (if possible).
Switch off your N73 phone.
Press and hold these three keys together:
  • The green dial key,
  • The star key (*)
  • The three key (3)
Press the power on/off for 1 minute to switch on the N73 phone. Do not let go of the three keys until you see the “formatting” screen displayed
Wait a few minutes until the format is complete. Your N73 will now be formatted and restored to its original factory settings.
This wont ask you for Lock code when you switch it on next time.
on Feb 14, 2010 | Nokia N73 Cellular Phone
Power failure
for powering on
use ur phone charged for sometime wait for some time after charging and press contiously the power bottone of ur phone untill the phone start fully
first it flash a white blank screen and then it start.
after start of phone
Please reset your phone setting without data loss it only reset your settings like as ringtones,skins,etc. as defult settings
U follow it work
Menu>Settings>Initial Setup>Master Reset>"ur secuirty code"
It takes sometime and then it free from this problem
Apr 16, 2010 | Motorola Mobility SLVR L7 Cellular Phone
Nissan Installed throttle reprogram
Here is the way to do it without the nissan scan tool. Make sure to follow all steps and it it best if you use a watch with a second hand.
1. Perform "Accelerator Pedal Released Position Learning".
a. Make sure that accelerator pedal is fully released.
b. Turn ignition switch 'ON' and wait at least 2 seconds.
c. Turn ignition switch 'OFF' wait at least 10 seconds.
d. Turn ignition switch 'ON' and wait at least 2 seconds.
e. Turn ignition switch 'OFF' wait at least 10 seconds.
2. Perform "Throttle Valve Closed Position Learning" .
b. Turn ignition switch 'ON'.
Make sure that throttle valve moves during above 10 seconds by confirming the operating sound. 3. Start engine and warm it up to normal operating temperature.
4. Check that all items listed under the topic 'PREPARATION' (previously mentioned) are in good order.
5. Turn ignition switch 'OFF' and wait at least 10 seconds.
6. Confirm that accelerator pedal is fully released, turn ignition switch 'ON' and wait 3 seconds.
7. Repeat the following procedure quickly five times within 5 seconds.
a. Fully depress the accelerator pedal.
b. Fully release the accelerator pedal. 8. Wait 7 seconds, fully depress the accelerator pedal and keep it for approx. 20 seconds until the MIL stops blinking and turned ON.
9. Fully release the accelerator pedal within 3 seconds after the MIL goes off.
10. Start engine and let it idle.
11. Wait 20 seconds.
12. Rev up the engine two or three times and make sure that idle speed and ignition timing are within the specifications.
13. If idle speed and ignition timing are not within the specification, the result will be incomplete. In this case, more test needs to be done.
Jun 24, 2009 | 2004 Nissan Sentra
Freezing
That happens to mine, too. What you do is stick a pin through the little reset hole on the left side (under the switch you hold down to turn it on). That should reset the player. If that doesn't work wait until the battery runs out and then charge it.
Aug 18, 2008 | Creative Labs ZEN V Plus MP3 Player
My motorola H700 keeps staying red when charging
Wait, how long have you waited for it to charge? It's supposed to stay red until over 80% charge, then switch to yellow. When it is fully charged, it goes to green. When you mean it stays red when plugged in, have you waited the 2 hours?
Jul 10, 2007 | Motorola Mobility H700 Wireless Headset
Samsung YP-U3 MP3 Player Logo
35 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
